% N+ U e- J: T3 ?( J, `4 k- Const pi = 3.1415926
% C: `3 }: r. f8 D% c9 W - Private insp111(0 To 2) As Double- T. y# |8 v3 W+ k0 [
- Public td111 As Double4 k! Q2 e, i7 m- q
- Public t_D111 As Double
" F1 e! k- I* K7 [; y - Public td1_111 As Double
8 T7 W- l& V2 c1 A u# T' ` - Public td3_111 As Double
# C( v2 x, \4 s) z5 r6 p - Public tH_111 As Double
& z# A0 ]( q% j$ ]3 B/ ]& j - Public t_l111 As Double
1 ~) I/ g/ C1 t) y4 |) q; c* c - Public tr111 As Double7 G7 D* a V% W: J- F
- Public tr1_111 As Double
+ N- H" C$ E2 ] - Public tL111 As Double
& V2 Q8 H2 j* K3 a4 N' ~9 \ - Public yuanxin111 As Double# x9 O! I) ^1 _7 d6 o7 N
- Public yuanjiao111 As Double
6 J+ @$ M3 h( a4 |- j - Public yuanjiao1_111 As Double5 Z! l/ @$ S" v6 U4 l M! y& f/ l
- Public distance111 As Double
% n! x% F4 E: U! i+ h1 E! { - Function dtr111(q As Double) As Double
1 X3 S6 \" s( ^* |# \$ ` - dtr111 = (q / 180) * pi; q( f/ E; a) V0 ?8 i
- End Function
( W+ z3 k7 k, [6 W+ J" m - Private Sub aJBT111()
' f% g, Q! m* G: w" K! ^ - Dim varet111 As Variant
" T1 A; ?3 m7 `+ p% z5 h9 n - varet111 = ThisDrawing.Utility.GetPoint(, "ÇëÊäÈë²åÈëµã£º"6 z$ W6 S: F! ?
- insp111(0) = varet111(0)/ o1 t6 z5 H0 e1 F# v' a4 F
- insp111(1) = varet111(1)
2 U# j9 |/ j) L - insp111(2) = varet111(2)
% w% p+ ^! |) _- [- s - End Sub7 X3 r, m$ r' S6 V- [ ]
- Private Sub drawout111()
_; l% w$ ]& @: f - Dim startangle111 As Double
: @7 O3 Q+ s+ W3 @* B4 n X - Dim endangle111 As Double0 W7 Z4 `# ?+ @0 t; } [0 e, j
- Dim lstartangle111 As Double' C8 }4 |" E* i) Q" X$ p! Z
- Dim lendangle111 As Double
& G7 M) d# i6 Z, a: Z) \ - Dim startangle1_111 As Double( W* O! d M5 K& x$ Y
- Dim endangle1_111 As Double# K6 O- K. ~5 j
- Dim pointsup111(0 To 9) As Double
- _+ O( l. \/ Q& g2 _ - Dim pointsmid111(0 To 9) As Double
! L7 ?# G: [5 K! ]+ q, X# j - Dim pointsdown111(0 To 9) As Double
) W v1 J' T' I! y2 D" J/ U - Dim sp111(0 To 2) As Double
% s1 J+ o A% J+ p8 _9 s3 ~/ h0 u - Dim ep111(0 To 2) As Double
# G; M$ ^* k+ f- B* o' N4 Z - Dim spnext111(0 To 2) As Double
# v1 w$ `. o9 C( Q: @0 E2 q, n2 Y - Dim epnext111(0 To 2) As Double
# e" u7 f. c5 F+ _6 p9 x* t, Q# d7 m - Dim spend111(0 To 2) As Double
) Y0 b. s0 ^( {/ w' o$ J' e9 G( V - Dim epend111(0 To 2) As Double/ ]9 N, {" ?8 m( N6 |" G
- Dim spendnext111(0 To 2) As Double
( d: e, z) m3 @0 x+ r - Dim ependnext111(0 To 2) As Double7 E. B B; b. H7 Y, g* J
- Dim arcst111(0 To 2) As Double: H1 a/ L0 K2 L- a3 L
- Dim arced111(0 To 2) As Double1 @1 v4 ^; \* j
- Dim arcnextst111(0 To 2) As Double. o5 S( w1 j) v/ ] \ D1 `: }
