发表于 2007-7-18 14:39:10
来自: 中国天津
下了,谢谢.
' j5 e4 C4 ^4 A9 B+ o提供另一个版本:
6 a$ ]: g3 R- j& Z4 W' X+ g( n, L2 a0 B p6 K4.2的,在4.3上测试通过.8 x4 O7 n7 r/ t1 v/ y% @+ i2 F: L
% ^& [& x0 Y1 M- c: x, ~ F5 E. X- b$ T& Q2 V
4 m; Z# B: U" O% e4 W# t
FEATURE ame_token AMED 4.2 permanent uncounted 202F59A51CCB \3 y+ ?5 T! j- X$ s: F
HOSTID=ANY ISSUER=ZWT: c$ M# o3 }7 P3 T7 o
FEATURE amecustom AMED 4.2 permanent uncounted 91E86B3366FC \
6 ~6 O! E* Y3 b( ~HOSTID=ANY ISSUER=ZWT
9 i/ n4 O% P+ v3 t' SFEATURE amerun AMED 4.2 permanent uncounted E586B06CAE54 HOSTID=ANY \2 q J/ g( l; v) ]
ISSUER=ZWT* E( E/ |! a( a. ?. x; w1 N0 F
FEATURE ameset AMED 4.2 permanent uncounted 76C4FEBBF1C7 HOSTID=ANY \4 ]* z! O! n9 Y# ^% ^0 H- n0 T
ISSUER=ZWT8 Y( h1 ^ `6 I L
FEATURE amesim AMED 4.2 permanent uncounted EA1CBAADA64D HOSTID=ANY \
5 i1 O/ a, h* Z5 vISSUER=ZWT
8 V3 j8 O W9 j- X) ^4 kFEATURE amesim_runtime AMED 4.2 permanent uncounted E5DF7CED618B \
; S- F% d! q, A: }" ]HOSTID=ANY ISSUER=ZWT
) P8 |0 A2 Q9 ~ A" @: X* _FEATURE animation AMED 4.2 permanent uncounted 9C454BAE02D3 \
" H: @7 l& u$ @* N, U7 u$ VHOSTID=ANY ISSUER=ZWT& d1 q& @" P* `
FEATURE build_air_conditioning AMED 4.2 permanent uncounted \
+ ~' Z& A0 a- V/ x% N, c* `8 b" `663EB892F730 HOSTID=ANY ISSUER=ZWT
) y, z& ]: d% l6 H, n" `FEATURE build_amebel_hydraulic AMED 4.2 permanent uncounted \- C* i: Q! D; Y" V
BFA25ABCEC20 HOSTID=ANY ISSUER=ZWT% e, v/ U x' l, r# H* w$ k. h
FEATURE build_amebel_pneumatic AMED 4.2 permanent uncounted \' M% u; G3 r! P* N' x( M: e
EBE1FE1AF358 HOSTID=ANY ISSUER=ZWT, _8 ]) m1 |9 Y! }( s; |1 q/ h
FEATURE build_cooling_system AMED 4.2 permanent uncounted \# r2 G- h9 N7 F/ q) H7 Q
9C3EE3762275 HOSTID=ANY ISSUER=ZWT
9 u8 H; q/ `& X; bFEATURE build_drive AMED 4.2 permanent uncounted FE60DA44B52A \; M. ?" F# d' L3 J
1 J% o! l4 T+ n& MFEATURE build_drive_cycle AMED 4.2 permanent uncounted 2EA858322D9B \, G' ?/ ^; ^8 E& K5 n V% y: k
# c1 s. r) I9 mFEATURE build_electric_motors_drives AMED 4.2 permanent uncounted \
6 h* w$ y. d, n& S/ z- l+ pAE080194D1B7 HOSTID=ANY ISSUER=ZWT
6 s; W" V; ], _% _0 S RFEATURE build_electro_mechanical AMED 4.2 permanent uncounted \
* v- |4 ]4 x; T( q25384F227788 HOSTID=ANY ISSUER=ZWT% @! R9 m! R/ T1 ` C" e/ L
FEATURE build_engine AMED 4.2 permanent uncounted D09D4235A1C7 \& N7 @3 t: F& |# M6 ]# R, q* J
