发表于 2011-9-25 20:28:09
来自: 中国山东烟台
9 Y- ?; P/ F) X, m6 i
当然可以,这是我写的G0G1钻孔后处理代码+ ~( R& C1 @2 t, j4 J8 g; C3 k( Y
: ?/ V8 L6 m, i
7 {& w+ j& C% t m0 CCYCLE: ON:+ a7 l/ x3 ^1 C. k" T
*{{ GPP range check
. w# Y# O" q4 L }( q# L' P*}} GPP range check; E. U& Q5 D! t8 S/ k2 `
FlagSpin = NO ;6 Y9 {0 B. w: ]" g& s: c/ j7 O
IF_SET (SPIN_SPEED) FlagSpin = YES ; END_IF ;
9 G( e# u8 m" f1 @) o" S# a IF_SET (SPIN_DIR) FlagSpin = YES ; END_IF ;0 _- q8 R, ]: Y( A
IF_SET (FlagSpin _EQ_ YES)
3 @& S! `6 l. t2 Z; Q( w8 L! k3 k% B) i* \- u
SET_ON SPIN_SPEED SPIN_DIR ;
) H- K5 T( P, p8 U, n2 J2 _ END_IF ;
) p6 m$ t {/ M4 I. m' _9 ]" h7 t& r: l1 U) p& C
SET_ON X_CURPOS Y_CURPOS Z_CURPOS ;
" H$ t9 F2 \2 v7 c! Y9 N, W& B C SET_ON CYC_DEPTH CYC_RETR CYC_CLEAR MCH_FEED ;& x, Z- _2 m0 ]% r1 Q' s+ m
SET_ON Zinit Depth Clear ;) D* w) ]' N2 A
Zinit = Z_CURPOS + CYC_DZINIT ;( h/ \" j) T% u
Depth = Z_CURPOS - CYC_DEPTH ;
2 c/ d9 M4 u+ U. T' x" L5 K- b Clear = Z_CURPOS + CYC_CLEAR ;
, A" A( z, D) }* j IF_SET (Zold _LT_ Zinit) OUTPUT $ "G00Z" Zinit ; END_IF ;
' V4 P6 \) l1 o- G9 o' j4 {2 X0 T# d& m& e
OUTPUT $ ;
( K; u$ `' y& f# N' t& U& L1 g+ v' e
OUTPUT "G00";
' z, C% o! L7 D) S/ l5 R1 m1 v* D+ h/ W H! O0 t+ F( w1 v
OUTPUT "X" X_CURPOS ;2 r8 S7 Y7 g" Q( z6 r# z$ G) ]& [
: v% B0 H4 `5 d) r% ~ OUTPUT "Y" Y_CURPOS ;2 W, E. A3 P! [: `# @6 A, O: W* c" J
OUTPUT "Z" Zhome ;- r7 G @1 W. A+ W9 T; }
OUTPUT $ ;
& M/ p( q* `' t% K; _
' O4 @$ L0 u8 G- x9 `4 P; y; A9 z4 L
! h/ b% d% K. W, N# s# ~2 B
OUTPUT "Z" Clear ;
% d7 `" ?3 |' v3 E! a OUTPUT $ ;+ `+ Q4 P6 s& r- t7 C; I
! | H4 Z6 c) \) W& y
IF_SET (LIN_MOV) OUTPUT LIN_MOV ; END_IF ;
3 C4 P+ m" f6 w- J! J# G. R9 g3 C3 h* A7 e! y
- C( p3 N# K& \
8 A/ a# G) Q$ h5 J1 q OUTPUT "Y" Y_CURPOS ;
8 x" k+ r$ Y$ D3 _- O7 N% i5 W+ ^" m7 w/ O
OUTPUT "Z" Depth ;
( W- o" b: U6 y6 {! }8 w+ {2 }4 j" q# r4 j
OUTPUT "F" MCH_FEED ;/ v, p! n% X3 R% t
8 U2 \- H( t: f% |4 y! h! D; @8 |
SET_ON LIN_MOV CIRC_MOV ;