- Dim arcnexted111(0 To 2) As Double
6 b* {2 @4 T0 ^& I( K. _6 r - Dim dashst111(0 To 2) As Double! }# L; e/ c8 `% m/ V
- Dim dashed111(0 To 2) As Double# N3 P6 n! E2 q
- Dim ndashst111(0 To 2) As Double% Q. A3 j" G: [$ j8 j+ j
- Dim ndashed111(0 To 2) As Double
! Z) E. H0 W( u3 P! A$ _/ j8 \ - Dim lsp111(0 To 2) As Double" k6 h8 e! ~* `! h P
- Dim lep111(0 To 2) As Double7 }1 Y5 n& s4 c
- Dim lspnext111(0 To 2) As Double
" P7 |2 D0 k- o6 T% L0 p - Dim lepnext111(0 To 2) As Double
# x# {$ t8 F( N0 h9 z - Dim lcenterpoint111(0 To 2) As Double
! u5 Z% N* M; z5 K& y - Dim rcenterpoint111(0 To 2) As Double
0 `7 J) g' h8 C$ G2 I# t, d* z - Dim pointws111(0 To 13) As Double# X- n8 B& B- x* w$ ^2 J2 p& }( h
- Dim tp111(0 To 2) As Double
" i: B8 O. n, {$ }, b: d' W( x - Dim bp111(0 To 2) As Double& q; H* v* S0 ~/ j8 \8 }2 A
- Dim ltp111(0 To 2) As Double2 X. S1 c2 v% Z) }" ?; R3 d: z+ f
- Dim lbp111(0 To 2) As Double9 w9 e5 o; ? g7 C: P3 r8 R9 Y$ v
- Dim lwlsp111(0 To 2) As Double' P& Q- @" Y5 m4 B
- Dim lwrsp111(0 To 2) As Double9 S' y; V9 R. x+ L
- Dim lwlxp111(0 To 2) As Double: d, ?4 U- s- A3 d | a1 ?% p0 G
- Dim lwrxp111(0 To 2) As Double1 `6 S9 ^0 m% F
- Dim centersp111(0 To 2) As Double
1 Z# g C6 k. w - Dim centerep111(0 To 2) As Double
$ ^ _1 D/ Q: }% ` - Dim starc111(0 To 2) As Double. B4 z5 @1 C. n8 W3 Q
- Dim edarc111(0 To 2) As Double
# X) m/ B; S8 P+ [% V - Dim ctp111(0 To 2) As Double- d9 r) A g# j4 n A
- Dim pline111 As AcadPolyline l7 |* J* F: r
- Dim lineobj111 As AcadLine t: ^7 ]+ b' C6 k" S8 ~7 t; r
- Dim arcobj111 As AcadArc
6 h4 O N, j# R# @& s7 p! a2 o5 I: Y - Dim varet111 As Variant! w, j: p& ?+ c4 \. v0 K: y9 R4 Z5 c
- varet111 = ThisDrawing.Utility.PolarPoint(insp111, dtr111(0), 0.5 * t_D111 - 0.1 * td111)1 M4 X- C" [( ^! ~: r- a
- pointsdown111(0) = varet111(0)
& Y3 ?; C8 r/ l* }, w0 ^& f( C& Y - pointsdown111(1) = varet111(1)4 g& \3 s( R3 @5 A4 b6 m
- pointsdown111(8) = varet111(0). e _2 U" }. U) `9 f' f
- pointsdown111(9) = varet111(1)6 Z3 U. R' u8 S- r5 J
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(0), 0.1 * td111): }1 e( {8 x/ v; O
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(90), 0.1 * td111)
- u! O) f8 V' D! j+ A. ^1 z - pointsdown111(2) = varet111(0)
; V c( S5 H: c* Y( c* E - pointsdown111(3) = varet111(1)$ X# b: u6 W$ d5 A7 K A3 d5 ]
- spend111(0) = varet111(0)
$ }- s' b" Z4 G0 z5 N5 M, P+ q - spend111(1) = varet111(1)
/ k6 p; C1 H# D# G' M8 | Z - spend111(2) = varet111(2)
& T4 W% e2 N. [" Q5 [3 x2 f) J, ? - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(180), t_D111)
