楼主 |
发表于 2011-12-5 19:34:23
来自: LAN
7 r, d1 ~* Z4 s7 L
2 @2 Q& u I# O( h8 V
List of fixed bugs
" O, ^- a' p& q' [5 B --------------
1 p9 L7 ?3 L& X1 a0 gRelease Notes:
+ ?+ Y% |* U; Y--------------
$ G# @' E; w }" n* ?8 g0 x 0 Y" p7 g q) d- F2 n
Product: Solid Edge
9 K; H& m/ ]+ Z+ x* dVersion: 104.00.02.05 # r( S o) r. _4 V) `
Date: 17-Nov-2011
. ~5 t4 l- `" u" Q! {-------------------------------------------------- 4 c2 Y: h& ?' [' Y4 j
This Maintenance Pack addresses the following PRs: 6 c) a! V2 D* D6 i3 ]4 I
% _* F2 p1 q' Y% ^& ` t# i$ Y 2 Q( S! @' x$ J* o
===API===
& l1 f8 K+ H' I* a9 H* V, w
: f; U( g( ]- e6 _PR 1858168: Problem with the Add-in Menu, does not display correct the first time, works fine the second time ; l, m& t$ L) h" j) a/ t
" |- e" i6 {- }! ~1 l
===Assembly===
( Q8 l% T# P* U; O# R3 L1 `8 I
! b0 c( O: a# vPR 1863648: Drag & Drop performance depends of asm size and if components are hidden or not ' ^/ |- k6 f; n2 |
PR 1867394: Wrong result if 'Ignore interference between matching threads' is activated * R/ j- H, K# `; ~
PR 6555905: Parts Library tab is slow to open when an Insight .par or .psm is last selected/highlighted in the tab
5 k# M6 ~( X0 @7 c1 f* w* KPR 6584857: Assembly hole features not honoring number of holes in profile + I5 z u4 g4 v7 x) h6 |* L
PR 1867986: Unable to delete button when macro not found
' g h& h+ _# x- s; h: k
3 U$ ], F) f8 A/ |% k===Draft===
/ {- @! `3 x# y2 |/ h # |) I5 x* |4 S9 M3 E
PR 6579864: Having problems selecting a Pipe in Draft document ' K* ?' Q4 e A% R1 {+ {9 n
PR 1867983: Parts List column Property Text is changing when ST2 file is opened in ST3 or 4
$ s$ J4 V0 ^( zPR 6603842: Parts List maximum row setting is overwritten ' D3 t N) e5 ~& x% T5 n
PR 1868919: Diameter symbol in callout displayed as %DI in 3D pdf , ?/ p' K; l: Z4 f( \7 }. U6 t
PR 1869690: No options when saving .emf in draft environment
, D1 Y- l5 d; x, q( T+ MPR 6541132: Cannot Open NX8 Documents 6 u, B: f$ |! u8 O v! K
PR 6599967: Solid Edge crash 1 P! Y* x6 j6 U% p. P6 T* ?
PR 1869499: Moments of inertia will not consider the scale Factor / n' p ]$ p+ o! w! N
PR 1870486: Line up text with left alignment does not work properly 1 \* B/ e5 r* ~3 {- U' `
PR 6609433: Crash when placing drawing view after hitting back button in DV wizard
0 O6 {+ M& c0 ?7 XPR 1826842: Parts list is not exported when attribute layer mapping is on ; r' X8 W. {0 [! y* G9 g) c5 H
PR 1842000: There is a gap between leader and break line of a callout in certain positions
! A+ k* a) ~" M' Q: {7 n , p* `$ F* {5 d
===Part/Profile/Sheet Metal=== % u& s$ y5 B8 B1 U( q2 U3 W. X3 Z
* w% {/ [9 a. b7 c+ B) r3 s( @; ^7 ]
PR 1864164: Sheetmetal files contain incomplete property structures in the Material Data # w4 t) L# M/ l9 r1 a
PR 1869122: Automatic detection of add/remove wrong in this case 0 X V M. _1 ~) R& o
PR 1869195: add/ cut option automatically switches to add when selecting axis of revolution A+ `* O8 q% H- R; R1 [
PR 6599667: reduce time for processing result in Simulation
. H; f7 _0 O) R& zPR 6603049: Cannot enter value and units while in the Move command in ST4
! J K5 l. t5 Z$ h0 g! [4 A( YPR 1862713: Holes with threads cannot be selected for adding relationships
$ ^9 H# `7 I) i+ c `( {/ C9 KPR 1867683: Rigid does not work for hole features 5 h, \. b: h4 f3 ~
PR 6583151: Property overrides (simulation) is not taken into account
2 x* o4 U- U! `* h# j, A2 z
' u+ \4 f3 R) M1 x6 _9 [" r7 ~===Solid Edge Embedded Client=== 5 V& b3 t% Q: L# R
% t7 a& l4 {" B+ Q1 I, UPR 6420435: SEEC Problem with graphic display in Teamcenter Feature Library tab 9 T1 d/ A4 _ U2 l
" k4 _9 T& Y/ N( E6 @---
0 n }+ I% T# I3 R" z+ V5 Z6 N! W' TEnd
5 ^( x' n+ Y$ O6 a& t9 U- v--- |