/ X' ~) {( [5 k" M& Y, p SET_OFF CYC_DEPTH CYC_CLEAR; 8 O+ @2 P3 E4 r3 z" q9 k- F2 @4 t
Xold = X_CURPOS ;
; c/ \9 A" p' `2 f( ?( O; ~ Yold = Y_CURPOS ;
) ` p& t- f$ h. }' C Zold = Z_CURPOS ;
0 W, A5 U/ d- a. k6 B8 u8 T
. g+ n% q e: b& S. L+ gCYCLE:- ?! w) i( v; p1 J
*{{ GPP range check
; w' M. O% X5 O*}} GPP range check, b7 w( o( i1 a- n& {5 D. }8 B* A
SET_ON X_CURPOS Y_CURPOS Z_CURPOS ;8 M7 |0 w2 l* [9 D/ q
3 t p: k$ Q1 O, T% N: @ SET_ON Zinit Depth Clear ;
+ ]" ?- R4 g9 c Zinit = Z_CURPOS + CYC_DZINIT ;
2 Z% s* d, s+ p% x# i Depth = Z_CURPOS - CYC_DEPTH ;
9 Y% z1 }; q0 i, s! B2 O+ ]% r Clear = Z_CURPOS + CYC_CLEAR ;
: U" Q5 F+ v/ R9 ]# {4 w, \ IF_SET (Zold _LT_ Zinit) OUTPUT $ "G00Z" Zinit ; END_IF ;4 `( g5 T* I$ w8 g" O4 r- ^
OUTPUT $ ;7 C* o" x$ N7 Z) S0 e& X
5 H+ o0 m4 A: W3 V; y& E, |
+ d, x+ r) X. O' w3 W5 Y) f
. {6 t5 ^8 k( S, x4 K1 M8 _$ \
J! N% q" Z7 I( ]
) u: W! j1 w1 J }5 {) @ OUTPUT "Y" Y_CURPOS ;. b) y V9 x6 S9 b& g6 x, N' C6 `
OUTPUT $ ;
; @( w; F3 ^7 n1 L4 J/ r6 m4 N# d: j; ?
( L; z" m6 m$ S" P
I/ d/ X# N) ^* M) \ OUTPUT "Z" Clear ;# p d; L! E2 ]0 @% s: U9 S
OUTPUT $ ;
& B% u2 C8 n# E$ J+ o& D% o1 h% |. \" B
IF_SET (LIN_MOV) OUTPUT LIN_MOV ; END_IF ;# p' A; f1 J+ v$ y8 w o) V
( f+ M, H4 Y, \4 a+ B- ]; c
' Q# t) p0 ?( H2 f, Y! q( _* b( H! v4 N8 B+ A! _4 g
OUTPUT "Y" Y_CURPOS ;5 E: E/ R0 c+ x
3 L$ ]/ W( Q* w* Y OUTPUT "Z" Depth ;
* H8 D! k1 y! n0 P IF_SET (MCH_FEED) OUTPUT "F" MCH_FEED ; END_IF ;4 @ V( Q$ R3 |3 F W6 j2 a
( S1 E5 `, u/ c$ B/ B7 l% m# n SET_ON LIN_MOV CIRC_MOV ;" W7 I' Z7 K5 f3 o
: {6 {5 t0 v3 G+ M" t Xold = X_CURPOS ;- c- q/ [" Z5 N* d& j( A# M+ q
Yold = Y_CURPOS ;6 O; |: _% W1 a: k6 M
Zold = Z_CURPOS ;7 C- n9 X5 W! z! q* a! R
1 Y7 F4 e) Y- M- W; aCYCLE: OFF: Q# I, `. E/ Z) i$ j- U
*{{ GPP range check2 |" z2 v9 F2 u C! @4 y/ r0 D
*}} GPP range check
% A9 @ T! h* X OUTPUT $ ;( \# A! h( n2 ~
OUTPUT "G00Z" Zhome ;
" U# D4 Y% M/ d; Q. X SET_ON CIRC_MOV ;' j+ X7 I( w- a- n6 g! t& `- q
Zold = Zinit ;4 B% O m5 ?! I1 L! l
* R( Y$ h* L4 @; [7 S# l2 p