* w1 {1 m6 p+ p* X8 }" @: j( Q - pointsdown111(4) = varet111(0)8 N2 T! g _0 j. ^6 \; u
- pointsdown111(5) = varet111(1)
( g# G4 W! H/ R" M- z8 \& c - spendnext111(0) = varet111(0)8 H/ V" o3 S8 ~, A. N# [1 a/ b( M3 R
- spendnext111(1) = varet111(1)
2 L, w0 D0 {- D" N5 e: w' x" T - spendnext111(2) = varet111(2)
" A5 w1 M% b( Z6 o+ X - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(270), 0.1 * td111)% k( l5 X1 I2 s/ S. W) n# b
$ ?; O$ `. d* ^) J9 G5 F - pointsdown111(6) = varet111(0)
+ s9 a; M- {; ?/ n- t - pointsdown111(7) = varet111(1)
0 s; R6 h* l j+ I7 d' z' c# ?( t - Set pline111 = ThisDrawing.ModelSpace.AddLightWeightPolyline(pointsdown111)# { b4 T `: x: Z! O7 b
- varet111 = ThisDrawing.Utility.PolarPoint(insp111, dtr111(0), 0.5 * t_D111)
! O: D: f9 L6 O - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(90), 0.5 * tH_111 - 0.5 * td3_111 - 0.1 * td111)
/ u# F7 h/ j2 Q% N Y9 R - epend111(0) = varet111(0)
/ p- _$ P K6 t, R1 D2 {' b - epend111(1) = varet111(1), f; H) u! m; h& v/ A, A
- epend111(2) = varet111(2)4 E5 x# |0 u' H
- arcst111(0) = varet111(0)/ M- ~. o- X- I7 h
- arcst111(1) = varet111(1)
% W4 e/ U' J2 P( V - arcst111(2) = varet111(2)& p) Q! m0 ~! V0 g$ V
: |( e' E) Q: W4 `( ] - ependnext111(0) = varet111(0)0 L. g- L) T, Q7 x
- ependnext111(1) = varet111(1)" M) A, s4 p) _8 h( k) h# S, U
- ependnext111(2) = varet111(2); y7 w( V5 `6 f/ h- q% w
- arcnextst111(0) = varet111(0)/ M6 @) o2 [) `1 K; E8 B) j
- arcnextst111(1) = varet111(1)$ N9 S* g' r+ T; j: p7 n$ l
- arcnextst111(2) = varet111(2)
& X/ Z6 O) ^3 T" G8 a( z - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(90), td3_111)7 Z2 P) b3 G; X2 c
- arcnexted111(0) = varet111(0)
, E" Q8 U# W8 f - arcnexted111(1) = varet111(1)
- L6 E) k& C5 V$ i* b - arcnexted111(2) = varet111(2)
) l; h7 _3 S! H Y; R7 R - spnext111(0) = varet111(0)7 n) V7 b6 f- d9 t: T3 M4 K* L
- spnext111(1) = varet111(1)
5 d) ]. Z/ R ]. }: M - spnext111(2) = varet111(2)
& P/ U2 U" M3 a( s - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(90), 0.5 * tH_111 - 0.5 * td3_111 - 0.1 * td111)
" B# C5 E0 t8 F0 y; a8 x( v - epnext111(0) = varet111(0)4 O4 O8 V4 F& B X# W
- epnext111(1) = varet111(1)
0 [/ `: j# l; E/ P6 x1 |) [, J) W - epnext111(2) = varet111(2)* k! F* O/ l9 n/ A# R; `- A
- pointsup111(0) = varet111(0)3 J4 n. K9 j! Y: |5 ~) h
- pointsup111(1) = varet111(1)- v3 E ~. v+ |, V, F8 ]
- pointsup111(8) = varet111(0)* |! F G* i3 I( H
- pointsup111(9) = varet111(1)8 e& h5 i* l0 I) U6 |
( {2 G9 F. J4 A' V) _/ Z" T - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(0), 0.1 * td111)
