查看: 1019|回复: 0
[新技术] 国际核聚变装置用超导电缆绞缆技术优化研究
发表于 2011-9-28 13:29:52 | 显示全部楼层 |阅读模式 来自: 中国上海
摘要: 国际热核聚变实验堆计划是目前我国参与的最大的国际合作项目,CICC( Cable-In-Conduit Conductors)! f6 U' [* B1 c8 [; Z
导体具有较低的交流损耗,是核聚变装置的首选导体。介绍了CICC 导体的结构及其绞缆试制过程,确定了
# i4 P# u$ m4 Q" _/ t& i7 VCICC 导体绞缆工艺技术路线。多次绞缆试制表明,第五级子缆的绞制加工尤其是外径控制是整个CICC 导体
4 h0 O/ l# d. @+ R绞缆关键环节。多道辊压+ 定径哈夫模控制技术可有效地控制CICC 绞缆的外径,并不对单线造成损伤。
. r- M, G0 \( \# Z关键词: 核聚变装置; CICC; 超导电缆; 绞缆; X" p9 @  A2 M( p
Research for the Optimization of the Cabling Process of CICC Conductor7 l, u  r, X( m) o3 [6 @
TENG Yu-ping,et al
" G4 S( h2 p! H! s: g$ u( Institute of Electrical Engineering,Chinese Academy of Sciences,Beijing 100190,China)
" C+ L  s, U8 G: g3 ^Abstract: ITER( International Thermonuclear Experimental Reactor) is the largest international cooperating program,- o8 [: Y" l, a/ S/ }2 y
which is being participated in by China. CICC ( Cable-In-Conduit Conductors) conductor was deemed to be the preferred
+ g7 p% d6 R0 o6 ~2 J3 o4 T. j, ~% uconductor for ITER program due to its lower ac loss. The structure and the cabling process of the CICC conductor4 C- e0 b, u5 m  h) Z
are introduced in this paper. The technique route of cabling has been established. The cabling process and the' S/ B6 c; L; e- O
controlling especially the diameter of the fifth-class cable are the key points for the cabling of CICC conductor. The
( v# \/ i% ^* n# Hdiameter of the CICC conductor can be controlled efficiently by multi-rolling die + half-die for diameter controlling' |; c, l7 B/ N. B) A+ @! D& r
without injure to strands line.
& Y' I7 |' B& B8 rKey words: ITER; CICC; superconducting cable; cabling
国际核聚变装置用超导电缆绞缆技术优化研究.pdf
340.52 KB, 下载次数: 0
