查看: 4316|回复: 7
[分享] Solid Edge ST3发布补丁MP6
发表于 2011-6-18 18:45:05 | 显示全部楼层 |阅读模式 来自: 中国浙江丽水
3 T6 p( ]/ Q' P" n# g# w$ T4 ^, s1 ~: n+ A7 {: q
Dear Solid Edge Customer:
6 ~4 H3 X1 p$ s. O* k, d
We are pleased to inform you that Maintenance Pack 6 (MP6) for Solid Edge ST3 is now available for download on the GTAC FTP server.
0 L& ~5 S- i) j( J- e7 y/ q* s
This Maintenance Pack addresses issues reported by Solid Edge customers. We appreciate your participation in the software support process - - your reporting helps us make Solid Edge more productive for the way you do business.
& W! f: k) W* E5 Z
Sincerely,
+ [7 a8 X) _* U! e, k
The Solid Edge Team
/ K8 g* A' f3 C2 {
3 s* Y4 @: W1 y, ?6 a' t% T3 f& v
Download Location:
# {! f5 N" k- L" _* y
1 N( _% J% q5 a
Solid Edge (Maintenance Pack)
8 ^; r* b' o/ B. ~, Q! F% k, O3 D% i" D; ]  w
Solid Edge Insight Connect (Maintenance Pack)
; D6 j0 r( X; [) q$ x: p' f* Y& j: `. N" j2 J8 M% H( [! B; v' g) ^
Solid Edge Viewer (Maintenance Pack)
0 S1 Z3 H1 W9 J' x9 |
/ N+ q4 @$ Q9 m$ y. |/ S7 l+ X+ E
Solid Edge Mold Tooling (Maintenance Pack)
; I$ z4 G9 K$ Z8 r' ?8 v
: t) V2 O: t$ {! ?
Solid Edge Insight Server WSS 3.0 (Maintenance Pack)
, Q# @0 v- }1 A9 Z
7 @( o$ c6 p1 s& |; N
Solid Edge Insight Server SharePoint Foundation 2010 (Maintenance Pack)* D" x( i8 t# @$ n. Z
http://ftp.ugs.com/solid_edge/ST3/InsightServerSharePointFoundation2010/
/ r7 n( ~' Y8 d/ C( V6 X. z
Solid Edge Embedded Client (Maintenance Pack)
( J7 w" {3 h. B) j
" [, T, m5 q/ X0 v
Solid Edge Embedded Client Structure Editor (Maintenance Pack)
. n7 C! y8 \; ]) D- t; G' U- b2 U/ d( ?
6 e8 l6 A1 I; J, l' h
Solid Edge Embedded Client Administrator (full install)
5 P5 O" [1 ^" k9 K5 i. h+ u/ q1 b7 G: p. E& t/ @! p
$ D2 p& A5 N/ y: B: ]  {9 k
Installation:
; N' }3 S6 x8 v
1 L8 I( t2 a  g4 h# v
After downloading the Maintenance Pack to your machine, unbundle the zip file and then dbl click on exe to install the Maintenance Pack.
7 k9 @) j* u& ], F* Z# A+ R
Windows 7 Installation tips: In addition to turning off UAC, right click on the exe and select "run as administrator" to complete the installation.
2 ^4 |9 n- P1 l8 D, V
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing Solid Edge somewhere other than the default “Program Files” folder. Install in a location like c:\SolidEdge\ that the user has full permission to write to.