4 V- q" b5 L9 ^. n- x. F( m - pointsup111(2) = varet111(0)+ P( i! z4 @4 b9 {; p7 g/ [& U$ ?
- pointsup111(3) = varet111(1)
# f* \& F0 i: Q7 a% n5 G1 L - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(0), t_D111 - 0.2 * td111)
5 _% {' J, c0 U7 C5 C - pointsup111(4) = varet111(0)
4 K* `# C" X( N4 c5 P) O* m) w - pointsup111(5) = varet111(1)
6 Z" E( P6 G k- g - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(0), 0.1 * td111)7 H! w$ D3 S0 ^7 ^# f: N
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(270), 0.1 * td111)( }+ \' U. N0 E5 D& G( \
- pointsup111(6) = varet111(0)
* A- U* T; e% t" S5 Y& a) ` - pointsup111(7) = varet111(1): X* D3 T5 n3 }$ `
- sp111(0) = varet111(0)7 [& R; ^! s& u5 N) x) F" J
- sp111(1) = varet111(1)( [ O. g9 W" y: @" s7 P
- sp111(2) = varet111(2): ]8 l& A; T+ m2 M8 d' k3 l
- Set pline111 = ThisDrawing.ModelSpace.AddLightWeightPolyline(pointsup111)
) \% \1 `) `3 c4 s" U$ _) r; Z4 R - Set lineobj111 = ThisDrawing.ModelSpace.AddLine(spend111, epend111)
, d9 I$ Q( Q, ` - Set lineobj111 = ThisDrawing.ModelSpace.AddLine(spendnext111, ependnext111)
/ H" E9 a4 u! e% | - Set lineobj111 = ThisDrawing.ModelSpace.AddLine(spnext111, epnext111): n. ^5 p4 s, x/ H5 t8 d3 o d
- varet111 = ThisDrawing.Utility.PolarPoint(insp111, dtr111(90), 0.5 * tH_111 + 0.5 * td3_111)# q% H! E) c! d' w( u& I9 k! I5 F
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(0), 0.5 * t_D111)
& @' A2 [- k* H" |. @: B, r - arced111(0) = varet111(0)
; H. m, o# G! ?/ d - arced111(1) = varet111(1)7 J0 ]3 `1 Y4 W% Y" b3 ^/ e
- arced111(2) = varet111(2)
% x) U9 v2 q+ l8 S - ep111(0) = varet111(0)
) B. h3 u u% ~1 Q0 B - ep111(1) = varet111(1)
: _. |3 P* B. g$ C# O3 @9 _8 c - ep111(2) = varet111(2)
* \8 Z1 |, m1 I: s! P- Y - Set lineobj111 = ThisDrawing.ModelSpace.AddLine(sp111, ep111)" O4 @3 a& |3 W" n+ H$ N
8 [! R' T4 Q6 Y1 H - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(90), 0.5 * tH_111)
- _: e3 {0 f2 h6 \ - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(0), yuanxin111)
% g Y, ?3 b- e" q7 G - rcenterpoint111(0) = varet111(0)' W! ?2 t0 M! Q3 B. ~( Q/ U2 N
- rcenterpoint111(1) = varet111(1)
: e0 B! d" b2 i3 b4 J" v& U$ v' h+ o+ R - rcenterpoint111(2) = varet111(2)4 `3 i; I3 B* o3 c1 h
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(180), 2 * yuanxin111 + t_D111)8 i' b+ R, W5 d+ q% g
- lcenterpoint111(0) = varet111(0)0 y- P1 \$ ^* l1 L! C4 O& c1 U9 O
- lcenterpoint111(1) = varet111(1)
