6天前
查看: 1849|回复: 4
[求助] 请教几个量规
发表于 2011-5-19 11:39:04 | 显示全部楼层 |阅读模式 来自: 中国湖北潜江
本帖最后由 长江浪子 于 2011-5-19 11:52 编辑 . o% k  V2 q- Y0 t, I
. L0 Z8 A: ^5 d- I, W最近在一个量刃辅明细表上看到有几个东东不知道,在车间也没见用过,
/ S2 a% ?8 r! f" c) d# \/ J请教一下高手,介绍一下工作原理及使用方法,有图片更好,感激不尽:" {; L' K- y0 t
1、花键塞规、单项规是个什么东东,如何使用) h+ W: z: {9 b; Q& n- ]7 D' n
2、API 2-3/8"锥度光环规,也没见过。
发表于 2011-5-27 15:22:22 | 显示全部楼层 来自: 中国四川成都
花键塞规就是检测内花键的塞规,也是通止规。单项规应该是某个单项参数吧,分度圆啊什么的' |: N# b2 [5 y* [8 g5 a
API锥度光规,就是一个锥度塞规没有螺纹,功能忘记了,查一下螺纹手册就能知道
plc + 2 应助
发表于 2011-5-27 22:10:37 | 显示全部楼层 来自: 中国湖南长沙
This ASME guide is a valuable introduction to a subject that is of importance to analysts of all levels; and although aimed primarily at computational mechanics, is applicable to all fields of simulation.  The importance of Verification and Validation (V&V) of analysis is not always fully appreciated; and is often misunderstood.  In writing this guide ASME has produced an excellent introduction to the subject, which both demonstrates the importance of V&V to engineering simulation; and presents a range of generic methods for performing V&V processes.
" J( Y% Q' i$ t/ s4 _; Y/ Q7 U  n: QThe guide recognises that the modelling of the physics of problems encompasses simple systems, such as linear elastic structures, through more complex non-linear systems to those cases where several inter-related physical process need to be modelled together or as separate stages in an overall simulation.  With this in mind methods for carrying out the V&V process on all types of models are described, along with a discussion on the development of a V&V plan.) B( F5 q. o3 R( u2 K# a
The guide finally examines the two processes separately, verification with respect to the numerical fidelity of the simulation; and validation with respect to the representation of the physics.  The section on verification looks into the various techniques for testing the accuracy of the numerical solution, from the use of closed form solutions, to alternative numerical benchmark solutions.  The validation section provides a background description of the design of validation experiments, uncertainty and assessment of accuracy.# }1 h5 D* }" m) Z  i  V* K
This ASME guide complements the documents being produced by the NAFEMS Analysis Management Working Group (AMWG); and will provide a base reference for NAFEMS documents on V&V.  The AMWG looks forward to continuing our already strong relationship with the ASME V&V committee.
发表于 2011-5-28 13:56:49 | 显示全部楼层 来自: 中国新疆克拉玛依
API 2-3/8"是油管螺纹,分不加厚(NU)和外加厚(EU)两种,API 2-3/8"锥度光规也分上述两种型号,一组由光滑塞规和光滑环规组成。分别用于检验油管螺纹或相应接箍螺纹1:16锥度。检验方法主要是以涂色法或间隙法为主。
发表于 2011-5-29 21:39:40 | 显示全部楼层 来自: 中国广东惠州
花键规我就知道,是用在汽车轮毂孔拉削花键的检查用的% Y1 V; l5 V. y
花键根据孔的大小模数不同的,我们公司有 26-28个模数的.
