A、常规流量换算:( A) g8 j. l2 l2 K3 q0 @
1m3/min=1000L/min=35.32cfm, G, v* m! }9 e$ ~& F, v; r f
1L/min=0.001m3/min=0.03532cfm
: O0 W& ]1 H+ O0 J1cfm=28.32L/min=0.02831m3/min' H$ P4 k# Y/ R t- g' z5 `
B、常规功率换算:
2 p2 M7 E9 t0 l7 d2 x8 Q1KW=1.34104HP
: S6 e- |. o6 H( D! \5 R" V1HP=0.7355KW$ z4 U l0 E! @% X1 S
B、 常规压力单位换算:# l5 T7 W; S* F" d& Y
1Kg=0.981bar=0.0981Mpa=98.1Kpa=14.22psi% k( d0 M9 j$ ~, J
1bar=1.02Kg=0.1 Mpa=100 Kpa=14.5psi2 P0 J7 y U" ^9 k4 u. u- ?, }8 M
1 Mpa=10.2 Kg=10 bar=1000 Kpa=145 psi
* x2 B% S* ?2 l9 v1 psi=0.07031 Kg=0.06893 bar=6.893 Kpa |
