12小时前
查看: 4353|回复: 2
[求助] 翻译一下,看不懂啊
发表于 2012-1-1 16:33:14 | 显示全部楼层 |阅读模式 来自: 中国台湾
可否翻译一下,看不懂啊
7 x3 k$ E  n$ N9 \, g5 {ATTENTION!5 u6 w) e/ a2 p+ a
If you already have USB-Emulator for MC X4-X5 (HASP or NetHASP)  installed you can skip steps 1) - 5) and need only to run "mastercam_X5_crk.exe"' |& a6 B( W4 Q& W2 m% {# Z1 O
) z$ c. \$ o& T$ w1) Unpack a folders "USB-Emul_Win32" and  "remove_old_emuls"  to your computer' X- w+ ]9 W" d, ^1 X, j4 H6 B- A
2) Run "remove_old_emuls\delete_old_emuls.bat"  to CLEAR a Windows Registry from "blacklisted" Emulators
: i# E1 \9 Q  k7 h: H3) Run "mcamX4_MU3-dealer-nethasp.reg" or "mcamX4_MU3-industrial-nethasp.reg" (dealer dump has got extended functionality!) if you want to install Mastercam X5 with NetHASP SIM type.( q+ R/ ]6 c2 g
or6 @* J0 Z$ o' T5 f6 v: ^8 L
run "mcamX4_MU3-dealer_hasp.reg" if you want to install Mastercam X5 with HASP SIM type.
" `% R" l( e( K( K4) Run "install.bat" to install USB-Emulator$ ~% X' ^- j, h. [
5)  Install MC X6 v15.0.4.3 32bit as HASP or NetHASP SIM type.
; }: m8 n$ R6 V/ \6 I+ t8 K6) Copy Mastercam.exe from crack to <Mastercam X6 progdir> and replace original one
- y* t2 r) w# I0 h* K4 S+ F& ~+ W7) Enjoy3 r0 r/ J' o) G2 Q9 G2 \; m& X
That's all
发表于 2012-1-1 17:04:17 | 显示全部楼层 来自: 中国广东东莞
本帖最后由 tangcarlos3d 于 2012-1-1 20:56 编辑 : _: V; ^& s7 c% \# z
9 d! ^, C1 ~: d  V
试译如下:; V/ n/ q! u" A. k. f8 y' i
! F& d7 m( J& ?9 @2 l注意:如果你已经安装了MC X4-X5 (HASP or NetHASP)的USB-仿真器,则跳过步骤1)~5),仅仅需要运行"mastercam_X5_crk.exe"  e+ q' }, T3 H+ x$ u6 k
1)解压"USB-Emul_Win32" 和  "remove_old_emuls"  文件到你的计算机上;, g6 ~& [) E: j2 @
2)运行 "remove_old_emuls\delete_old_emuls.bat"以便清除windows注册表中的"blacklisted"仿真器;
5 H1 V4 e. Q3 v: t% @3)如果你要安装带NetHASP SIM的Mastercam X5,运行"mcamX4_MU3-dealer-nethasp.reg"或"mcamX4_MU3-industrial-nethasp.reg" (dealer 转储已获得扩展功能!)6 |+ r- f8 `+ `  _& q6 H8 ]$ X
6 W6 l$ V7 ~- B) A  G. Z3 N  v如果你要安装带HASP SIM的Mastercam X5, 运行"mcamX4_MU3-dealer_hasp.reg";0 a; U1 v2 [2 H9 v' i4 n/ o8 T! x6 n
4)运行 "install.bat"安装USB-仿真器;% J* X- v" i' Z, c, V
5)安装HASP 或 NetHASP SIM型的32位版MC X6 v15.0.4.3;
" \0 w9 |" R. Q: J( ?6)从crack拷贝Mastercam.exe 到Mastercam X6 的安装目录代替原先的Mastercam.exe;# s2 J) L+ n6 p: e" @5 g- n
7)享受(你的Mastercam X6 )乐趣吧。
' P$ e/ [; b+ j, t0 o( W% v就这些。
pengxiangxu + 5 应助
 楼主| 发表于 2012-1-1 20:47:36 | 显示全部楼层 来自: 中国台湾
感谢2楼大哥的翻译.......感恩