  d  W  Z( [$ W3 J+ b# x9 P
( H# C- A7 E2 G
E-mail Notification:
, ]2 C3 z8 F( Y
5 \- |$ J) d, o
To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe to the SFBmail notification. To initiate your subscription, navigate to: http://support.ugs.com/general/email.shtml for the web interface. Or send an e-mail message (message and subject line should be blank) to: sfbmail-subscribe@ugs.com
4 j* P) w# B. i5 \( h
" a" x. q& y3 {* Z
This Maintenance Pack addresses the following PRs:
8 p$ z+ g9 j; X1 W5 L8 z+ u, X: Z
7 N( E" ~; R  B; ?( }) C- M9 n
===API===
. X& n  v* }; E6 \& z( ^
PR 6525375: BalloonDisplayedText showing symbols instead of display values
) c% }- @7 v. E4 |0 a
PR 1845612: API method SeekWriteAccess doesn't work properly in ST3
. `# d/ m2 M+ n
===Assembly===
0 d4 _8 S$ J% I8 h* I" ]4 q
PR 1819823: Cannot import STEP files
4 N* I& [) l6 V! }4 S  U- K
PR 6482973: Assembly relation tree in ST3 obscuring selected parts
# l  j# g: @* l! e6 }& Q
PR 6524547: SESysInfo reporting negative memory value for graphic cards w/2GB or more onboard memory
  W" t- N1 l' M$ J+ f5 r# E
PR 6530354: crash after editing connect relation
1 @- L1 {3 Z; y5 x( Z8 j8 E7 c
PR 6530975: Check interference doesn't consider weld features when selecting subassembly
) G3 D  P/ c! |+ G$ e# y8 N
PR 6532294: Relation Tree not showing document icon
( l  r4 v# n* @) ]: ]
PR 1822686: JT file will open in Traditional but will not open in Synchronous
) G: ~# W: ]& u* M, q" ]' d/ `- O
PR 1828686: Missing parent for sketches in an assembly are not reported
: t9 b6 D, V  ~% k6 o
PR 6425708: Reference plane not hidden after exit of Assemble command
: \* K3 Y5 k( g# C
PR 6468554: Missing files after import of a X_T file
" b  o2 D/ `5 r$ C1 x! O
PR 6489805: When using Publish Virtual/Publish SE aborts
: ^0 A! v1 f  H
PR 6533309: Abort when adding assembly relationships
# u& y! ^2 D3 z) E2 I
PR 6534186: Rotating an assembly causes assigned textures to change color during rotation
2 w$ N& L! _- C. n1 p: ]
PR 1828736: Long beam is not cut to C channel profile (frame module)
0 b, a0 ]2 d) \* j& ?! a0 ]
PR 1845357: seCatiaV5.exe crashes
$ L; ?" [9 A4 C* z* G! ?6 z0 X
PR 1849144: Unable to finish tube placement on German OS
8 S9 a4 }! |2 n- c5 u4 O3 v+ @
PR 6443468: Batch translators are not generating output
/ V: X9 A  y' }( p% a& j; q# d: k0 b
PR 6484486: Cannot export Solid Edge files to STEP
! D4 |& e& N1 k3 R5 C  @6 i, n
PR 6534753: Application Display settings will now properly detect the new Intel HD Onboard driver
+ R% ]+ P* O3 l; @( O$ Y3 Z4 S
PR 2169599: A fully constrained assembly becomes under-defined on flipping to rigid from adjustable
2 _% z8 r) D/ H0 l+ ?( a, |
PR 6471511: Unable to Translate Inventor Assemblies with Data Migration tool
/ M3 Z/ i6 Q/ f. D0 Y4 B
PR 6535868: List Control tab options are enabled with 'use assembly item numbers' is on
/ {9 U% [- i9 s
PR 6541886: Crash at: OccurrenceNode::GetSite
3 W2 p6 H7 P+ m/ ?0 m
