查看: 1064|回复: 0
[新技术] 高压架空输电线自动防冻方案
发表于 2011-9-28 13:28:43 | 显示全部楼层 |阅读模式 来自: 中国上海
摘要: 介绍一种高压架空输电线自动防冻的方案,即在架空输电线上附着防冻自动控制器及其相连的发热电$ f" g5 n- {. E$ e- u& v( \
线。当架空输电线温度低于3°C 时,防冻自动控制器将开启通电,使发热电线升温,提高架空输电线的温度,
  P. _/ j: N- U! ?5 f4 K: U4 F8 l所以不产生冰冻; 当升温到12°C 时,防冻自动控制器将关闭,停止通电。这样就可避免架空输电线冰冻的
% ?0 ]: N" z2 k危害。8 U# B, H# v3 n
关键词: 高压架空输电线; 防冻方案; 自动防冻器; 发热电线  l; i& {4 q6 g* C+ _
A Plan of Preventing the High Voltage Overhead Transmission Line
, v2 H/ @/ B& m/ l$ {0 JZHUANG Shao-lin
% }6 f7 X0 f$ C" P( Qingdao Harmony Electronics Co. ,Ltd,Qingdao 266410,China)
5 z7 G- m; O0 ]- V/ o5 C4 q: o- nAbstract: Introduce a plan of preventing the high voltage overhead transmission line from being frozen. In other3 |! t: |6 z' A+ ]9 ~
words,A antifreeze automatic controller and the heating line are attached with the high voltage overhead transmission
3 h* S+ @, s. m, p. v% Xline. When the temperature is below 3 degree,the antifreeze automatic controller will be opened,the heating-line’s
) O: M* t" ~; Btemperature is begin to rise,the high voltage overhead transmission’s temperature is begin to rise. When the temperature
+ O, d2 o) [4 Mis higher than 12 degree,the antifreeze automatic controller is closed. Consequently,the high voltage overhead
4 Y0 C1 g: X& A% e+ utransmission line will not be frozen any longer. So according the plan,the disaster which is caused by the frozen high1 B1 o' s4 i/ k: E# `: H4 a
voltage overhead transmission line can be avoid.
. ~, d& M0 Y, T9 r" w1 X9 DKey words: the high voltage overhead transmission line; an antifreeze plan; an automatic antifreeze controller; the6 v  z" J, m( _2 O. K* L& K9 a
heating line
高压架空输电线自动防冻方案.pdf
119.64 KB, 下载次数: 2
