查看: 1081|回复: 0
[新技术] 架空地线用铝包钢绞线型号的识别与选用
发表于 2011-9-28 13:30:29 | 显示全部楼层 |阅读模式 来自: 中国上海
摘要: 铝包钢绞线在架空输电线路地线上应用越来越多,但是型号、标准不尽统一,给线路工程的管理、设计、
' w& L% P# Y* E; C4 R1 o8 D' h  H运行维护带来了一定难度。通过查阅铝包钢绞线的国标、部标,并根据工程实际选用情况进行了比较,分析了
: d3 H7 Q4 S# }0 \它们的相似与不同之处,可以为广大电力技术人员在工程实践中选用铝包钢绞线提供一定的借鉴与帮助。
7 m6 v* V" ?) m* T; O  T关键词: 铝包钢绞线; 导电率; 截面积; 型号; 选用
4 i/ |* g% z. r. v$ O Identification and Selection of Aluminum-Clad Steel/ U; b# i" o6 V
Wire Models in Overhead Ground Wire
% ^0 L* @7 ^# @, P& VHAN Li-kui,et al
- ?- ?& D1 Y, q& i& k( Dezhou Power Supply Company,Dezhou 253008,China)
9 r7 F* V% X! C; |9 w! t0 T% kAbstract: More and more aluminum-clad steel wire for grounding wire application on the overhead transmission lines,- C. _7 ?( {1 X9 W: z
But not unified model,standard,To the lines engineering management,design,operation and maintenance of a certain4 X4 z1 o) H. Z. T5 _3 p# Q" _
difficulty. This paper through the national and ministerial standards of aluminum-clad steel wire ,label,and
7 ^+ Z" g) r4 c! G8 h6 z7 Acomparison of selected according to project,analysis their similarities and differences,can provides a reference and
/ y! U" \* z1 ]" z) c4 K, v6 E2 d+ Qhelp for the majority of electricity and technical personnel during the engineering practice in the use of aluminum-clad2 D) C: ^( x2 \  _% e
steel strand.& k' q2 b. l& {  A4 M/ r* d- [
Key words: AS wire; conductivity; cross-sectional area; model; selected
架空地线用铝包钢绞线型号的识别与选用.pdf
143.95 KB, 下载次数: 5