PR 6550314: Crash when activating assembly parts via the pathfinder
2 j* g, c% a' S: n* K! r. H
===Draft===
  M9 e6 Q4 b2 Y
PR 1844982: "check config" on drawing view properties was not working
3 H- K; d1 u. o( n6 j0 L4 `8 k
PR 1846422: Parts list quantity is incorrect when using assembly item numbers
7 U3 a' E9 E5 r( h0 l4 |
PR 6458478: SE crash occurred while inserting image in draft document (Workflow specific)
- i. q0 T! H1 K
PR 6484441: Reference dimensions have extra brackets when exported
% b8 m. ]- X* T1 f! J$ g# a# M
PR 6531106: Fixed crash identified by crashlog at: HGetQuantityOverrideFromOccurrence
/ G' E/ {# x  d2 G4 h) ?; X. w( ^
PR 1819327: dxf_Export is not including some crosshatching
* ^* ]; [% G6 n( ~' I
PR 1822869: rotating the contents of a draft file causes Solid Edge to crash
( y' x& J) c: ~+ U, K8 G# e
PR 1823915: Cutting plane lines are missing in exported AutoCAD DWG file
( s" ~' G- J# Y" i3 }& d
PR 1830725: Parts list has an asterisk next to the item number
0 k4 [! q# d( S6 L- H6 u
PR 1833156: the drawing view "show fill" option not honored
1 ^( d3 u! o& v  X- W7 V0 N
PR 1836348: It's necessary to click twice on Break Line option in the Callout command bar
) W$ D$ h2 p% D" S1 z$ w& o
PR 1843290: Symbols not placing correctly when Inserted as Geometry
( @' \8 X& b8 C
PR 1847031: Geometry in a 2D Model view cannot be moved/copied, huge file size
. @2 Z3 P' K0 j$ k% A4 h% K8 H. C8 j  ~
PR 2165599: Can't maintain separate grid settings when two draft documents are open
( Z- K; t6 ]1 `! t! T! s* a; {# [
PR 2165638: Existing Solid Edge draft template issue in windows 7
) a& f5 ]0 L7 e3 L2 q
PR 2166696: Dimension tracker copy to clipboard is not working
- e& l$ `2 x4 h% H* k+ S
PR 2168599: View not being refreshed after activating hidden layer
9 {9 y: y; _2 h" u
PR 6419394: Opening of 2000/2002 DWG file does translate any geometry
+ @9 \* a; h5 A% {6 b
PR 6438019: Trim Corner selection is picking the wrong line
) [* ?8 O8 x0 C( h  O. Y
PR 6487857: DV tracker update instructions were incorrect for part copy
- {( a3 P! l9 r% c- K* E8 ?
PR 6529930: Detail View Caption can't be moved correctly if envelope is an ellipse
6 l! [+ M$ n4 r9 g! `( H3 P' z( `
PR 1826475: Selection mode remains active after balloon number change
% a" R, G7 h$ \" l# N2 X
PR 1817696: Embedded Objects are exported to DXF in the wrong position
8 k% ^7 Z! H( V) q# M# H
PR 1824327: Fill Text with Background color rectangle position incorrect
9 P+ _: R4 i" q0 I) z
PR 1832830: Seacad "template file" is empty if you don't go through seacad option steps
$ o( ^. C/ v8 z& g; ]8 u
PR 1833975: Attempting to open a dgn file aborts if the look in button is selected
# Y# H/ S3 V. g. S' |+ {$ L
PR 1840830: DV caption is exported to layer "0"
/ ]4 d) b9 m3 x6 x/ K0 y8 R
PR 1842175: Cutting plane line cannot be selected with "Active Layer Only" option
! `. Y, t) ?% [$ Y: F
PR 1847435: Tab key function for upper and lower Tolerance needs to be sequential
