Dear Solid Edge Customer: We are pleased to inform you that Maintenance Pack 4 (MP4) for Solid Edge ST3 is now available for download on the GTAC FTP server. 7 |) }0 p h' v4 M
========== ) c: p4 @/ k/ ], f8 ^3 M
Installation:
! P2 K) E4 j9 w, f# t==========
2 y& Y* j* k" y, w( d5 f, K6 { After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on exe to install the Maintenance Pack.3 [, P# I: ?5 P' g) ^# ^6 ?
Windows 7 Installation tips: In addition to turning off UAC, right click on the exe and select "run as administrator" to complete the installation. * u0 u, j% l: F+ S* f' t+ j3 {
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing Solid Edge somewhere other than the default “Program Files” folder. Install in a location like c:\SolidEdge\ that the user has full permission to write to.
8 p7 L% c5 X X8 j4 e===============
4 L; O+ F& o" P& m6 `! b5 y4 S( zE-mail Notification:
, z% E7 `/ G9 S! @===============
* ]: C. @+ a6 W To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: http://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com
; u8 e$ r/ j* d8 Q# G r =========================================: b- @" R9 P$ R9 s, L5 O
This Maintenance Pack addresses the following PRs:7 n1 v0 y- W# F7 h" b5 I& _
=========================================) A. L! F/ w" W6 t3 q
===Assembly=== ) y# b8 r5 k2 C8 N" h& a* B: E
PR 1833635: Web Publisher result are incorrect if a part has sync and ordered features
) c5 R0 c, p4 N5 a/ s* R/ G5 YPR 1832106: Copied sketch elements, linked to the parent sketch, can be modified or deleted
* a" Q* }3 D9 {1 }2 D* Y3 R1 BPR 1835705: A crash occurs when a section view is applied and a part is placed
) c; z! K8 s$ _! p3 EPR 2161686: Path dimensions disappearing in the frame environment.' Y+ q* H0 J' c# M" ]
PR 2163832: Assembly pathfinder losing display of icons and hide/show boxes/ p \, K2 }7 B! a2 v
PR 2164176: Crash in XpresRoute when placing dimensions
& e v* e( `8 x9 i4 yPR 6426117: Fails to create Chamfer on Frame Pattern occurrence in first attempt
+ I0 T9 g; E7 X+ R F, o* FPR 6446233: Mirror assembly command fails with error message
, S# H y% Z( P+ o+ p$ jPR 6459239: No user defined properties in assembly query& O2 }# n$ N1 e# B1 T3 i
PR 6463932: Face of the flange should coincide with the endpoint of the line5 D' k- U" O4 t$ K& c: b0 h
PR 6471354: SAT file fails to import all bodies
2 {7 g5 K1 k( J1 k; fPR 6484211: mass of frame components incorrect
5 |8 r$ w! |+ \! Y9 ^6 W Y' GPR 6382855: Change Source button is disabled in the Edit Links command
$ c( V( x$ \' ]" Y3 c, ^. ~PR 6427250: pathfinder needs a lot of scroll in a particular workflow
9 c' o1 J% S/ N4 GPR 6472286: smart installer does not provide a way to not update already generated parts
5 _2 n0 f% Y$ SPR 6450569: Crash on Right Click in Configuration Manager
/ `$ p; s( [" L6 D8 hPR 1823993: Offset value field disappears if more than one part is selected1 {% O$ a1 D' k2 ?1 b( a
PR 1834121: Unable to open X_T file in ST3
! R6 m$ X8 Q5 ?3 n- L6 j. Z4 R' uPR 1837775: Solid Edge hangs when selecting a link in pathfinder
( ^9 F* A' A7 G3 N6 u/ k. C( gPR 1840226: Cannot enter an offset distance of zero
G1 ~9 M7 f, s, ~. M- `PR 2164215: Unable to create spur gear as done in ST2
: ]1 f2 c8 E# lPR 6469288: 'Apply Configuration' dialog comes up, when applying subassembly configuration
1 `# q8 I' H% {# D* qPR 1838609: 'Center Distance Between' missing in Synchronous Pulley Designer
* L5 b; S3 J$ F# D; X6 PPR 6447436: the Select Identical Parts command not being available in ERA
[% | r$ q$ z+ A4 [! G===Draft=== " X* a: N2 T7 k+ }! l% g% |. @
PR 1827819: Property-text "Mass" (in draft) is empty, if drawing is opened without model
0 Q8 d" q% @! [3 \+ R( u% \PR 1831283: Texture Symbols and Geo not imported# `" v* x: |4 v- Y# ~9 t" U
PR 1836610: Unable to save a single sheet to PDF to its correct size2 M: }, N. ]& r3 G
PR 2097195: The space of the tolerance is too large
3 H& d+ m8 |: I- IPR 6438504: Retrieve Dimensions will only work from one model at a time8 X2 A2 ~+ q+ X8 @3 R7 q1 k
PR 1830981: Parts list header text wrapping changed V20 vs. ST37 S6 }& x4 P* Q3 Z) Y8 O; l
PR 1833476: Copy link / Paste special does not give correct result in ST3
0 s3 A5 X* X; WPR 1836176: Draft where SE crashes in connection with 3D Device and mouse drag
; }( h) t3 W6 x+ PPR 1836241: Parts list is not showing FOA member names
! B8 B+ W3 r" KPR 1837622: Cannot open or create drawings after installing ST3 MP3
- f1 _; G# r" o, U, J0 \$ a9 xPR 6476574: sheet being renamed( U1 y6 c; P: n: Z/ u
