发表于 2011-8-24 20:19:13
来自: 中国黑龙江齐齐哈尔
本帖最后由 wfgwfgwfg 于 2011-8-24 20:21 编辑 2 }7 \2 a; ?' I) w. f$ V8 ]3 _% q
2 R# b* T" x- J$ w9 d5 _; kThis crack activates SW2010 32bit & 64bit and SW2011 32bit & 64bit to SolidWorks Premium Edition
2 _! i: L4 ~( oHow it works: after every reboot of computer and start SW crack checks if activation has expired or not and reactivate SW if needed automatically! r% T: \9 }0 e* r8 N
1. SW installation
+ t' d# s8 o" `ATTENTION!% d' u. R% W( ^# l2 d- N0 j3 Q( j2 K
Keep in mind that this crack needs original files of SW, so if you have got SW2010 cracked with previous SW2010 SSQ's cracks (with patched sldappu.dll & sldanimateu.dll for SW2010 32bit and patched sldutu.dll for SW2010 64bit) you need to restore original DLL's5 [+ `* c) ~6 P* \; q* M
If you did not save original files of SW2010 befor patching you need to reinstall you SW2010
$ G% j! f2 N4 u7 `/ vInstall SW2010-2011 32bit\64bit with any of this Serial Number) u, p* K3 k! B; v( f+ S4 y
0001 0001 0736 0361 JK3Q HDJ3 G5 I% m! @/ m
0101 0000 1289 1488 R4H5 Q5333 y) m, A# N# U) O
0000 0000 0000 3486 Q5HF FG987 o4 F5 H5 X+ V, \, [' H7 }) ?
. w3 F7 Q* O4 r Cyou can use any other valid LOCAL (not NETWORK) SW Serial too
: k" ^. S7 w3 O" b' A. eAt SW2010-2011 Setup DO NOT INPUT serials for SW Motion, SW Simulation or SW Flow Simulation!" W; {: s1 x! t, O% T8 Y
to be sure that there are no COSMOS serials in Windows Registry check Registry partitions
$ p1 _; J2 x- {$ f. N[HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\Licenses\Serial Numbers]
1 E. Y4 w9 X' z7 F* ?' A* A[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SolidWorks\Licenses\Serial Numbers]- x" {; r+ O3 j- m. `
and delete (if exist) strings like
7 u: s) R C' WCOSMOSMotion
2 s$ D; w- a# ^. \& N) O7 u$ b. R$ JCOSMOSWorks
. g" o3 f8 w6 ICOSMOSFloWorks* |1 d! s F5 D0 y2 T4 x$ _
2. Applying a crack: n( q( m4 A% Y, |# \. l
2.1. Copy folder "setup" from crack to SW2010 or\and SW2011 program directory and overwrite original one8 O9 |4 [ ?+ l5 n% `6 G
2.2. REBOOT you computer!& C* _( i8 |5 Y, h. j7 i6 q
2.3. Run SW. If all is OK activation wiil be proceeded automaticaly and SW start to work9 K* q# `( H( y" _! t/ I* _
If on some 64bit computes at SW start you will get a warning8 _% e3 Z7 z; `& L) M ~
" Error: Can not initialize library (%d, %d, %d)"
7 \0 _. f9 r/ }; C or' Z8 A9 \( P/ @+ _2 t0 T
" Error: Can not open handle (%d, %d, %d)"
( k+ \2 t8 t) f9 [0 lyou need to run <SW progdir>\setup\i386\x64_fix\ServiceInst.exe, REBOOT computer and start SW again
+ L2 n! ]4 e5 C- N7 m* t9 m
+ Y/ A4 f0 r/ ^6 }" n7 L P3. Remarks
1 W. E- g7 K; l, D% K3.1. If for some reasons you are changing System time of computer be sure to REBOOT computer befor next SW starting; M# C& a2 Q5 k$ S5 Z R7 v
3.2. If you will get a problems with automatic reactivation of SW after reboot you can do it manualy. To do this run2 b# z6 G+ R* \8 O/ m* K# j
' L7 D8 ~. r V) m<SW progdir>\setup\i386\swactwiz.exe$ u/ I6 M; y5 j( Y
or. z) h4 F8 v' l2 M5 U& J1 E. a
Start > All Programs > SolidWorks 2011 (2010) > SolidWorks Tools > SolidNetWork License Manager( `2 B6 L5 }! j. Q( y
3.2. If on some Vista/Win7 computers you will get problems with activation eDrawings 2011 32bit\64bit to Professional Edition you can use local crack for eDrawins2011.
, C: k6 v: O' X( f: Q( G' }; ]With this crack you can use eDrawings both as Stand Alone (without SW installation) and Embelled (with SW installation)
9 }# Z1 N5 k) n8 N2 vFor more infor see readme.txt in eDrawings2011 folder!
" ?1 x) i2 W9 r, U0 {6 w; b- q1 H; b+ c0 H+ y/ C4 b7 {
Team-SolidSQUAD (SSQ) |
