5天前
查看: 1251|回复: 2
[讨论] 材料编辑的依据
发表于 2011-9-19 10:28:11 | 显示全部楼层 |阅读模式 来自: 中国甘肃兰州
按道理应该用COSMOSWorks,可是工作环境:SW2006的COSMOSWorks找不到.只能在文本编辑中,按下列格式进行编辑sldmat文件.目标基本实现.) D# G7 r* ?8 J$ I! q9 H
请问:下面的格式的依据是什么?谢谢.
. h1 o* L! M9 e7 j  L' K" `1 K0 U5 c7 l2 A3 o1 Y0 M
8 r: @  A& _% n) }' ?<?xml version="1.0"?>" z8 G- m+ `8 j
<mstns:materials xmlns:mstns='http://www.solidworks.com/sldmaterials' xmlns:msdata='urn:schemas-microsoft-com:xml-msdata' xmlns:sldcolorswatch='http://www.solidworks.com/sldcolorswatch' xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'>
* l% D6 f# c" v<curves id="curve0">$ w$ [+ h' q7 O, v# |+ G
    <point x="1.000000" y="1.000000"/>
1 z  F  J( u+ ]% H    <point x="2.000000" y="1.000000"/>8 k5 }" ?* P; e8 n
    <point x="3.000000" y="1.000000"/>8 t. Z# ~' T  W
</curves>
" F) R- a) J6 a8 {; l<classification name="碳钢">
6 ^2 M* ?$ v+ _4 l7 W( ]<material name="Q235">. V- D5 q+ X, s  o4 d0 |. M. F" y
    <shaders>* F& M3 m  _4 q. j; R1 B9 X
        <pwshader name="綻產薛"/>  i2 l2 k0 W+ G: V$ j
        <cgshader name="CopperPolished"/>
3 b+ M8 ]* g/ D" f9 R/ `# O8 ~$ Z        <swtexture path="images\textures\metal\brushed\wrought.jpg"/>2 Q8 a0 X0 u0 ?$ d
    </shaders>
/ \* z, r! J3 z; }/ x    <swatchcolor RGB="ffffff">  j$ ?- l* c6 N) L; f; `
        <sldcolorswatch:Optical Ambient="1.000000" Transparency="0.000000" Diffuse="1.000000" Specularity="0.000000" Shininess="0.200000" Emission="0.000000"/>
9 \; N+ D, ?' A5 D8 k' F0 M    </swatchcolor>3 H7 K  u0 U: N, L; @
    <xhatch name="ISO (Steel)" angle="0.000000" scale="1.000000"/>
( b3 A" ~, f8 k7 n5 q    <physicalproperties>& M/ N, a$ j2 @5 I
        <EX displayname="弹性模量" value="199999995904.000000"/>6 P2 g8 D0 K' G& D* P. i( g
        <NUXY displayname="普阿松比率" value="0.280000"/>
' r7 Z6 ?9 [2 U  }        <GXY displayname="抗剪模量" value="76999999488.000000"/>
5 y" |: |8 s1 R3 S. \2 ~        <ALPX displayname="热扩张系数" value="0.000011"/>7 d+ D- v$ s3 Z" P1 C6 S1 C
        <DENS displayname="密度" value="7800.000000"/>
7 Z$ n: B/ ~0 \: s; N        <KX displayname="热导率" value="18.000000"/>+ C  {$ E# @6 W
        <C displayname="特定热" value="460.000000"/>( Z4 s! S% n! _4 @
        <SIGXT displayname="张力强度" value="413612992.000000"/>+ O& w3 F/ e  k  S. d; N0 s: u, E
        <SIGYLD displayname="屈服力" value="172338992.000000"/>
* v0 ~! V, ~( v* Q- x$ ]9 E2 W    </physicalproperties># `9 m% q! j$ y1 _0 Q( A
</material>: s+ A" Z# C! q1 s7 e+ m
</classification>5 }4 B: [4 S' U' k( x
</mstns:materials>
发表于 2011-9-21 21:04:01 | 显示全部楼层 来自: 日本
你不就是想修改材料属性的吗?
% H; C3 b. p% p5 X7 P. ]4 |# G2 K" l; U' p
修改参数就可以啊,那么麻烦???
发表于 2011-9-22 14:50:24 | 显示全部楼层 来自: 中国江苏南通
没有必要这么麻烦的吧
