查看: 2323|回复: 3
[已解决] 关于官网下载版的最新发现:教育版!(来自官网的证据)
发表于 2011-4-14 18:48:55 | 显示全部楼层 |阅读模式 来自: 中国浙江杭州
如题。
1 v' |) I0 k3 T; E) d7 ^先访问官网页面http://www.mastercam.com/TeachersStudents/EducationalDownloads/Default.aspx
& j" S+ ~5 e# H* Y- M9 f5 W# m有如下信息:& W  Y: ?4 ~- f0 P( N, s! }3 p2 v6 B
Educational DownloadsThe setups and requirements of teachers and schools for machining can be very different than in industry. In our efforts to provide the best support possible to our educational customers, we have put together this special downloads area. The driver downloads include files for your SIM or HASP installation or upgrades. The posts downloads provide several post processors for general or common CNC machines.
/ R5 l5 V  w# H' f& O* M0 [If you can not find the downloads you are looking for in this section, please visit the main Downloads page.
9 |$ ]  S  h% y2 W$ EIf you have questions about educational downloads, please contact your Authorized Mastercam Educational Reseller here or contact the Mastercam Educational Division [email=info@mastercamedu.com?subject=Email%20from%20www.Mastercam.com]here.[/email]8 F+ t& J( _5 a4 `. |" x4 |
- m! M7 z# C# ^: U8 r
相信大家都看得明白英文,按照指示please visit the main Downloads page.9 u" g; h1 I7 Z+ ^/ w; K
就进入了我们在官网的下载页面. t9 Z; z4 V& X7 s
http://www.mastercam.com/Support/Downloads/Default.aspx
  S3 F- `7 j, ^( _,教育版也可以用,呵呵,但是是不是会有一些文件转换和升级的限制?4 D. L- F7 }+ R( L2 M
那也就是说CD版本的是PC版。好,现在测试X3教育版
发表于 2011-4-14 20:55:56 | 显示全部楼层 来自: 中国江苏苏州
楼主真心细啊
 楼主| 发表于 2011-4-15 07:38:22 | 显示全部楼层 来自: 中国浙江杭州
刚才又看了一下,教育版又有单独的后处理下载区http://www.mastercam.com/Teacher ... /Posts/Default.aspx
# K. ]' y4 c0 O1 l/ @我是不是又判断错了?但是不管是不是教育版,我又有了新的发现:
) j+ @4 M& u+ M  Y* J. i& D譬如X3,在它的下载页面查看文件的“info”,包含如下信息:
9 B5 C9 V0 k2 M  q5 P) tYou must have a maintenance expiration date of 06/30/08 or later to run Mastercam X3. This install is designed to run as either a standalone product, or side-by-side with any other Mastercam release (excluding X3 Beta 1, 2, 3, 4 and PC...these must be uninstalled prior to installing X3).! ~. \) a) ]2 }" T+ p9 k* v
()里面的说要卸载beta版和pc版,那么既然不是PC版,究竟是什么版本?
发表于 2011-4-15 11:54:32 | 显示全部楼层 来自: 中国广东汕头
听楼主这么说了就到官网上去看看教育版的
