请高手改进代码
% M$ j! n c4 z4 S, f$ U2 |+ Y
4 D+ e3 l# `! j: b: f0 h请各位高手指点一下:4 Q6 I5 m3 z9 h: R5 s/ w- Q
编制了化工容器中常用的立式圆筒体进行开孔的二次开发程度,其中
0 Q j7 `" o5 g3 F: R( o; ntext1 为开孔角度
3 v+ j5 a5 u( K( H [( V# Z: h: ltext2为开孔高度2 x% i5 ]; w" n; P2 ^! a' G( i
text3为开孔直径 \5 ] B- C& e1 S7 b& v
程序在第一次运行时没有问题,但在第二次运行时没有达到指点效果,请熟悉化工容器或二次的高手指示以下代码,* O8 ]( C0 j M$ i1 _
问题可能出在boolstatus = Part.Extension.SelectByID2("", "PLANE", 0, 0, 0, False, 0, Nothing, 0)代码,但不会改进,请高手指点
0 z% h1 X, S, U8 \0 U1 Q% d" T3 J: ?* T) ]8 u
Dim Part As Object
$ W" g, w, Z6 L0 Q B* |7 [/ }Dim boolstatus As Boolean5 n4 F8 Q# W* c1 P5 M8 H
Dim longstatus As Long, longwarnings As Long
; W5 y% A3 B* W3 Q5 N2 E2 l0 H' y3 u* f" H, Q
Private Sub cmdcreate_Click()
6 F: e1 ^# }8 R1 Z [9 C" ^6 [" `; [
3 `+ J+ E* s, L2 [& `0 B
Set swApp = _" \; X% ^' U; I7 u
Application.SldWorks
; x8 ]5 y% |) R2 D" s9 }0 p$ F- c/ {+ _8 P1 v2 B
Set Part = swApp.ActiveDoc
9 z$ [ Z# R0 z8 f/ J$ I" F& tConst pi = 3.1415926$ o# U3 G4 [; D; b6 i) b- I
boolstatus = Part.Extension.SelectByID2("前视基准面", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
+ d7 i7 @. K6 C+ P! qPart.SketchManager.InsertSketch True
! X8 T' i8 r! \2 t4 @& JDim skSegment As Object: K J- |$ N1 x/ E* Y: S
Set skSegment = Part.SketchManager.CreateCenterLine(0#, 0#, 0#, 0#, 0.3, 0#)
5 k$ A9 J4 T* h1 q+ B a" zPart.SetPickMode: k* o q) C4 b5 n2 v
Part.SketchManager.InsertSketch True" n6 a7 S# b: Y6 L) C* i9 c" g
boolstatus = Part.Extension.SelectByID2("前视基准面", "PLANE", 0, 0, 0, True, 0, Nothing, 0); A( s1 f7 ?- Q* u; q8 b
boolstatus = Part.Extension.SelectByID2("Line1@草图2", "EXTSKETCHSEGMENT", 0, 0.1580207116827, 0, True, 1, Nothing, 0)
5 P: x! b% j! E" gDim myRefPlane As Object
: j8 D9 P9 q, zSet myRefPlane = Part.FeatureManager.InsertRefPlane(16, (Val(text1.Text)+90)/ 180 * pi, 4, 0, 0, 0)8 f: Q5 F( N+ r
boolstatus = Part.Extension.SelectByID2("", "PLANE", 0, 0, 0, False, 0, Nothing, 0)% }, e/ x0 A3 _0 y# X) u
Part.SketchManager.InsertSketch True+ p2 x T% |" ^
Set skSegment = Part.SketchManager.CreateCenterLine(0#, 0#, 0#, 0, Val(text2.Text) / 1000, 0#)- F1 L/ j3 O0 R! m: z4 N
Set skSegment = Part.SketchManager.CreateCircleByRadius(0, Val(text2.Text) / 1000, 0, Val(text3.Text) / 2000)
: G) F4 x* j2 W9 v C$ N8 r v9 Q) Yboolstatus = Part.Extension.SelectByID2("Arc1", "SKETCHSEGMENT", 0, Val(text2.Text) / 1000, 0#, False, 0, Nothing, 0)2 p; n( U7 a7 o' I# z' s
Dim myFeature As Object3 H) H9 x _8 ]! j) ~' X7 U5 b
Set myFeature = Part.FeatureManager.FeatureCut(True, False, True, 1, 0, 1.5, 1.5, False, False, False, False, 0.01745329251994, 0.01745329251994, False, False, False, False, False, True, True)
% k- F$ _8 r8 u0 X% z- zPart.SelectionManager.EnableContourSelection = False
' l, J% v' n( T) G" {End Sub
) i' V+ m0 E+ |, \& s6 c
% i6 N) c/ d8 G6 d! s* x$ i& b( ^4 t2 o {1 }6 O. n1 F
+ l; g% P/ V) A& c0 V! l, ]
Private Sub cmdexit_Click()5 H" M1 E6 @- |
End5 x1 y( S G2 t$ t6 W/ R
End Sub
+ k" `1 ], \7 p4 b1 L9 V: [* w2 N
Private Sub text1_Change()9 k0 j% p1 `5 ]" J3 }: |8 O0 p
% a- p K( e* s9 B+ m9 [6 j1 X9 i
End Sub$ r- x3 _, _* k4 s( I, P% ~
# k+ Q1 R d3 Q1 v$ X: {Private Sub text2_Change()
5 r" u' ?) e. _/ F! y, y& a
: g1 q# V8 ~4 y& S7 b1 WEnd Sub
+ h! O/ q! n: |9 R" n( L7 @: l! T( {$ Y
Private Sub text3_Change()5 n# |& S4 v. d4 u1 C% Z
- k& a% D0 z( u8 h- i% H, e; i
End Sub |
