查看: 1985|回复: 3
[求助] 后处理问题 帮帮我谢谢
发表于 2011-9-5 21:41:13 | 显示全部楼层 |阅读模式 来自: 中国河南洛阳
请问 如何让每一句G02G02的程序前面都有G02G03$ t$ \" B- N3 H! B
9 c6 `/ T+ }! ^9 n# A
他自动简化,伺服读不出来。
* N" u- u4 E; ~- w+ y/ E: I
, [& p6 `( F! V6 R! m6 Y(补充 ,菲迪亚系统,必须要改啊,研究好多天了,痛苦啊)
 楼主| 发表于 2011-9-5 21:41:53 | 显示全部楼层 来自: 中国河南洛阳
是G02或者G03的程序,每一句都有G02或者G03
发表于 2011-9-7 20:01:31 | 显示全部楼层 来自: 中国江苏南京
编辑后处理:0 v' F& f/ F' c) J' a
9 F& V. f6 h& Z) S
查找到0 w. I" S2 V; Q. L% ^
4 \+ s' `1 A/ p6 j; f
prapidout       #Output to NC of linear movement - rapid
1 R9 k8 _9 y" j% P      pcan1, pbld, n, sgplane, `sgcode, sgabsinc, pccdia,7 b% [* m) }/ Y4 g$ {% s
        pxout, pyout, pzout, pcout, strcantext, scoolant, e
: d' a& y& V2 N
$ R, R8 `2 u% ?8 D' {  ?plinout         #Output to NC of linear movement - feed                    1 L2 V' f% f& r- t
      pcan1, pbld, n, sgfeed, sgplane, `sgcode, sgabsinc, pccdia,( j# m1 L8 s9 T$ G9 [$ b2 M8 }
        pxout, pyout, pzout, pcout, feed, strcantext, scoolant, e
; f  H3 v+ H& b2 f5 ~- f, }3 e( C: d& @9 i0 [2 x, e
pcirout         #Output to NC of circular interpolation
0 K# {. g% G0 `      pcan1, pbld, n, `sgfeed, sgplane, sgcode, sgabsinc, pccdia,
# A1 H7 n" ?, j4 a) _+ `        pxout, pyout, pzout, pcout, parc, feed, strcantext, scoolant, e   {# x7 G6 p9 [
0 Z$ b; U; A- C
6 x; b5 [* j6 l# N
改为:
+ V/ T0 @% f0 j! {5 N7 U/ m9 F7 ~: F2 k5 G
. M. s, y+ `3 S8 x+ j0 N# [% `      pcan1, pbld, n, sgplane, *sgcode, sgabsinc, pccdia,
& x1 {4 I; y8 J1 k, P* B/ _        pxout, pyout, pzout, pcout, strcantext, scoolant, e
! ^. t$ S; n' ~" U; O& Q) f9 V& H/ J! \. {
plinout         #Output to NC of linear movement - feed                    & u3 A! R4 P/ a4 \
      pcan1, pbld, n, sgfeed, sgplane, *sgcode, sgabsinc, pccdia,
' e. E& ?" @$ I) |+ y: a5 G1 _        pxout, pyout, pzout, pcout, feed, strcantext, scoolant, e
3 b4 c3 @6 ?9 ^" o' Q# ?, g! e# Y6 _5 W' P3 `: m
9 Y7 k9 D$ a9 x: J      pcan1, pbld, n, `sgfeed, sgplane,* sgcode, sgabsinc, pccdia,6 b2 I# U4 r+ \8 |- E
        pxout, pyout, pzout, pcout, parc, feed, strcantext, scoolant, e 4 D6 A' Y2 f* H* F
9 O, O; ?4 g0 H/ v) T" c
在sgcode前加 *
发表于 2011-9-7 20:02:23 | 显示全部楼层 来自: 中国江苏南京
试试看,在9.1里可以,我的系统也是必须加G02和G03,朋友教得