6 K3 a+ a" y9 |; c- A- s( m - lcenterpoint111(2) = varet111(2)
8 u; A+ G) y! Y4 @. u4 v - startangle111 = dtr111(90 + yuanjiao111)
0 f/ [; y7 ~- F# O/ j1 b H - endangle111 = dtr111(270 - yuanjiao111)
3 c; X; g# T4 ~ - lstartangle111 = dtr111(-yuanjiao111)+ v {) \. A4 l3 M2 u$ _
- lendangle111 = dtr111(yuanjiao111)
* {0 s$ Y9 @2 r# j - Set arcobj111 = ThisDrawing.ModelSpace.AddArc(rcenterpoint111, tr111, startangle111, endangle111)$ Y! ~( D2 U0 D7 p! G
- Set arcobj111 = ThisDrawing.ModelSpace.AddArc(lcenterpoint111, tr111, lstartangle111, lendangle111)! Z; M5 @6 {, b# {: }" a+ L4 p
- varet111 = ThisDrawing.Utility.PolarPoint(insp111, dtr111(0), 0.5 * td111)
( \! v0 d4 @, {5 f, m7 W - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(270), tL111 - 2 * td111 - t_l111 - 1)
+ x% ~' @5 Q9 k - ltp111(0) = varet111(0)7 O) Z5 f& K2 [& g F
- ltp111(1) = varet111(1)
& F* S2 s; v( p - ltp111(2) = varet111(2)
$ }0 @" }* Y9 I8 ~% d' ^ - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(270), 2 * td111 - 1)
% x+ i6 z* N* B - pointws111(0) = varet111(0)
|3 R+ x% I L7 H1 p - pointws111(1) = varet111(1)' P( J: [9 t& j1 h4 ^5 o
- pointws111(12) = varet111(0)8 O6 c( j! [( t4 y3 @
- pointws111(13) = varet111(1)
, y& V1 ^4 e7 s3 ]: V! F( ] - tp111(0) = varet111(0)1 r$ y- `, k. f- Y, k7 { K& V
- tp111(1) = varet111(1)5 g* d% P6 @) l2 \
- tp111(2) = varet111(2)
; y" a* k% J1 `; ]2 W - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(210), 2 * 1)' z5 r6 l1 A _0 Q
- pointws111(2) = varet111(0)' y# f1 N0 {1 b0 n2 O
- pointws111(3) = varet111(1)' h, j3 a& u- t% I/ Q" n# s* e" U7 A
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(180), td1_111)- O# ^0 Z1 e8 [; X* t6 j: \+ m
- pointws111(4) = varet111(0)2 N0 w, n, P" v. ]
- pointws111(5) = varet111(1)0 N& X1 h( g! E" |- O2 B
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(150), 2 * 1) A0 i5 m! v# C7 V
- pointws111(6) = varet111(0)
7 ^4 I6 }: K* @8 p - pointws111(7) = varet111(1)
- S5 N1 V0 I1 u - bp111(0) = varet111(0)
, a- g4 C( X; h: p/ ? - bp111(1) = varet111(1)5 n+ o7 r7 i V
- bp111(2) = varet111(2)+ Z8 U( y; X6 a
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(90), 2 * td111 - 2 * 1)1 E" Z9 g# ^) U
- lbp111(0) = varet111(0)
- D7 j5 k/ D" J/ @; o - lbp111(1) = varet111(1)
3 {# ?* F& }7 s9 C: W7 \ - lbp111(2) = varet111(2)
7 g5 c; M7 J: U. n$ v, X - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(90), tL111 - t_l111 - 2 * 1 - 2 * td111)
