发表于 2011-9-29 14:39:29
来自: 中国江苏无锡
自动转很简单的.自己新建个宏,把这段代码复制进去就成了...拉个图标上去..就成了.
. F% {' P. O/ @9 e
2 Q# S# X6 S4 T9 t) X6 F'''****************************************************************$ ` z$ n0 G8 F5 n7 C! ]
'' Edit by votasee @ 090909 update 091010& X& {: J0 v j1 {3 u4 ?! q
'' ****************************************************************2 D2 l3 n% Z/ }+ H" d) X4 o
Dim swApp As Object7 F. w& M/ b; e: ]
Dim Part As Object5 M: _. @, r" Y4 f
Dim Filename$, dwgFileName$5 R) W1 F: T' ^* Q8 Y% j! c! o$ _
Dim No%, Title$, sTime$, sUserDir$ o% h1 X# }% |
Sub main(), D4 v/ q$ u# W) u2 a
Set swApp = Application.SldWorks
& I) W# B% ^+ q9 [! h0 W. kSet Part = swApp.ActiveDoc; Z: F4 Y# O6 Y7 F$ N) o6 V; h
On Error Resume Next
8 N- q3 n& d, o8 f Filename = Part.GetPathName()
! T( i: M/ d* S8 e+ m( e/ ^* E% v* y sUserDir = VBA.Environ("USERPROFILE") & Chr(92) & Chr(-10304) & Chr(-15386) & Chr(92)8 U; s7 r1 p* Q( ^5 ?
sTime = Format(Time, "YYMMDD_hhmmss")
( y7 v* }) W1 e6 ?1 D: {
7 @( e# @0 s [( m8 @+ c6 _ Randomize
8 [' x5 B) G1 Y- s. s If Filename = "" Then Filename = sUserDir & "Part" & Int(Rnd * 1000) & ".SLDDRW"
2 |0 J1 d0 u/ \8 H$ W! a8 j''' if need SLDDRW FILE,THEN DELETE THIS MARK!
8 Z! x6 X" ~* v6 z+ M+ R; q# U" r+ Y' Part.SaveAs2 Filename, 0, 0, 0
3 L5 l' e& n) {/ N/ P' \ No = Len(Filename)
7 C" X4 E6 g5 R- L/ x' v dwgFileName = Left(Filename, No - 7) & "_" & sTime & ".DWG"$ F% }8 ?( b- U K
Part.SaveAs2 dwgFileName, 0, 1, 0! [2 e- _9 F+ N* O/ t
Title = Part.GetTitle; Y' y& A8 B5 F8 V
' Set Part = Nothing; r; Z! g: w6 _9 `0 \$ u
' swApp.CloseDoc Title) t' C9 _! m: p* J( A
swApp.Frame.SetStatusBarText Filename & "is SAVED!") t( b. ?4 u1 i. o! H- i" z# [
End Sub
3 b& Y P4 `% M: [0 c+ n) |' ]8 E; n% [8 w% p* L& p7 G+ z) u
'Part.SaveAs2 "C:\Documents and Settings\Administrator\桌面\Part1.DWG", 0, True, False |
