1天前
查看: 7183|回复: 6
[已解决] win7 64安裝master camx6 安裝不了啊?
发表于 2012-1-27 11:13:55 | 显示全部楼层 |阅读模式 来自: 中国台湾
win7 32位元的可以.為何64位元的就不行; v4 ^! Y) N; U$ {* Z' _. Y
也有試試案F8安裝也是開不了ㄚ~6 t& I5 W& e9 ]% f$ H
有哪位大大可以只點一下.拜託^^
发表于 2012-1-30 21:22:41 | 显示全部楼层 来自: 中国广东珠海
本帖最后由 lixinqiou 于 2012-1-30 22:31 编辑 4 V$ ^1 ?' J0 y# {
4 Q. x4 L& ]4 x) N, ?
1# mi15988 同解!E文不好,麻烦哪位楼主翻译下:
, J3 F# y& c( \; b( r6 F4) Install a USB-Win64 Emulator/ w% G' z7 x% K' }' f4 O
You need a local Administrator rights to install this emulator for Win64!
+ W4 |' K1 j- v5 jOn Windows Vista64 and Windows7 64-bit you need to boot Windows in mode F8 > Desable Unsigned Drivers Enforcment !!!$ l1 A/ Z, L( h
4.1. Reboot computer (for Windows Vista64 and Windows7 64-bit you need to boot Windows in mode F8 > Desable Unsigned Drivers Enforcment !!!)
7 a* x- f- d7 u' \4.2.   Install usb-emulator drivers
4 i- C: Q$ \" R/ v, K  Start ->  Control Panel -> Add Hardware (Yes, I have already connected the hardware) -> Add a new hardware device -> Install the hardware that I manually select from a list -> Show all Devices -> Have disk -> Browse -> (browse to folder "USB-Emul_Win64") -> OK -> Confirm to install not certificated drivers if Windows ask for..9 g6 W+ G+ h2 j; w% R+ P" N
If setup is succesfull you have to see new system device:4 r4 v6 n$ d3 ?$ y# ^
Device Manager -> System devices -> Virtual Usb Bus Enumerator% _5 N/ f0 F5 m  v9 @
( u* I6 E2 W% X+ o7 e: W
5)  Install MC X6 v15.0.4.3 64bit  as HASP or NetHASP SIM type. , l3 F5 s& d1 f9 q' [
6) Copy Mastercam.exe from crack to <Mastercam X6 progdir> and replace original one
* T8 n# ]) b) o  W1 o7 W( \7) Enjoy
6 w0 ?+ s, G1 Y2 Z/ P多谢!现在知道了,不好意思!
发表于 2012-2-2 21:39:31 | 显示全部楼层 来自: 中国江西南昌
本帖最后由 wgchen0113 于 2012-2-2 21:40 编辑 1 I! p, Z0 B- z- C; l: W
* Y' t+ x5 }: U 2# lixinqiou , F% N+ X# V: L6 I
4)安装64位的USB虚拟狗. H& H7 L5 `1 T/ n
在64位系统下安装时要以管理员权限安装虚拟狗!
/ w- j8 T1 e2 P  |! _64位的vista和win7系统需要在启动windows时进入F8模式中的<禁用驱动签名>状态下安装虚拟狗!!!4 F: O0 y' L7 [
4.1 重启电脑(对于64位的vista和win7 进入F8模式->禁用驱动签名!!!), G, S: |7 T: `+ j& E* n
4.2 安装USB虚拟狗驱动
9 v8 e$ [2 e" x8 m/ c0 i: e5 q5)安装64位MCX6 V15.0.4.3,使用HASP或是NetHASP SIM类型。
  y7 q  k; l  {% m2 r6)将Mastercam.exe<Mastercam X6 安装目录>替换相应文件。: r, O$ |, k1 w+ p5 D! ]/ p* X
以下只是说明,非翻译4 n6 Y! F, p/ P
4.2步骤下的安装虚拟狗驱动的过程有很多种路径,我就直接说明关键的,不翻译了,在win7 x64下一定要在启动时按F8(就是进入安全模式那种),选择<禁用驱动签名>的那种模式启动windows。当进入桌面是点击<我的电脑>,右键选择<属性>,在窗口画面左上方处选择<设备管理器>,任意选中对话框中的硬件,点击菜单栏中的<操作>,选择<添加过时硬件>,点击<下一步>,选择<安装我手动从列表选择的硬件>点击下一步,点击<磁盘安装>,选择驱动目录安装驱动就可以了。如果安装成功在<设备管理器>中的<系统设备>中出现Virtual Usb Bus Enumerator。
7 x1 D  U2 M4 d& x8 Y( x要在x64的vista&win7正常使用MCX6,只能在<禁用驱动签名>模式下使用。& ^) ^# H' Z1 u0 [$ k6 S
我现在用的是2008R2,也可以安装并使用MCX6。
路过不买 + 2 应助
发表于 2012-2-2 22:19:00 | 显示全部楼层 来自: 中国广东珠海
3# wgchen0113
 楼主| 发表于 2012-2-3 22:39:54 | 显示全部楼层 来自: 中国台湾
感謝這位大大的指點^^
# h  H) K1 w0 m. m" O. I學習了~
发表于 2012-2-10 09:25:18 | 显示全部楼层 来自: 中国浙江宁波
本人安装已成功!!
发表于 2012-2-20 19:25:52 | 显示全部楼层 来自: 中国台湾
thank you...
