! z) g: Y9 @1 R
6 S5 _& |4 h- [9 b用VBa做了个简单的小程序,居然提示“无效的过程调用或参数”5 |1 a* G+ W1 r
程序:) _0 J4 I1 T1 N7 Q& k" \: C A5 o
- Public Sub HTT()
, W3 y' S- L$ |4 Q: ]8 H) E - Dim Pt0, PT00 As Variant- C; u" r2 m) `" e8 ^7 v
- Dim PT1(0 To 2), PT2(0 To 2), PT3(0 To 2) As Double
0 b- V- W- C' T+ k2 g8 W; L. r# ` - Dim L0, L1 As Double
& l3 G- g1 G' e& N - Dim i, m, n As Integer9 u) o! X7 \" b/ w
- Dim ALine As AcadLine/ c$ l/ f) ?8 {6 y7 `- u; J9 O/ f% O
- Pt0 = ThisDrawing.Utility.GetPoint(, "基点:")
6 P9 ?0 P! Z! t: A - X1 = Pt0(0)2 Y1 l6 C2 a. l5 s! z, g
- Y1 = Pt0(1)2 I4 ]. }2 I' Y* V# O% ?
- L0 = ThisDrawing.Utility.GetDistance(, "单节筒节宽度:"); c7 G3 t S) H8 c
- L1 = ThisDrawing.Utility.GetDistance(, "筒节直径:"), z+ F+ q7 l @# F( j
- PT1(0) = Pt0(0) + L1
9 ^ u- S- U; R - PT1(1) = Pt0(1)5 Z D% O2 H6 q* k
- PT1(2) = Pt0(2)9 }5 I7 }/ c0 W7 T' `
- PT2(0) = Pt0(0) + L1
# B" w$ t7 j% r+ ]! L - PT2(1) = Pt0(1) - l2
8 N6 ] D# R8 q, v6 y - PT2(2) = Pt0(2)% @; S- v. H% j# J/ d
- PT3(0) = Pt0(0). E& ^9 G! @5 W& Z9 j5 Y6 z
- PT3(1) = Pt0(1) - l2
3 ?: [( Q! t& J' K* E - PT3(2) = Pt0(2), W5 I' g4 C; S
- 8 v5 r; D: `; ]" U2 Z3 D& J( V% p
- Set ALine = ThisDrawing.ModelSpace.AddLine(Pt0, PT1)1 S. b5 T! O n* V
- Set ALine = ThisDrawing.ModelSpace.AddLine(PT1, PT2)' p! h/ y5 ]* \7 u
- Set ALine = ThisDrawing.ModelSpace.AddLine(PT2, PT3)9 T/ J, `6 ^# z; L" c8 y3 P
- Set ALine = ThisDrawing.ModelSpace.AddLine(PT3, Pt0), v, {. T4 W' ^% u+ Q
- ZoomAll
% z4 A1 J, m0 {4 d. C" S - End Sub
复制代码 / M3 {+ ?0 ]+ e" H4 e
错误提示:
/ N; L2 n0 B7 E( n7 \
5 m) f; y) v0 R7 X
有知道如何解决的吗? |
