KeyShot 3 升级更新 - 3.0.99 PJ发布(2012-01-31 12:00:19)
) G2 |& P# \# U+ {; l! e# a- U+ m) \0 M! L
一个新的KeyShot 3更新版本已发布. 它修复了以下错误问题:
, J: ^8 J; |: V/ q+ q3 L1 N3 `' O1 k$ f
3 Q; j! |* g4 U1 Q- Improved reflections on rough materials
- Copy and paste of inclination animation type
- Fixed movie compilation error when rendering out animations in individual chunks
安装包下载更新 / n* i# q, I3 I* b; h* h+ d( ]5 }( ]/ D
完整安装包:
- J) D* p. K3 ~9 ^Windows 32 bit: http://download.keyshot.com/keyshot_w32_3.0.99.exe
6 O1 M0 B6 [4 jWindows 64 bit: http://download.keyshot.com/keyshot_w64_3.0.99.exe
; |( v Z" L% P* k! _# z2 ?3 I* `MAC OS X: http://download.keyshot.com/keyshot_mac64_3.0.99.pkg
" q9 Q; v; O3 `2 q
+ ]9 z: H+ T* F3 j! t2 m升级安装包:' Z. h% e( T2 u/ K3 D) @5 A! n
Windows 32 bit: http://download.keyshot.com/keyshot_w32_3.0.99_update.exe
, b1 N# \# H% D$ r+ d/ K iWindows 64 bit: http://download.keyshot.com/keyshot_w64_3.0.99_update.exe
8 q5 u5 D) x0 ~ `* CMAC OS X: http://download.keyshot.com/keyshot_mac64_3.0.99_update.pkg0 g' u/ b6 b* y
0 k6 q! [8 H$ F/ e3 l; R# b! e1 h! M! Q, \
PJ文件下载:http://115.com/file/be8gl2po# (仅PJ补丁文件)
7 C( e9 j) C) t: g- P" ?4 Z, U
8 u; t4 o. `; {) k如果你是首次试用用户, 请继续阅读.. b7 t4 T& B, I: H" f' F
8 I/ i+ O' k6 U3 q试用版本限制:
# N' f' i! V2 C9 B. U- e4 S& mThe trial version you are about to install is a fully functional version of KeyShot except for the following:
2 F' u2 U# e( U4 q" I4 o; l- Your saved images will be watermarked.
- You cannot save any of the scenes you set up.
- You trial is limited to 15 days per release (e.g. 3.0, 3.1, etc.) per machine
/ f3 G4 S. I9 q; ~3 r- J
如何开始: h# @! L0 y/ Y7 a8 o
- After installing KeyShot, the software will start automatically.
- Please select "Try".
- Fill in the information, and select "Activate".
- KeyShot will connect to the server and automatically receive a license. Skip steps 5-7.
- If a server connection can't be established, save the "license-request.txt" file.
- Send this file to license@luxion.com.
- You will receive a license file shortly.
* i% U$ X# Q" m0 f& y你的首次渲染:
# ^9 N- H3 d. }- ]; rFollow the 6 steps outlined in the quick start guide found under the "Help" menu. We also have a getting started video you can view here.
' C0 R" u7 H4 `( K9 h/ J/ Z4 S$ v4 X. I5 L) E' G
KeyShot supports the following file types on both Mac and PC: - ALIAS 2012 and prior
- AutoCAD (DWG/DXF)
- CATIA v5
- Creo
- Creo Elements/Pro (Pro/ENGINEER)
- Inventor 2011 and prior
- Rhinoceros 4 and prior
- SketchUp 8 and prior
- Solid Edge ST4 and prior
- SolidWorks 2012 and prior
- NX
- IGES
- STEP AP203/214
- Parasolid
- OBJ
- FBX
- Collada
- 3DS
- JT
In addition we provide direct plugins for Creo, Pro/E, Rhino, SolidWorks and SketchUp. Please goto www.keyshot.com/keyshot/pluginsto download and learn more.
K, O" R; |4 ]; U+ ?/ O/ R% I* u* x6 I, M6 O
PC 机配置:
2 P/ o/ _5 v0 z$ ~! ~2 G+ A- Windows XP 32/64 bit
- Windows Vista 32/64 bit
- Windows 7 32/64 bit
- AMD or Pentium 4 processor or better
L: B; E7 G2 iMac 机配置:" H$ |; D0 f6 Q
- INTEL-based Mac, Core2Duo processor or higher
- Mac OS X 10.5 or later
- 3 button mouse, incl. Magic Mouse plus MagicPrefs
+ S( R* b* p0 P# N1 g0 K: R
一般系统配置:
. S) a, b* _/ t4 t( |$ ^- Minimum 1 GB of RAM
- Minimum 500MB hard disk space
- 3 button mouse
- Monitor resolution of 1024 X 768 or greater
- Any graphics card (nothing special required)
- Internet connection for product activation
Enjoy!7 D% s! q0 L1 @4 N
% O' T$ X* ]9 G/ |' J! w8 l, sYour KeyShot Team
; S. ~( G8 S% `5 y6 m4 FFor your records, here is a copy of the information you submitted to us... |