: ? m) s1 A& ^+ A YFEATURE build_exhaust AMED 4.2 permanent uncounted 6214C3AB3A62 \% K5 G W1 H, ]. I
0 E6 B G8 v; PFEATURE build_filling AMED 4.2 permanent uncounted 7054B355215A \
- r/ n W7 S9 I" b' | p' OHOSTID=ANY ISSUER=ZWT
$ Z. |% ?+ t, r2 v. KFEATURE build_hcd AMED 4.2 permanent uncounted 3C6A23140582 \
% t1 k7 @( c/ v" Y0 f" t- V7 ^HOSTID=ANY ISSUER=ZWT) D$ C$ U5 i6 C4 }
FEATURE build_hydraulic AMED 4.2 permanent uncounted 9E12D3BFA3FF \# M+ T" g3 ?3 o4 V4 D8 e8 x
HOSTID=ANY ISSUER=ZWT1 l! E% M P. B; L+ |7 M
FEATURE build_hydraulic_resistance AMED 4.2 permanent uncounted \& Z1 f7 k! A! [7 P
4F385FB99F30 HOSTID=ANY ISSUER=ZWT
4 i: W; \( D* e0 y6 x6 T5 Y7 qFEATURE build_pcd AMED 4.2 permanent uncounted 87A68BACF5CA \
5 x1 ?8 i( E* A. R; O( dHOSTID=ANY ISSUER=ZWT
& W* K- a" V- {% r% F8 GFEATURE build_planar_mechanical AMED 4.2 permanent uncounted \
9 ]0 S2 |" f, _8 R98E5FFD7884C HOSTID=ANY ISSUER=ZWT
8 \. E& r- e! K, R' j5 cFEATURE build_pneumatic AMED 4.2 permanent uncounted 9F73E4AAC227 \
! L. Q' g" A5 T8 q9 m! DHOSTID=ANY ISSUER=ZWT
- `1 N/ x! w" q2 {, y8 |FEATURE build_pneumatic_comp_design AMED 4.2 permanent uncounted \
) u6 }5 X; l. Y; m26A1FA08C127 HOSTID=ANY ISSUER=ZWT
! I2 m! `2 f5 J/ P3 JFEATURE build_powertrain AMED 4.2 permanent uncounted AF16140C68A8 \. p; E8 n z% `+ H
HOSTID=ANY ISSUER=ZWT9 ?1 |+ U8 N5 A# p9 |$ ~
FEATURE build_thermal AMED 4.2 permanent uncounted 3FF1D9C6E6D1 \- Q' ^8 C0 n# |/ ~" x
HOSTID=ANY ISSUER=ZWT. g# M: L+ [! c2 r, b; X: H; {- R' Z
FEATURE build_thermal_hcd AMED 4.2 permanent uncounted 6771632CC01E \
0 F6 \$ u( _6 v/ v, E$ q& cHOSTID=ANY ISSUER=ZWT' K2 d5 Q" i4 L; X1 R
FEATURE build_thermal_hydraulic AMED 4.2 permanent uncounted \
( h; B B, g: U3 b9 ]1 V- iB8AE1A06F863 HOSTID=ANY ISSUER=ZWT6 J+ [. W4 g: u; Y# @6 _; P- I
FEATURE build_thermal_pneumatic AMED 4.2 permanent uncounted \& P$ ^' v, n' L" x- F' z: _: n
E33129DF89E7 HOSTID=ANY ISSUER=ZWT# l) I* S8 Z% e2 z. x- L
FEATURE build_thermofluid AMED 4.2 permanent uncounted 3A2A949983EF \
4 n+ M& G+ c9 x" o2 |HOSTID=ANY ISSUER=ZWT
$ i6 @& M, M. D: ?FEATURE build_transmission AMED 4.2 permanent uncounted 5AFED4E5981D \
1 W$ v3 U$ A% PHOSTID=ANY ISSUER=ZWT# B+ I! W% o, F. j
FEATURE build_two_phase AMED 4.2 permanent uncounted A7001284F022 \0 U5 x& l6 B6 g1 ?0 I7 G
