发表于 2011-7-5 09:47:17
来自: 中国广东深圳
应该是不一样的。
# ~& p, m4 y+ M8 W" D2 {2 W# U* B5 g* ?7 w' |- Q
+ z7 w4 r4 B4 n: h) |( G4 Z4 t5 d, gGM GM7111M Corrosion Protective Coatings Phosphate/Zinc/Organic Type( W$ Y8 a) v+ y
http://wenku.baidu.com/view/a782126a561252d380eb6e6e.html1 T; }4 \3 T( q8 |, |( O
盐雾试验240h
; X6 v1 A+ t H' PGMW-3179 Zinc Phosphate & Oil (Code “A” & Code “G”)5 @# u# h' n( B( D( r
盐雾试验24-72h/ `# w2 v- m4 j+ j% p3 m6 H1 U- i+ P/ q
GM GM7112M Corrosion Protective Coatings Phosphate/Black Zinc Organic
/ H7 a/ U# E; G, P% ~ g: gType0 l' E+ q$ ?$ ~& z
GM GM7113M Corrosion Protective Coatings Zinc/Organic Type( U! E8 f7 [8 T7 K
GM GM7114M Corrosion Protective Coatings Phosphate/Zinc/Organic Type: h6 Y1 ~& m- E! J& l3 z( b; k4 [
% v% y4 m1 Q' j0 {GM-4435M Zinc Phosphate & Oil
. j, ?: ]0 J) A& s& D, Z" L) ]% z$ K. i盐雾试验72h |
