摘要: 根据变频器电缆使用环境、电压或电流的波形畸变、电磁干扰、分布电容、波形阻抗等诸多因素,对其产
$ R6 U3 S/ b) a& b4 w/ F) H8 Q; F品结构设计、材料选择以及关键生产工艺进行了分析,研制了硅橡胶绝缘硅橡胶护套变频器电力电缆,该产品0 E9 u0 d' j9 f! a3 k0 u
具有耐高温、耐低温、耐辐射、耐老化、抗电磁干扰、柔软等特性。
7 ^& `+ u) }6 E+ s# S关键词: 变频器电力电缆; 硅橡胶; 结构设计; 材料; 生产工艺. B1 U8 Y8 ]4 c
Development of the Silicon Rubber Insulated and Sheathed Inverter Power Cable! f, d. V0 x; b$ ]
GUO Jian-xu
8 Z0 w6 H+ A# b6 a3 Q( Jiangsu Hengtong Power Cable Co. ,Ltd,Wujiang 215234,China); B/ ^$ H8 A6 V2 Q5 f
Abstract: The authors analyzed the structural design,material selection and key production technology according to
' @2 U! M. R, V" wthe environmental conditions,voltage or current waveform distortion of the voltage and current,electromagnetic interference,
* u0 d9 \9 ?0 J( I/ f4 u1 }# Xdistributed capacitance,wave from impedance factors,and developed a new type of inverter power cable for
- ]; g$ R, n7 C: q; h3 [silicon rubber insulation and sheath,which has the high and low temperature resistant,radiation resistance,aging resistant,* p5 @( l- f. J0 Y$ K1 {
anti-electromagnetic interference , soft features and so on.) [$ Q" n+ o& i0 J( c
Key words: inverter power cable; silicon rubber; structural design; material; production technology |