1 p) J3 @9 k& W! s7 Q7 w! U3 m
PR 2167888: Right Justified callout text is scrambled in .dwg
2 Q$ D. j8 ~$ S' i; `, c4 ?
PR 2169063: Starting location of offset thread not displayed with solid line
' [8 f/ z  [& K
PR 6511394: Prefix copier doesn't copy the tolerance type correctly for Class tolerance
+ V5 d/ ^/ s7 z8 N! G
PR 6535524: Parts list does not honor property text formatting codes
* c0 V: i, z- J
PR 6536661: Parts list reverses order each update if renumber and sort by item descending
  _4 |' ?  k: l
PR 1684703: Sketch in a section view was not sectioned properly
' ]+ q5 ?) \0 `/ M: j: D
PR 1823726: Text placed in rotated drawing views is lost after SEtoAcad translation
; e6 J  E. R# b+ G* E- e3 [7 |" f
PR 6541869: Crash at: JDimChainAngular:isconnect
! |5 j  Z5 X# p! G, S
===Insight/View & Markup===
& k! ^1 P! H5 Z& q' g# e0 y
PR 1842460: Cache Manager does not work
- _4 O1 b, b9 _4 g
PR 1846854: Assembly doesn't open - No error message
  {- U- t6 O7 P; h
PR 6461727: Search not finding Custom Properties
9 `; `2 U1 q! E( T3 t
PR 6332833: Insight Web parts: The Viewer MP's are not getting pushed to IE clients.
; {" F, U* F) V3 d
PR 6399126: Insight connect crash occurred while saving PCF file (Workflow specific)
$ ?# a, k$ a  ]: ?
PR 1845749: Calculated Columns will not sync anymore
4 ~- W& h7 \& {. _8 P: [% r8 M- v6 p
PR 1835210: MP info not shown in View & Markup/Help About on 64bit computers
0 Y1 H8 ~6 D9 R$ `# J9 R, X* j! H
PR 1835727: Incorrect characters in SEWebParts on Insight MP3
& n$ d. F/ a2 ~
PR 1840719: Error Message when copying Excel Docs within a Asm Structure in RevMan
  V( Q$ u* [, R% w4 K% D+ `
6 k" k. Y: D6 s; J( y& i
===Part/Profile/Sheet Metal===
+ Y& ^' {! k, a- m
PR 1783293: File open dialog is slow to show large folders
1 e9 A( O0 s- ?5 t% L' R2 [' h
PR 1844377: PartCopy from an assy will only work if the assembly is also opened
1 A, V0 W& c! B5 b
PR 6522205: Abort at JUnitsOfMeasure::~JUnitsOfMeasure
, @/ Y4 V  e) t& m6 i/ n
PR 6524170: tangent relate failing when the elements did not share an edge
* x  h/ u0 C5 G: [
PR 1823155: changing the value of a round using all available memory which results in a crash
' A3 n( j8 y1 H9 @3 B" q
PR 1843475: Flat pattern from mirror is different from original
0 k; D5 }% c2 P# ^: d: q2 R
PR 1845013: Hole Feature will not cut through the part
& r' P0 M+ }* U( d+ e) n# V
PR 1842597: Ribbon bar added by custom add-in is not customizable
3 X4 _2 F: ~% @; ^+ p7 w* N( K
PR 6534273: Sync threaded hole problem when using saved settings
  w, t/ _; ~; F  ?; _9 r
PR 1847811: Ctrl+A (select all) in Profile environment also deletes synchronous body
9 k# F; S, J- R2 a" f, E* |
PR 2170648: Selecting User-Defined Sets causes an abort
' R5 S# M" U7 I) O! V9 z
PR 6441781: Binder names not all converted to Unicode, yielding garbled display
5 W# a6 X5 V! A" I
PR 6522975: Crash when performing an undo of a move to sync
3 _0 f6 ]) ]5 `( f& s( N( m
PR 6532739: Crash at: JMostRecentFiles::Add is at top of the stack trace
  c  E! ?0 G, \6 s# k- e
PR 6537877: Sync Pattern does not create all occurrences
6 R3 I$ ?0 s& B
===Solid Edge Embedded Client===
" W! @& Z( i5 f' F5 a% `: `
PR 1800213: Smart Codes form is locking up when saving a new file
: U9 l4 k, P8 m0 _. x
PR 1834093: Wrong dataset name is used in ST2
. i0 H8 t3 t( e( E9 k' L2 C
PR 1837961: Automatic update of linked NX part does not work correctly
! a% W- ?4 m' r! [$ X$ \
PR 1838542: Revise non-default dataset names are renamed to default.