HOSTID=ANY ISSUER=ZWT' K; T4 G$ {% _1 c! {
FEATURE design_exploration AMED 4.2 permanent uncounted 0F7FD105ADF8 \2 o! L- w# U& p J# g! `" A+ J
6 D0 J3 Y( m* W2 NFEATURE design_exploration_runtime AMED 4.2 permanent uncounted \
/ X6 n; d P3 E) q: \0D7D6D6AFD70 HOSTID=ANY ISSUER=ZWT
2 k4 `) |- [( f, c6 g1 H7 TFEATURE design_exporation AMED 4.2 permanent uncounted 58207CDD7E11 \' i" A: [5 K( J& I
HOSTID=ANY ISSUER=ZWT: T4 c$ K0 Y- E2 z
FEATURE design_exporation_runtime AMED 4.2 permanent uncounted \1 d/ Q% Y; P l! {5 Z
6444626AE56E HOSTID=ANY ISSUER=ZWT
, n' q2 }% [# g/ E% Q& GFEATURE export AMED 4.2 permanent uncounted 63547C06135A HOSTID=ANY \$ C7 \* P5 W. Y$ N9 `# x
ISSUER=ZWT |- M1 h: i& R# t. e9 r
FEATURE export_runtime AMED 4.2 permanent uncounted 4CF7B76D8FE2 \
0 ~) o7 C7 {' I. R$ M- hHOSTID=ANY ISSUER=ZWT
2 f5 c. g# c8 g" l' SFEATURE ifp_c3d AMED 4.2 permanent uncounted 7648AC0585F7 HOSTID=ANY \
% s8 b' {1 o9 G n3 n% a) v; qISSUER=ZWT- C! U- ?* U/ ^) v( K
FEATURE ifp_c3d_runtime AMED 4.2 permanent uncounted 9F421192566D \
1 h% w5 A/ u9 I2 B5 }' Q1 A! kHOSTID=ANY ISSUER=ZWT0 ~" [. _" h( W, j6 b& a
FEATURE air_conditioning AMED 4.2 permanent uncounted C4C1175B6034 \
. w7 ~& ^9 G, y8 w `0 B; pHOSTID=ANY ISSUER=ZWT, v6 P' ^8 G$ Y
FEATURE amebel_hydraulic AMED 4.2 permanent uncounted 013482A58E02 \# j. ^! s6 _! |3 E& d+ L) j
HOSTID=ANY ISSUER=ZWT. ]1 t+ t) Z, `( q
FEATURE amebel_pneumatic AMED 4.2 permanent uncounted 37BBB3C7B878 \
5 c5 k1 }5 u. ]! c) L# CHOSTID=ANY ISSUER=ZWT
. X' r( W+ ^% j9 ~% yFEATURE cooling_system AMED 4.2 permanent uncounted 246C168C9EBD \& V# z G! N9 _6 ^2 W" P( D6 c$ A
2 W \7 w D: u( x! u) C0 k0 \FEATURE drive AMED 4.2 permanent uncounted 76A8725A594E HOSTID=ANY \4 N! |$ S. ?/ z/ y' I) j% L
ISSUER=ZWT
7 {! t6 }/ j4 d0 D( pFEATURE drive_cycle AMED 4.2 permanent uncounted EBA54C0203B3 \
3 u& d. I: M& @ `7 U, t4 aHOSTID=ANY ISSUER=ZWT! B8 B8 w" l- N, |( H. m
FEATURE electric_motors_drives AMED 4.2 permanent uncounted \
0 [; Y, u0 D; U) I2 C8C597F7D2050 HOSTID=ANY ISSUER=ZWT
9 z% E0 t' ~! k3 d; KFEATURE electro_mechanical AMED 4.2 permanent uncounted 3171E5ADBCAA \5 r! G4 O3 [" c
/ ^5 ]7 z8 U) E: D% fFEATURE engine AMED 4.2 permanent uncounted 1C40589CBF4B HOSTID=ANY \1 u& b/ k' i$ y j% S" t* ], D
ISSUER=ZWT
