https://forum.solidworks.com/message/116545# ~' S4 b1 d0 k8 T$ n' q
- w, \# f# L8 I8 K" D& Z3 d* Y
( a$ s4 g# R, |8 Z! U-
8 Q; y h4 ^+ R0 D6 E* @( z9 G. H- a+ y3 D - ' Mass_Section Properties (Mass) ---------------------------------06/08/10) t6 C6 x8 S- ~5 u% X& y# t" N
- ' ******************************************************************************7 X. h5 @' X: A& G1 d
- ' Macro will change the Mass units for Mass/Section Properties from Grams to Kilograms
$ b3 j" x5 {6 g2 y% [0 `2 \" J - ' or vice versa7 Q2 M |" b- X2 B
- ' ------------------------------------------------------------------------------; Y* k" i6 J. b3 o
- ' Written by: Deepak Gupta (http://gupta9665.wordpress.com/)- t" h( d! p- k4 ?
5 |3 G& l' J [! U2 F. V - Dim swApp As Object4 `/ o# {7 g. S& I& b" l
- Dim Part As Object: R/ A* x+ ?' j7 n5 ~
- Dim boolstatus As Boolean( u1 i% _. Z i8 A
- Dim longstatus As Long, longwarnings As Long
: }: Z6 v/ S' }& Q7 b - Dim Instance As swUnitsMassPropMass_e 'As swUnitsMassPropMass_e! l& c- H% L+ \. {$ i/ z
- Sub main() q( K/ d% Z- N. F
- Set swApp = Application.SldWorks% o# I/ m4 E4 H- q) X+ r
- Set Part = swApp.ActiveDoc( n- m5 G1 y0 d) \+ s- P( g x
- Debug.Print Instance2 \' p7 Y, c, n. U! `8 U
- ' Set the Unit system to Custom
2 [% V5 g1 @0 Z5 P$ ~ - boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swUnitSystem, 0, swUnitSystem_Custom)2 r/ r; d& G, z& [/ U
- ' Get/Check Mass/Section Properties - Mass - Unit, if Grams
/ z! g. p( o+ L7 M- I - If (Part.Extension.GetUserPreferenceInteger(swUnitsMassPropMass, 0) = 2) Then
Z' ~# O/ L1 _2 | - ' Change to Kilograms/ @/ }) P: R D& }
- boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swUnitsMassPropMass, 0, 3) '! F+ Q" N4 `2 h: _: ?: V
- Else
4 N, Z, w1 w, V& Q! Z - ' Else keep or set to Grams
" h, z4 N r& ~1 h) y - boolstatus = Part.Extension.SetUserPreferenceInteger(swUserPreferenceIntegerValue_e.swUnitsMassPropMass, 0, 2)+ o5 N9 N0 X( A- r! C
- End If( N q# J+ }- d+ ~* J; I3 u9 \
- End Sub& R: Y! I9 y9 _4 {+ k2 I& ^
复制代码 ' u0 o4 s. f. S- C# h( \; O
! ]' G1 |. p4 c- i6 G, u D& z, c
- f8 D# {( Y% T H! J'This example shows how to change the drafting standard to a custom drafting standard.
q1 T: S4 q- u4 Y, X k'-------------------------------------------------, E% f& Y8 d1 k# S) N
' Preconditions: Model document is open and a
S# a$ ]2 y' ?! O' SolidWorks-supplied drafting standard is set.1 E2 X4 V* X8 C$ P
'0 J& `. ^+ U' Y' W
' Postconditions: Drafting standard is set to the
; K% J" Z# i# U% i- i' specified custom drafting standard.
