查看: 1040|回复: 0
[新技术] 民用机场助航灯光电缆主回路故障诊断与排除
发表于 2011-9-28 13:48:24 | 显示全部楼层 |阅读模式 来自: 中国上海
摘要: 民用机场助航灯光电缆是保障机场安全运营的重要设施,由于工作环境异常恶劣,分布范围极广,使得
+ V% I: H( n( M, x其一旦发生故障将直接严重影响到机场助航灯光系统的稳定。以银川机场助航灯光电缆的故障实例为背景,- E) Q, j$ v; K0 @% b1 b. b2 o/ a
对故障发生的机理、诊断与排除的过程做深入地分析与探讨。9 U, m; x, s. q3 Y3 Y$ F
关键词: 机场助航灯光; 灯光电缆; 开路故障; 接地故障; 复合型故障$ E' J5 E7 u  i/ d
The Analysis of the Troubleshooting of the Naviaid Cable9 d7 ^% |' ~5 b% v
HU Yi-zhu4 L) \, a6 ^) Y) J" R
( China West Airport Group Yinchuan Hedong Airport,Yinchuan 750009,China)
1 s( q2 C& G- ]* RAbstract: The naviaid cable is the important facilty that guaranteeing the security of the normal operation of airports,
) M+ P  N7 L7 G* a5 e4 Obecause the distribution of cabling is very widely and the circumstance often is too bad,make it will directly influence
% O; O. c8 _+ Hthe status of the air field lighting system seriously. This situation is a common problem in most airports. The troubleshooting
( ?. P1 [5 x2 R. Vof the naviaid cable is analysed.5 C. b! m8 d) K2 o" Z# i5 _* L
Key words: air field lighting; naviaid cable; broken circuit; ground connection; combined failure
民用机场助航灯光电缆主回路故障诊断与排除.pdf
193.43 KB, 下载次数: 2