0 M% v2 N* J$ [( |FEATURE exhaust AMED 4.2 permanent uncounted ECA2B8B505C1 HOSTID=ANY \: q& n5 i0 ?1 e/ t3 \
ISSUER=ZWT
4 j. ]9 u# K2 TFEATURE filling AMED 4.2 permanent uncounted D8E5AED9EABE HOSTID=ANY \6 A# g, l R( R. ]
ISSUER=ZWT% w# J# m7 ?7 |& r
FEATURE hcd AMED 4.2 permanent uncounted 1A193ABDBFE8 HOSTID=ANY \
1 Y4 T. J0 f+ O) Z& {% R* FISSUER=ZWT. J8 @& b9 i' w5 O) C% c( h
FEATURE hydraulic AMED 4.2 permanent uncounted 13423A0D94ED \7 `2 x. r- N1 }) c+ Y1 e
HOSTID=ANY ISSUER=ZWT9 y2 Q- j) p8 b3 c; t$ G- b
FEATURE hydraulic_resistance AMED 4.2 permanent uncounted \
3 ]9 Y; \/ |8 y0 P715B9ECC8F6E HOSTID=ANY ISSUER=ZWT: u1 h9 Y: g' P/ D4 b, l- v
FEATURE pcd AMED 4.2 permanent uncounted 0C0FC255EF28 HOSTID=ANY \
5 t7 s' z* P4 Y2 [4 L0 rISSUER=ZWT* f% k/ c. m% h& T( q& ]+ n8 L, e
FEATURE planar_mechanical AMED 4.2 permanent uncounted B944BF70CA2D \' \2 g* n2 z1 ]+ K/ S( S
^! r J; M; y5 H$ p oFEATURE pneumatic AMED 4.2 permanent uncounted 1CDFC01B978F \2 j" y4 J+ Y2 ~9 b0 E
HOSTID=ANY ISSUER=ZWT J+ I% d2 y3 H V1 L+ y0 ?2 }
FEATURE pneumatic_comp_design AMED 4.2 permanent uncounted \
* t1 r4 ]% g8 W( N$ l5 \4A5F54F1A4AE HOSTID=ANY ISSUER=ZWT4 t' b0 A' T7 k ^7 n$ [
FEATURE powertrain AMED 4.2 permanent uncounted 85E9C573D111 \
2 { T B! M% q# XHOSTID=ANY ISSUER=ZWT
8 `) r0 o' o/ m) @0 A( ?$ O0 |$ SFEATURE thermal AMED 4.2 permanent uncounted 5F1533D90500 HOSTID=ANY \6 p0 f0 N# `* e6 k( X. |
ISSUER=ZWT7 F2 U# @4 z$ r+ C3 y1 p
FEATURE thermal_hcd AMED 4.2 permanent uncounted 7896EBDB0408 \4 h; M, b' D' c' l
HOSTID=ANY ISSUER=ZWT6 j, o% `) I" G* o& L# ^% ?
FEATURE thermal_hydraulic AMED 4.2 permanent uncounted 264E58D040BE \; L$ _9 q* P G x# T- X
HOSTID=ANY ISSUER=ZWT( o o" s0 H$ G# `7 I; D
FEATURE thermal_pneumatic AMED 4.2 permanent uncounted 18648A9A1776 \
+ q- ^1 D* q* w; xHOSTID=ANY ISSUER=ZWT- U+ t$ y/ s0 I' L* q
FEATURE thermofluid AMED 4.2 permanent uncounted B2A5399453B0 \
1 c# b7 E; H' \) E5 O' fHOSTID=ANY ISSUER=ZWT
+ j8 k9 N. e/ w% r9 U0 w% jFEATURE transmission AMED 4.2 permanent uncounted 56963E37828A \7 B( P& _# L( ]
1 V, w$ R! p! |: U3 P& ^1 I8 gFEATURE two_phase AMED 4.2 permanent uncounted 831E4355E158 \$ B5 F# N- F( g F0 S
HOSTID=ANY ISSUER=ZWT( z1 e: P1 o+ F. H. F$ r) [
: \! z7 z$ C6 x4 B1 m9 t5 W
* `1 j+ ]; m N0 c& e6 X' A( U' a把上面的字符存成license.lic放到没有中文路径名的文件夹下. |
