本帖最后由 fisherliu 于 2011-10-21 17:18 编辑 # I8 c; k! p. f% y/ F- G
6 o, j4 X$ b1 A5 w, H, q在PRO/E 中,螺纹参数表中有如下参数,不知道什么意思,请大虾帮忙。
7 u! _" m1 a+ Y/ V+ B5 Q3 l: x8 E/ J; h" t' p1 y) L
| PROE_VERSION | 表建立时的版本
# o, M: \9 y3 \2 V. R& W | | THREAD_NAME | 空表的名称. This parameter can be used to create threads with multiple names that have the same THREAD_SERIES. If a name is not mentioned, then the THREAD_SERIES is used by default. ' b9 F. E$ S6 e% H. h! I9 \6 h
| | THREAD_SERIES | 使用的孔标准 (比如, ISO, UNC, UNF, NPT, NPTF, ISO_7-1).
. x" V) B8 c# o2 @9 u ^% ~" W/ D | | THREAD_TYPE | 螺纹样式. 必须包含以下样式的一个: TAP, TAPERED, or TAPERED_ISO.
3 y$ I3 @1 n& U# |) i% I. j6 _ | | THREAD_CLASS | The tolerance class for the hole chart and a parameter that will be visible in the Thread Note (for example, 2b or H).4 Y; P3 `& B+ v* R
| | TABLE_UNITS | 空表的单位值; 必须是inch或metric之一./ k$ A6 {/ ?; r+ T
| | DEPTH_RATIO | The relationship between the thread depth and the drill depth (for example, 1.25). When you enter either the thread depth or the drill depth on the Hole tab, the other value is calculated automatically using this ratio. Drill Depth is Thread Depth multiplied by Depth Ratio.
+ M+ g2 _: {, W7 S" j1 M- B( SNote
( @9 L2 U& \) n0 l$ s& iYou can override the default relationship of the depth ratio by entering both the Drill Depth and the Thread Depth values on the Hole tab, under the condition that the drill depth value is greater than or equal to the thread depth.
0 s) v; M# L1 W- n( E5 S: H- E: t* C
5 P) {' t4 \1 W- ^0 x; o | | CALLOUT_FORMAT | The format of thread notes created or shown in the model and drawing. This is not a place to add text to a note, but a place to define the way that the text of a note appears.
% r" n! J9 ~1 e1 A$ X |
4 p4 c; g1 ]% J! L, fTHREAD_DATA (hole parameter values) \1 ^$ D/ B3 Z! f% O, Z Z
& }7 O1 o# d/ u" U
FASTENER_ID显示在孔标签的螺纹尺寸列表中
0 M: D; }2 m& cBASIC_DIAM螺纹直径5 u; w4 T+ z Q2 s* t4 F
THREAD每英寸的牙数,或牙距(公制)
8 ^- ?/ Q7 P0 Z. _TAP_DRLetter, fraction, number, or metric drill standard size.
' G; n; i; O6 oTAP_DECDecimal size in inch or metric of the tap drill. This value appears in the diameter list box in the Dimension area on the Hole tab. (See Note below.) * l2 x7 ~& [0 ?
PERCENT_THREADRatio describing the actual engagement of fastener threads.
" h7 j9 q' H8 Z8 V9 a0 @CLEAR_DR_CLOSEClearance drill, for close clearances.
8 K+ A7 a4 M3 h/ `/ a( mCLOSE_DECDecimal size in inch or metric of the close clearance drill. This value appears in the diameter list box in the Dimension area on the Hole tab. (See Note below.)
. o0 u6 o% t# V% z; F9 N# Z( bCLEAR_DR_FREEClearance drill for free clearances.3 g, u6 X2 m! {& h3 Y8 @2 y2 V2 Z
FREE_DECDecimal size in inch or metric of the free clearance drill. This value appears in the diameter list box in the Dimension area on the Hole tab. (See Note below.) 5 M8 A: w( j2 U' x
CLEAR_DR_MEDClearance drill, for medium clearances.9 I) o ?) j! V! x3 y. o5 K
MEDIUM_DECDecimal size in metric of the medium clearance drill. This value appears in the diameter list box in the Dimension area on the Hole tab. (See Note below.)
( Q$ j* Q3 E, m5 T9 X7 XCBOREDIAM平底沉孔直径
/ e- D5 I# J7 S3 ICBOREDEPTH平底沉孔深度
* @% b6 J6 V5 R0 C" CCSINKDIAM沉头孔直径
1 q0 Z2 N' V7 P' o; @CSINKANGLE沉孔角度.' _. P/ `( C) u* o# [, X: C
BOTCSINKDIAM退出沉头孔直径
* a/ J. {3 \6 F6 DBOTCSINKANGLE退出沉头孔角度
) U0 E7 y6 Q, |3 }. U' Z% U |