PR 1840034: Performance problem updating views with PMI model views specified# W% X3 t$ j, e
PR 6439408: Bad Display in PDF & p, d) U) M( X$ B* A! F
PR 6495446: Predefined Draft Text (Annotation) Alignment does not work
" `8 S! _7 T9 \; N# ?% UPR 1840906: SE aborts when updating view; }, @+ e V! I# m! Q: Q" U
PR 2166384: Leader display has changed from st2 to st3' n( x0 h4 K8 [9 p; a& c4 ^( \
PR 6461898: %RT does not work like it did in ST2) x2 K! q, k& k
PR 6491943: Drawing view properties section tab not enabled/disabled based on PMI view selected \% C5 s% A% F3 U0 m% Z
===Insight/View & Markup===' f& F7 k( L9 j, V( G; {8 `7 W
PR 6483466: Search not returning results from top level site only sub sites4 r$ k$ [2 j$ r- t4 {
PR 6484521: Crash saving as pdf into a DocLib with required properties
/ a) n9 G; b8 X& f8 uPR 6497333: Errors in Insight Logs since upgrading to MOSS2007/ST3, |. N, e+ D5 V7 Q8 ^
PR 6483575: FOA property mapping problems with SharePoint% W7 A+ }+ f- {, M
===Part/Profile/Sheet Metal===
% C' S# I F( G8 j* N; D* f7 j5 nPR 1834162: Draft option in synchronous extrusion doesn’t work properly
) K" l0 r. h' E( r/ z7 sPR 1824904: "Show only" is missing in ST3 ordered
/ D% N! W/ e) {7 e* sPR 1832775: close corner reacts different in ST2
# @ p% c @: J* V" B& sPR 1833282: Sheet metal local symmetry doesn’t work (Live Rules)+ }' m# m# q4 H4 B
PR 6493372: Bend direction not showing on printed .psm documents from batch mode
/ X, J# ~* f* l1 ~) N( X# LPR 1835549: Unable to pattern a feature
1 V* u, V% h+ gPR 2164158: Extrude created a feature with a duplicate name
; H2 R* R' d5 p% P$ N$ hPR 6489351: Crash occurred while reorienting the steering wheel while in SE Simulation
) {# n, z }8 s# Q* x, \7 iPR 1838826: Dimensions placed with feature are not editable in FOP
6 H: k1 x2 p2 V( G# y& ~+ B7 T0 g# APR 2165475: Japanese command tips being garbled in crashlogf.txt
/ W \7 R4 ?; m! j$ yPR 6493558: User is unable to scale a part copy when importing it into a new file
' \- _3 C: i; a, o, QPR 1826580: It’s not possible to assign part material with ordered and synchronous features* \2 g2 w( f" ~6 J" Y1 n" Z: m
PR 1829378: Material Thickness on Gage tab of File Properties dialog is no longer accessible
0 l' M) c6 R; KPR 1833358: feature library is not working0 ]' J5 y) M% O8 T" r% ~
PR 1837948: Unable to flatten a psm file
% k, l) }! G/ [, {# H/ ?' q4 D- vPR 1838687: Solid Edge aborts when populating FOP members( z3 C2 y% c& v9 E- r
PR 2165291: Normal Distance causes an abort in Japanese ST3 - Sync& w; W5 J; A7 D6 |
PR 6385655: radial edits taking too long for synchronous models& U2 u" n% f9 S7 Z" X
PR 6389400: Wrong result on flat of conic shape with cutout. s, r" H0 u7 g9 l8 ?& Z% t3 Q
PR 6442323: cutout in ST3 synch part that takes 10-30 times as long as ordered/ R. k e0 V$ V. v) P: K o8 f
PR 1704478: After dissolving UDS, features don't remain selected) z3 B$ _7 @( v. ^' ?$ h( |
PR 1816608: smart pattern performance - applies to both pattern and pattern along curve# E p% w1 }% n; n' o4 j( q
PR 1838985: Countersink is lost when re-bending w6 g, n+ H6 r# s. K* {
PR 2166692: Unable to select curve control points for connects with Solid Edge x644 k* K" w' e( s; K1 H9 ~3 }9 B
PR 6461572: Pattern Plane creation is incorrect most of the time' Z7 j9 o" \/ _: _2 q, s, N# ^
PR 6469130: Product uses a lot of memory when placing sync cutout using Text Profile0 Y. E% S7 J, i) N( j' l6 N9 F: {, y
PR 6509580: edit handle arrow does not point to edit face
' _' g9 t A$ ], X0 K ===Solid Edge Embedded Client===
X1 B3 b2 P1 @5 }2 u2 y9 uPR 6479486: SEEC API OnGetWhereUsedForAutomation does not work
4 A# n$ m z+ i- T7 v VPR 6495362: Unable to Check-in documents; returning document has moved or is missing error
' g0 y: k( X; O$ U2 L7 wPR 6507472: Need to verify the back port Item Number - Find No. Integration project* m& e# G! Z- Y6 @% W! Q4 f
PR 6484387: No warning given for Item id conflicts with virtual components 1 o+ b: M5 z% F# e( o% _+ e0 d
PR 6512292: Next Available Number command doesn't consider TCVC3 Q" n" o: }# Y h, J
PR 6441245: Modified weldment feature is not updated in structure manager in RAC5 }+ W# h7 m. z* m7 X6 l; S
PR 6471911: SEEC does not recognize multiple revisions during open in an assembly
% ^. W3 @+ I$ E) d3 `' aPR 6482868: With PS_new_seqno_mode=none the Occurrence Properties show nothing
7 c/ @" A- S& A# Y# r5 gPR 6512110: after deleting assembly feature the JT is not updated in the Tc viewer |
