遇到如下问题不知该如何计算: v# C% j) T8 \8 P$ w( `4 m
请达人指教( `; I; D/ L4 g( W
have some requests more about needle valves :, S' u- q, S/ p, y# M
5 L; Y5 J2 l. c
1 – What is the hole diameter the needle valves needs for a flow rate of 2500 litres/hour with a pressure of 4.2 bars.
; r& z" [- ~: L% r+ ?7 J Q" J7 \% Y" r5 W
, O/ ?4 R, q9 ]2 – what is the flow rate for a hole diameter of 6.8mm with a pressure of 4.2 bars9 I$ L4 D& X# J# s
what is the flow rate for a hole diameter of 8mm with a pressure of 4.2 bars* G9 z+ N$ [) |2 q4 S+ X3 m1 l
2 S- H) E- A+ B6 \2 Y0 N& w9 o9 |. i- u+ p
. ~: m! f! Q( y1.压力为4.2BAR,CV值是2500L/H的情况下,孔径是多少。$ c* U9 ]$ p X6 y! ~" k" t$ @
9 A9 j: I3 ]3 Y" U* v2.压力为4.2BAR,孔径为6.8MM,CV值是多少
7 C; [+ E( Z) b/ P: ?
# q# p% p, Q) s( L. W( @; k 压力为4.2BAR,孔径为8MM,CV值是多少
5 v$ T7 {3 S- P+ e f! W
" q9 m6 R* T* |. r/ e[ 本帖最后由 userkypdy 于 2007-3-20 19:52 编辑 ] |
