查看: 5237|回复: 4
[分享] Solid Edge ST3 MP8 Update & crack (by SSQ)
发表于 2011-9-22 19:58:29 | 显示全部楼层 |阅读模式 来自: 俄罗斯
3 M$ X2 m# O/ {( b! ^
- F. l; s1 V  X4 D7 A3 f) g9 W. iATTENTION!3 D# R( Q+ M) b0 O- R4 B: t
It's Update only! To install it you need Solid Edge ST3 to be preinstalled!
4 E/ t+ Q: {5 r, R( Z' F
! e# p/ H: x* E% p' I" Gu.115.com# s" [% H  Y2 L  g0 N) Q
32bit4 N! X" u: k2 m
http://115.com/file/bhf2sp88#
+ G4 ]# h  |8 y' }" h2 k) O64bit
* W$ K; B& {1 U; w* Hhttp://115.com/file/aqymfzrz#. T; a7 ^; s: H/ K* G1 C. n
' g& q7 Q) k# u& L0 L
FileServe
" }. G! L/ t- K: s6 x0 i4 U! f* h32bit
) z. T. U! X0 F6 r6 h+ Yh-ttp://www.fileserve.com/file/yT9wu7V/SE_ST3_MP8_32bit_Update_SSQ.rar# K4 H& Q# f6 f" C7 m
64bit
* T- M- J3 C" hh-ttp://www.fileserve.com/file/BU4AeJr/SE_ST3_MP8_64bit_Update_SSQ.rar' W+ B/ e& N; H7 S. S
1 X+ s' F2 Y5 y2 G9 PRapidShare* N! ^) X" e6 y
32bit
& ?. G% Z6 M  `4 \1 y" Q& c  Hh-ttps://www.rapidshare.com/files/278268356/SE_ST3_MP8_32bit_Update_SSQ.rar
2 A$ O5 z% ]+ Z7 l4 f$ w64bit; r3 Q4 Z# |& f7 X  _- ~9 R
h-ttps://www.rapidshare.com/files/2280004065/SE_ST3_MP8_64bit_Update_SSQ.rar
4 Z9 `9 S: D& S
% Y8 f# [  W: B5 v& v% d2 M/ ^- uHere is list of fixed bugs
9 j# D4 q0 M6 x! S8 B# ?5 r% d! i=========================================. Q/ n& s# M7 c' v8 t
This Maintenance Pack addresses the following PRs:8 R* i6 S& Q8 C4 Z
=========================================$ [8 r! ^. q! h
===API===3 v5 ?- g0 h; S# p' R( K
PR 1844579: Need Automation support for creating PMI dimensions' [+ T+ W2 j& S# l/ |: l: o
PR 6585353: BalloonDisplayedText API does not return the correct info
- b- g" T4 D, B3 S===Assembly=== # b$ h: z. K& W) X+ U( O
PR 6560593: A large number of embedded weldment bodies causes performance issues for view rotation  {0 y! A; M4 G) w* t# W
PR 1848704: Getting an error when adding a new standard part (from existing part file)4 o* P% h- K% m+ }& N
PR 1854670: Assembly aborts when using Interpart Manager! T( M; ^/ l4 ?8 I; |) X
PR 1855154: Unable to import a Solid Works-asm (SW2010)
4 v+ E$ W. F8 l4 |. F/ Z3 e) f; ePR 1859600: Assembly contains parts that no longer display after adding Assembly Features3 D3 ]4 v. C0 J% D" u, x4 D7 ~
PR 2174262: Unable to place a 15 degree fitting, while all other angles can be placed
# e. {0 e; m) W; r; H4 ?7 JPR 6576033: pathfinder reports erroneous driven parts for top level sketches
0 `0 ]+ c0 S2 ]PR 1855845: Text font size doesn't change on sketch dimensions$ F" n+ U# [& J) A; h
PR 6571258: significant performance hit when profile has extra points0 O* i3 f; Z4 b* S2 h: v
PR 6487257: STEP file import performance is very slow using this file$ ?8 d$ @7 T, F4 R2 b! F
PR 1857542: Piping Performance is bad on ST3MP6 XP32BIt compared to V20 XP32Bit
( o6 l6 g# ]* `0 ]: I* t5 K8 hPR 2175526: Problems with fitting positioning on piping& ^$ x2 o- F1 S: X' U) t
===Draft===
0 h. i5 v( B  S, I( [8 W" H% w) VPR 1846417: Ordinate dimensions changed after opening in ST3
4 t0 o7 k5 K) M( a0 @% rPR 6578739: Solid Edge aborted on close
0 G* ?7 f7 V8 q+ sPR 2174989: drawing view caption is moving on file open
# `: x0 {: b+ e' wPR 2175139: specific edges are not displayed when the draft file is opened' _6 T* m3 T4 `
PR 1794331: a trim operation has a delay of 1 min+ in this file
9 l- @1 j& {, ~& s4 x4 O: w) ~PR 2175819: Parts List marks ambiguous parts even though the option is disabled9 d7 u  g8 r/ C, n/ h0 [- |
PR 6557936: PDF sheet sizes are swapped/ ]3 g$ ]: S8 t! X* o1 i2 ?) ^7 ?6 f