% t2 ^! @1 n: P U# l' e2 r - pointws111(8) = varet111(0): u7 |* @$ L2 e- `. e
- pointws111(9) = varet111(1)5 S6 H' W" U% ]. e ]
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(0), td111)
$ S3 O5 |4 V0 y) a9 j1 h - pointws111(10) = varet111(0)
% p- L' c8 G, B* K0 u! q1 V - pointws111(11) = varet111(1)
" d/ c% w% @7 @; o; f - Set pline111 = ThisDrawing.ModelSpace.AddLightWeightPolyline(pointws111)( R" r Z4 j ]
- Set lineobj111 = ThisDrawing.ModelSpace.AddLine(tp111, bp111). @6 n. K$ r! N4 ]1 v: ^9 N+ ?* W
- Set lineobj111 = ThisDrawing.ModelSpace.AddLine(ltp111, lbp111)
1 k- F# c5 ?6 n% i/ G5 q9 P - varet111 = ThisDrawing.Utility.PolarPoint(ltp111, dtr111(180), 0.1 * td111)
1 z4 L2 \4 q) L0 s9 H - lwlsp111(0) = varet111(0)
6 I/ y& q8 Q" | - lwlsp111(1) = varet111(1)
" c! g' S+ [5 _3 o8 x - lwlsp111(2) = varet111(2)+ M" V$ S1 ~! B$ t5 n4 Y
- varet111 = ThisDrawing.Utility.PolarPoint(lbp111, dtr111(0), 0.1 * td111)
5 d) A# N' N W% X( M" K7 q - lwlxp111(0) = varet111(0)
: S2 U5 d7 l* T# o1 c* l ` - lwlxp111(1) = varet111(1)
1 t+ Q& f1 g) Z1 L - lwlxp111(2) = varet111(2)
7 G( O9 J8 p P4 i - varet111 = ThisDrawing.Utility.PolarPoint(lwlsp111, dtr111(270), 2 * td111)3 t0 R* v, x( r0 ~% i* b# @% n
- lwrsp111(0) = varet111(0)
7 y' f8 V: \+ d" S7 v4 N" g. G - lwrsp111(1) = varet111(1)
; d. d7 U8 u7 w5 ^" D% i, b- u - lwrsp111(2) = varet111(2)
* B2 _. a m$ _& H5 G$ ^ - varet111 = ThisDrawing.Utility.PolarPoint(lwlxp111, dtr111(270), 2 * td111)7 m9 B( P& m! j2 B: f/ Z
- lwrxp111(0) = varet111(0)
7 W7 Q! {7 _& R* M' \1 |! j - lwrxp111(1) = varet111(1)7 N$ a: b/ Q; i
- lwrxp111(2) = varet111(2)4 c+ f: z6 B: Z6 Q& _9 \4 w9 H
- Set lineobj111 = ThisDrawing.ModelSpace.AddLine(lwlsp111, lwrsp111)
I% S( J6 r: i: N. F - Set lineobj111 = ThisDrawing.ModelSpace.AddLine(lwlxp111, lwrxp111)
, d, ?5 z1 ^& E1 V - varet111 = ThisDrawing.Utility.PolarPoint(insp111, dtr111(270), tL111 - t_l111)' ^+ x5 R h9 ?6 |% x4 ^; B9 D0 Q# |6 O
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(0), 0.5 * td1_111)2 q: X* L, u1 x2 Y
- pointsmid111(0) = varet111(0)/ Z0 J, C+ E" F9 K
- pointsmid111(1) = varet111(1)5 J; I. D+ z. S A9 r
- pointsmid111(8) = varet111(0)
# ? q; `% \3 M) N - pointsmid111(9) = varet111(1)
2 ^% j3 ^, U$ W; E2 E2 h4 R - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(270), t_l111 - distance111)8 I2 D* K) A& I! M1 W; J: f
- pointsmid111(2) = varet111(0)' {& B, ^+ S+ S/ ?
