查看: 5215|回复: 8
[公告] BuiltWorks 3.0 已经支持 SW 2012
发表于 2011-12-27 20:51:27 | 显示全部楼层 |阅读模式 来自: 中国江苏苏州
钢结构插件 BuiltWorks 已经更新 支持 SW 2012
& I7 Y$ O6 R9 ?. V" A7 C3 r/ E0 N( W* [4 v
BuiltWorks Version History                                2011-12-09
. d( p9 @' z9 Z& F: ^/ WA new major version 3.0 (build 6337, 9-Dec-2011) is released                                                New major version 3.0 of BuiltWorks for SolidWorks 2012, as well as continuously supported version 2.1 and version 1.6 for SolidWorks 2011 and 2010, is available for download by registered users.2 [; h# A6 v3 k# ?5 M2 Z2 V
; d) h* W( B* N2 L. d/ ?3 j
. _, d9 P+ R3 B                        Some of the most important new functions and improvements of BuiltWorks 2012 v.3.0 are:/ ]8 }: _5 c! r% B* U% V
  • General features:
    • Compatibility:
      • Full support of SolidWorks 2012;
  • Structural modeling updates:
    • Added new international standards - Australian;
    • Icreased performance for member PMP loading;
  • Connection detailing updates:
    • Increased performances for Connection detailing;
    • Created a command which allows to recalculate markers of the Connections - improved performances;
Drawing generator updates:
    • Full support of Free Plates by Drawing Styles and Drawing generator;
    • Added feature which allows to assign Auto dimmensions under Generation Styles;
    • Refactored feature "Show selected documents" from Drawing generator window - hilights the selected object in graphic area;
Other enhancements:
  • Free Plate supprot for CIS/2 import/export;
  • Changed activation form;
Some of the most important fixes in this release:
' t! }: w( w* u' x; M7 P. L
  • Refactored connection graphical object position calculation for highlighting;
  • Fixed issue regarding saving End Plates material when copying the Connection;
  • Fixed cut-list issues with non English language systems;
  • Fixed issues regarding using custom styles for Drawings generation;
  • Fixed some issues working with Lightweighted models;
  • Fixied some issues with adding End Plates;
  • Fixed issues related to the incorect alignment of the Free Plates;
  • Fixed issue regarding exporting excluded members from the array;
  • Fixed some problems related to the editing of the profiles MAP file;
  • Fixed issues related to wrong members offsets export to Analysis software;
  • Fixed issues regarding document properties (Description Value) for members inserted by Path.
发表于 2011-12-27 21:32:06 | 显示全部楼层 来自: 中国江苏扬州
很好!什么时候能有CK文件出来那?
发表于 2011-12-27 21:42:17 | 显示全部楼层 来自: 中国福建三明
关注这个插件很久,希望有大师提供破解版学习!
发表于 2011-12-27 21:44:20 | 显示全部楼层 来自: 中国江苏常州
期待能用上!
发表于 2011-12-28 08:34:19 | 显示全部楼层 来自: 中国浙江宁波
发表于 2011-12-30 14:21:45 | 显示全部楼层 来自: 中国北京
2012呀 有支持2008的吗
发表于 2012-5-4 19:28:51 | 显示全部楼层 来自: LAN
Anyone has it ? Im looking for it and I cant found the last version
, ^. _# ^: h/ Q# R! M! d# @5 a
5 L" O( o0 X! T8 l0 }  l( k5 k4 RThanks
发表于 2012-10-15 16:02:45 | 显示全部楼层 来自: 中国湖南长沙
有破解版下载么?
发表于 2012-10-15 20:50:07 | 显示全部楼层 来自: 中国上海
什么东西,好高级,这插件一般的三维设计用不到吧.