PR 1861764: Performance problem updating a view after many additions/deletions in the model  g+ n" |, h* a5 \. S, X3 c9 ^
PR 6572180: Spell Checker changes justification and removes text
) A# Y+ L1 i% o% A6 S/ c& d; p   Note: the updated spell checker can be downloaded from: http://ftp.ugs.com/solid_edge/SupportTools/SpellChecker/
1 R3 g$ a$ t5 T5 o===Insight/View & Markup===! O  d6 j9 K) K/ C
PR 1844744: No error displayed when search query ends 10x with timeout 6 j. v' Q6 N3 n! M$ |) O
PR 6557429: Crash editing sync file in asm after synchronizing through Cache Assistant5 A0 W# B/ z2 }/ Y# }+ {7 ~; {
PR 1856783: any user can release assemblies that contain parts with a Prerelease or Obsolete status! N8 r+ Z# \' C* Q
PR 6569695: Revise and set path operation creates duplicate files
! V3 E' E. q9 x; y: o7 B$ N2 [PR 6571007: Full Text search hangs on WSS3 server
, y2 Y  `  n6 C  q" [PR 6424248: User cannot create a revision as a member of a domain group
- S, N; u. E2 c6 P1 s& KPR 2165916: Traditional Chinese View & Markup aborts closing files
7 G+ J) O$ o) T9 g   Note: A workaround / partial fix for PR#2165916 has been verified for MP8 that requires you to manually delete
4 r, U# S! B. A( O" R               FrameBrokerWeb_res.dll & WorkspaceManager_res.dll files. The complete fix is scheduled for ST5.( `  K& |! J+ G8 s$ k0 k
===Part/Profile/Sheet Metal===
8 L6 c% a. u1 g/ z6 j3 q6 Q2 aPR 1857983: Synchronous hole thread disappearing when an ordered cutout is placed on the sheet metal part9 x6 {# z  a; ?
PR 6566839: Doing a recompute on first feature and Solid Edge hangs. V  a% w6 N$ X' r
PR 1856721: Select from sketch features indicate under-constrained profiles8 Y/ z+ I' y3 m0 b
PR 1860323: DIN.PZL and neutral factor has no impact on converted sheetmetal parts
0 f- x* F/ P1 S4 C7 R, zPR 6576500: Fewer Undo steps after each sketch, ending with a system error
8 W5 s# y/ i" Y$ Q6 E1 W4 ~+ zPR 1861355: Product Aborts when saving or loading a customization file with "deny" security$ ]% q. K1 t: F) [* n* x* e5 }
PR 1860681: Unable to edit dimensions in a sketch
2 U" u# @9 a# O1 E  o' \% HPR 6580444: Bends w/default bend radius are not driven by the global setting after transform- {2 D, O) l/ C2 W
PR 6582077: Adding a cutout makes part disappear$ A8 ~  c' A. z' Y* [4 ]9 ^
PR 1856611: Part disappears after move/zoom/rotate# Q4 `5 y9 D3 a. V2 k7 D( h( p
===Solid Edge Embedded Client===
$ X8 |. v( ?2 ~2 qPR 6569840: cannot save searches based on newly created searches
( Y2 O/ N/ c( y5 O& y& t* u% hPR 1843322: NX part files are not updated / removed from SEEC cache* C6 X  U  L' k, f- Q5 N8 j0 Z7 Q7 B
PR 1851218: Very low performance for AddToTeamcenter
! C3 h5 f5 ~6 u5 F' V) u, i/ f8 mPR 1851237: Solid Edge Item Number Sync works not from TC to SE 3 f( |2 J0 \8 g2 M) z2 G* m' j
PR 6515479: Find Number for TcVC tries to reset and can lead to a collision
' E& P. _0 K. [( ]PR 6546565: Sets Priority ID for a new revision of a part in the CPD and it changes Priority id
发表于 2011-9-22 20:02:41 | 显示全部楼层 来自: 中国北京
破解也更新了?还是仍然用以前的?
发表于 2011-9-22 22:05:28 | 显示全部楼层 来自: 中国浙江丽水
ST3目前已经没啥子吸引力了。
 楼主| 发表于 2011-9-22 23:12:47 | 显示全部楼层 来自: LAN
破解也更新了?还是仍然用以前的?
! B2 O. e  A" y* X: [) o368天 发表于 2011-9-22 20:02 http://www.3dportal.cn/discuz/images/common/back.gif
! n2 z6 A* {) \1 C2 uLicense is the same as I shared for ST3 MP2
发表于 2011-9-23 08:14:36 | 显示全部楼层 来自: 中国北京
ST3目前已经没啥子吸引力了。
$ z' S. N* J! i大有茗堂 发表于 2011-9-22 22:05 http://www.3dportal.cn/discuz/images/common/back.gif
0 k; `# j( }( @5 f
哎,偶只能用ST3