- pointsmid111(3) = varet111(1)
) p$ r, s E/ u" z - edarc111(0) = varet111(0)& K; ^" L( G) q6 X# B1 ]: [
- edarc111(1) = varet111(1)
0 f. w( ~9 s" x - edarc111(2) = varet111(2)
1 R' G9 e+ K' o. {8 T7 a0 ^ - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(180), td1_111)1 f* o6 u- ?% g* P+ g) ]
- pointsmid111(4) = varet111(0)
: ]4 o3 g" r9 l - pointsmid111(5) = varet111(1)& _/ r! U6 w' h% g
- starc111(0) = varet111(0)
& {6 ~/ A% M7 g- [- ^ - starc111(1) = varet111(1)' D/ `. A0 j0 d5 [$ V: a4 Q
- starc111(2) = varet111(2)
$ W' J9 z1 @, o" P& m0 `9 K - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(90), t_l111 - distance111)
3 u1 ~. l- g0 k( ? e; i; O2 A - pointsmid111(6) = varet111(0)
* ^! q9 q5 P7 Q - pointsmid111(7) = varet111(1)- R! N; }: c. R! p5 ~: K
- Set pline111 = ThisDrawing.ModelSpace.AddLightWeightPolyline(pointsmid111)& k: s) f$ d2 b$ R
- varet111 = ThisDrawing.Utility.PolarPoint(insp111, dtr111(270), tL111)% o. {2 p) p" ]! F+ T/ j
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(90), tr1_111)
0 a/ d9 `1 u! \# o1 p4 I7 e - ctp111(0) = varet111(0)* u. @# D0 k, E- P# a
- ctp111(1) = varet111(1)
4 F0 ?' ]7 P0 Z" P& E* U - ctp111(2) = varet111(2)
( H' F8 D8 }3 c3 E: s - startangle1_111 = dtr111(180 + yuanjiao1_111)
3 c% F7 K; I1 |: i - endangle1_111 = dtr111(360 - yuanjiao1_111)
' o. j- x- `% c3 e0 m - Set arcobj111 = ThisDrawing.ModelSpace.AddArc(ctp111, tr1_111, startangle1_111, endangle1_111), b& n. h( p; B
- Set currlinetype111 = ThisDrawing.ActiveLinetype/ l8 w2 S" k) N2 C
- Dim linetypename111 As String* J6 n5 O! ~6 R9 N
- linetypename111 = "CENTER". x4 t- v9 y( Y1 r3 U: D
- ThisDrawing.ActiveLinetype = ThisDrawing.Linetypes.Item("CENTER" ), f# N$ C5 A# _, I7 f6 D, b
- If Err.Number = -2145386476 Then0 L) u [& V$ x) k! `: j! }
- ThisDrawing.Linetypes.Load linetypename111, "acad.lin") L% G8 B5 X; k
- ThisDrawing.ActiveLinetype = ThisDrawing.Linetypes.Item("CENTER" )& `2 [2 |. _' u. v( I* S: O
- End If
9 r+ k7 ?# P; ]4 ?% V5 s! R4 g - varet111 = ThisDrawing.Utility.PolarPoint(insp111, dtr111(90), tH_111 + 2)
7 E3 D( \# d) F7 w0 m/ _! u; N" z$ P - centersp111(0) = varet111(0)
5 E* ?( E& l& u1 v - centersp111(1) = varet111(1)0 i) s2 D6 y, C1 P4 M* C
- centersp111(2) = varet111(2)% d4 U0 o/ I& H8 |' B4 E
- varet111 = ThisDrawing.Utility.PolarPoint(insp111, dtr111(270), tL111 + 3)( c2 }" V" k/ |. ^
- centerep111(0) = varet111(0)) O* k3 l3 I1 T( e G. F3 O( }; C
- centerep111(1) = varet111(1)" d( s$ W3 L) J* ?/ |1 ?- X7 L# j
- centerep111(2) = varet111(2) D A/ `# Y/ K Y4 X
- Set lineobj111 = ThisDrawing.ModelSpace.AddLine(centersp111, centerep111)