9 j4 D1 u& _9 d% Q; |
PR 6528853: Couple issues with assemblies and missing components in SE & replace part
9 ^5 t+ c5 S+ Q7 g1 J% T7 B2 J
PR 6495119: SaveAs of a FOP master and select no to copy links copies the links anyway
/ @( Z' [; g" C# Q
PR 1844966: Time to drag and drop & open from the Edgebar takes too long
3 P! {; @% e0 v4 \# i
PR 1845018: SEEC Create in Place does not show default values of mapped properties in CPD
' _8 e5 ^, Q) T+ f: |* D3 r
PR 6482635: Unable to Save As FOP member in Structure Editor
' U- X8 A  m& N) K! [- L
PR 6484834: CPD is not renaming the Item Revision properly for the Dataset Name
* F1 Q5 [& C5 [; A/ N, k6 D; u
PR 6448444: Structure Editor is not displaying assigned LOV when creating New
0 P1 K4 ^9 i& v, q
PR 6530136: AddToTeamcenter is clearing Document Number value during Dry Run
: }9 n6 Y+ z% t4 l
9 _( n/ ?, m, L, o
PR 1847283: NULL Attribute Values not honored
7 F# b/ I) g; _) q/ |
PR 6492500: Save As behavior in SEEC behaves differently to Save As behavior in SESE
 楼主| 发表于 2011-6-18 19:05:03 | 显示全部楼层 来自: 中国浙江丽水
玩一下神秘。想看下载地址? 方法如下:
3 H8 N% W% m+ Q; D
! U. v0 ^# F8 w5 I9 q, P+ L7 \8 L
7 c7 ]  x% I) q& C. g. t% s, t9 F
: ]* J/ C5 f* W7 s, A2 r; Y8 a按键盘Ctrl+A
发表于 2011-6-18 19:40:35 | 显示全部楼层 来自: 中国北京
楼主玩花活,不方便啊
发表于 2011-6-18 23:45:15 | 显示全部楼层 来自: 中国江苏常州
说是要帐号和密码的...
发表于 2011-6-23 08:18:04 | 显示全部楼层 来自: 中国香港
115网盘下载:+ d: t; T7 L, C7 p# H: ?, x
9 X# }- s0 z8 X+ }0 mhttp://u.115.com/file/dns25xdl#
( L2 U* ]2 n9 q% {3 h* x3 [( M( xSE32MP6.exe* s% t. T+ W  K( c
4 L0 h$ G+ M" z2 _" X
http://u.115.com/file/clvmxu6a#
( S4 j* t1 T- oSE64MP6.exe
发表于 2011-6-23 19:53:19 | 显示全部楼层 来自: 中国陕西西安
115网盘下载:
: T! W7 ?6 k; E8 O0 q
% S8 }$ g! L9 z3 j9 C* i. Ihttp://u.115.com/file/dns25xdl#
4 A( g& \* h6 u3 o( h" |SE32MP6.exe
' F/ \& L, F# x7 Q( K* W  r
8 F7 ?4 [0 {: p% \) C# _http://u.115.com/file/clvmxu6a#0 q0 q1 E$ ?# M; j% ]0 J6 m- ?3 R/ r
SE64MP6.exe" f9 l" ^2 H/ Q2 g9 J) U: S
wxxwjl 发表于 2011-6-23 08:18 http://www.3dportal.cn/discuz/images/common/back.gif
谢…………………………………………
 楼主| 发表于 2011-6-23 21:38:14 | 显示全部楼层 来自: 中国浙江丽水
哈哈。把俺的网盘贴出来了。
发表于 2011-6-24 17:00:36 | 显示全部楼层 来自: 中国广东广州
谢谢楼上诸位,辛苦了。