) I* Q S, ]5 B9 n'-------------------------------------------------# D5 G( Z' O/ W% z7 P
Option Explicit
2 D1 t }6 A3 D
, }+ U: ? ~% i5 {$ FDim swApp As SldWorks.SldWorks
+ G8 E* A# k) @+ } }Dim swModel As SldWorks.ModelDoc2" z& U2 t; R9 l3 X1 v" m
Dim swModExt As SldWorks.ModelDocExtension
9 m( h+ U( a/ Y8 ~Dim bRetVal As Boolean
. A) O/ [( k. y5 [Dim sPath As String
( B- \% M1 S2 N# N" ]Dim sFileName As String
) ^3 W& b; `1 P. d; NDim vDSNames As Variant
+ o. E& l4 T" G9 m8 tDim i As Integer# S" x6 b4 w4 o% r
0 I4 R/ h* ]0 J1 B4 D O
Sub main()
' X- k8 }& L6 U- t* t! K( e/ v) n7 \7 D6 _5 o' T2 S
Set swApp = Application.SldWorks& o7 m9 y' C4 K% b# P
Set swModel = swApp.ActiveDoc
( S4 Q" Y: O) U% ySet swModExt = swModel.Extension
9 k0 t4 B4 ?1 P/ V
1 y; S. b" s6 c4 u+ h'Get current SolidWorks-supplied drafting standard
+ ]* K* |2 G! X8 Z5 ~Debug.Print "Current drafting standard..."' U* }. S; C4 P1 D
Debug.Print " (Standard, NoOptionSpecified) before = " & swModExt.GetUserPreferenceInteger(SwConst.swDetailingDimensionStandard, SwConst.swDetailingNoOptionSpecified)
5 P! @9 G1 {) i+ @Debug.Print " (StandardName, NoOptionSpecified) before = " & swModExt.GetUserPreferenceString(SwConst.swDetailingDimensionStandardName, SwConst.swDetailingNoOptionSpecified)
4 L4 j" V" I- i8 j& p7 Q6 u) z5 IDebug.Print " "
' c! N& O& y4 T4 {' Z9 n2 f @5 D9 S
' Get drafting standard names
" ?- n3 y' F. N- x9 z* t# w' Only the SolidWorks-supplied drafting standards
% H) C) b% a8 i6 q' are returned; any custom drafting standards are# d+ [# I9 c1 L$ I% A9 ~$ \- @6 O
' not returned
6 Y% @. f4 I' r3 T5 p& YDebug.Print "SolidWorks-supplied drafting standards..."
' H9 [1 _, i0 H. H( ^+ p( G! jvDSNames = swModExt.GetDraftingStandardNames
7 |% K: F- N) cPrintNames vDSNames. S' U% T$ n r) X8 x
Debug.Print " "# R# L; X- e" n0 Q# n
s& B8 O: | W; t8 i6 i' Load custom drafting standard
: P! W% R0 I9 \" o0 D( h6 jbRetVal = swModExt.LoadDraftingStandard("C:\test\MyANSI.sldstd") ' Substitute your custom drafting standard path and filename
/ w+ i( w ]. I( f, h: q8 l* x
; ]2 [4 `/ h2 w, `, {: W' Get custom drafting standard just-specified
5 ]3 e: ~& k" a. I! LDebug.Print "Standard that custom drafting standard is based on or derived from..."3 S) [4 @, p6 l; l
Debug.Print " (Standard, NoOptionSpecified) after custom loaded = " & swModExt.GetUserPreferenceInteger(SwConst.swDetailingDimensionStandard, SwConst.swDetailingNoOptionSpecified)
5 o2 g* \; a# P5 z* ADebug.Print " (StandardName, NoOptionSpecified) after custom loaded = " & swModExt.GetUserPreferenceString(SwConst.swDetailingDimensionStandardName, SwConst.swDetailingNoOptionSpecified)* J# b) a& S" L5 T/ ]
Debug.Print " "
$ J; c- I) d# B9 h( E T& u5 s/ {
" {9 J2 S v: g. z' Get drafting standard names
: A M% w/ p! q/ G* T, E2 O' Remember, only the SolidWorks-supplied drafting standards# W5 X$ b& w. [# K, E, }( M
1 @0 e) M1 Q2 l' not returned
% ]8 o3 S# d( o+ n1 R5 g1 w# IDebug.Print "SolidWorks-supplied drafting standards..."
5 T0 S5 u$ q! v+ A& |. CvDSNames = swModExt.GetDraftingStandardNames, B% n# Q" M; t% M
PrintNames vDSNames! x$ o8 O- j0 z3 f0 Z4 F1 k- T
Debug.Print " "
/ R# B/ H9 z0 c! g& r: ?; R, @1 m% `2 H& h P4 C) X
End Sub
" a* V* L( H7 I: [3 x" @6 n3 I
. u; S7 A% e! u4 b# Z, AFunction PrintNames(ByVal vDSNames As Variant)
. z* S6 k" h$ G) J0 Y7 ?For i = LBound(vDSNames) To UBound(vDSNames)$ M( a0 Y+ c, Q& ?# z
Debug.Print " " & vDSNames(i)
1 ]4 v: p/ b$ R" uNext i
1 C+ n* u' f8 ]8 N, D" _! d4 v$ mEnd Function |