9 Z$ N' r) o7 Q0 ~+ e1 p - ThisDrawing.ActiveLinetype = currlinetype111
; ?6 K* D+ `! L - Dim linetype111 As String
1 G7 B( r1 }6 s5 S: A# ~ - linetype111 = "ISO dash"- @* U' `6 h5 x X0 f
- ThisDrawing.ActiveLinetype = ThisDrawing.Linetypes.Item("ISO dash" )/ s4 ~) w/ q0 H3 r$ ~7 O
- If Err.Number = -2145386476 Then# v# D K) r6 L4 [" t
- ThisDrawing.Linetypes.Load linetype111, "acad.lin"7 _1 D% W8 q; j5 m1 {
- ThisDrawing.ActiveLinetype = ThisDrawing.Linetypes.Item("ISO dash" ) M& k, h! i/ J* F' E) m
- End If) a9 T$ ^2 s1 ~4 J6 I# Y* t
- varet111 = ThisDrawing.Utility.PolarPoint(insp111, dtr111(0), 0.5 * t_D111)5 l: A: x3 K5 e2 r( U. f
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(90), 0.5 * tH_111 - 0.5 * td3_111 - 0.1 * td111)# s& ]+ |, c8 W; r
- dashst111(0) = varet111(0)
8 g: f. h$ t% ]) H& c) q) d: A1 x - dashst111(1) = varet111(1)
% w ?9 P. w) M4 p7 h& t* Y - dashst111(2) = varet111(2)
3 j2 Y) u3 ^, G6 d W - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(180), t_D111)
1 E/ X5 Y8 |6 D - dashed111(0) = varet111(0)
8 G7 c- e9 A4 x - dashed111(1) = varet111(1)) y& X2 t6 B9 P9 u, G3 o% C
- dashed111(2) = varet111(2)
: x; A5 p6 v/ v5 E2 o; `% Y8 i - varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(90), td3_111)
M( ?7 k/ l" w* h7 t9 z3 s3 \ - ndashst111(0) = varet111(0)
( I1 c) W4 R( W S - ndashst111(1) = varet111(1)- P& m: e+ t! j; |/ e2 i$ J- f6 W
- ndashst111(2) = varet111(2); r' n3 n6 s$ |+ @" ^5 ~3 F' C# n
- varet111 = ThisDrawing.Utility.PolarPoint(varet111, dtr111(0), t_D111)
" I0 [; d- u2 t+ R$ l# X9 g - ndashed111(0) = varet111(0)* K- v8 H& s p& M
- ndashed111(1) = varet111(1)4 u7 Q4 A7 a' S, g6 g) m
- ndashed111(2) = varet111(2)
. q; W4 g7 t, w/ r - Set lineobj111 = ThisDrawing.ModelSpace.AddLine(dashst111, dashed111)
& t: ]; Q2 x: ~% ] - Set lineobj111 = ThisDrawing.ModelSpace.AddLine(ndashst111, ndashed111)$ v4 w! O# U6 Y! |5 F
1 m. V8 U$ U6 c |0 X/ b - End Sub+ z- R4 g9 B8 H3 w
- Sub luoding111(): m& O: a. J# N p8 G
- Dim sblip As Variant
3 n& S3 z/ M* U* U5 _# M0 e - Dim scmde As Variant
1 d- }) T. [8 u - win111
& h- W! g& R3 o u3 C+ k$ W - aJBT111( M: V6 H4 e8 |% O! i6 T% W
- sblip = ThisDrawing.GetVariable("blipmode" )$ @+ t7 u% @+ E* _+ h1 a
- scmde = ThisDrawing.GetVariable("cmdecho" )
8 \( D L- N1 I9 v3 ~ - ThisDrawing.SetVariable "blipmode", 0- h: W3 |: Z$ u
- ThisDrawing.SetVariable "cmdecho", 02 M* h$ O2 l4 M
- drawout111) e9 S# a: j; I) ?' B
- ThisDrawing.SetVariable "blipmode", sblip
, p3 ^; c5 o3 v7 b - ThisDrawing.SetVariable "cmdecho", scmde
3 o$ r8 I1 h) r& \* ~ - End Sub7 n% \1 q, f5 n9 U8 B, q
复制代码 求高人指教,拜托了~~~ |
