查看: 1290|回复: 0
[新材料] 材料及线缆烟密度测量方法比较
发表于 2011-9-28 13:26:10 | 显示全部楼层 |阅读模式 来自: 中国上海
摘要: 线缆行业大力发展低烟无卤线缆和材料,此类产品都要求测量烟密度。烟密度值是试样在规定试验条& ?2 s7 P- j" a+ d) u0 \  Z
件下测得的,不同测量方法得到的试验结果不同,不能认为是试样的固有性能。材料烟密度试验方法标准新" E  c: P; w1 i" }9 V
版GB/T 8323—2008 与原GB/T 8323—1987 存在诸多差异,线缆烟密度试验方法标准GB/T 17651—1998: P, W$ f$ t5 l! f. L7 v+ {
( IEC 61034—1997) 和UL 2556—2007( 9. 9 节) 测量方法也有较大差异,文中对这些测量方法进行了比较。
+ f- c( |3 z& L* e6 @1 F: E4 ~) l关键词: 烟密度; 测量方法; 材料; 线缆; 比较* b6 Y0 F* d- n- x& X6 z" x8 |
Comparison of Test Methods for Specific Optical Density of, a4 s$ \% a- s9 F8 S- X
Smoke Generated by Wire and Cable and Their Raw Material
( l6 N- W5 l* gLI Ming-zhu,et al9 s/ x4 H5 v6 \8 z
( Shanghai Electric Cable Research Institute,Shanghai 200093,China)5 P$ @0 @2 I& _0 ?
Abstract: There are a large number of low smoke zero halogen wires and cables and their raw materials in our industry.
# j" T( F% t% o  `9 M' _Need to determine the specific optical density of smoke generated by these products. The density of smoke generated# q9 J& q/ M$ y
by a specimen was determined under the specified exposure conditions. Values determined by a test method are
4 g4 R9 g( }5 i9 J( anot to be considered inherent fundamental properties of the specimen. Values determined by different test methods are
; n7 n6 R$ ~- [/ c7 j  inot same. The new edition of standard GB/T 8323—2008 is different with the old edition GB/T 8323—1987. The4 B! A7 _% q9 r% d2 H1 [0 Y' J
standard GB/T 17651—1998 ( IEC 61034—1997) is different with UL 2556—2007 ( 9. 9) . The report describes
- J8 c' C, I6 l( _) L* [; n9 Tthese differences.
; K5 S2 v- T8 l/ z+ x1 N% M% q/ TKey words: density of smoke; test methods; material; wire and cable; comparison
材料及线缆烟密度测量方法比较.pdf
148.71 KB, 下载次数: 0
