楼主 |
发表于 2012-3-24 00:56:41
来自: LAN
Release Notes:# r' Z* ?. s) c- r
8 h7 f* m. e) e' s
; \3 L2 C7 G: D2 ]Product: Solid Edge & p+ C9 S% R# } J" u% _
Version: 104.00.04.05
" K8 G7 @3 g" [- l; p' k; M6 ]Date: 29-Feb-2012
) I+ X, [( ~! `3 J' T/ B( I _1 ?+ U9 ]& s3 n4 t4 h# k0 y
Maintenance Packs are all inclusive and can be installed on top of the base
! h4 e: N/ F" U8 \- Trelease or any released Maintenance Pack.9 s. Z4 C+ O% T+ n
2 M- s& F, ~5 E, x/ L1 s% AThis Maintenance Pack can be installed on top of Versions:
( _+ U9 j: C0 \6 n! v) [7 L104.00.00.82, 104.00.01.08, 104.00.02.05, or 104.00.03.05
7 O1 h3 c% Y8 T: O4 q" ~6 i* T m+ @
" ^/ G: _- |. e# }0 K5 \" X7 l$ O" V6 Z: q" \! {
--------------------: n; o9 f L' ^, ~8 {2 P
End of Release Notes
; L# e% d0 |: h8 k% r! @4 p) s6 J+ H--------------------
- j( i6 M6 N, ]* h9 W8 L+ b& q) |0 l: E8 I) R) W, L6 R% ]( V
-------------------& H6 n, C. b: {+ T) A4 x( P+ I, k: Q
Installation Notes:% Q5 M3 B+ c2 d% g- |
-------------------0 U3 a: n; N# K7 h. _/ e
2 B3 w9 T$ h5 T% Z2 Z( G( U
After downloading the Maintenance Pack to your machine, unbundle the zip file and
2 D+ k+ _- G+ j1 t) P: N& ^! Ythen dbl click on exe to install the Maintenance Pack.8 Q$ @+ D4 N H& r7 E% Q' g
& X3 v$ G$ f: w' S& CWindows 7 Installation tips: In addition to turning off UAC, right click on the exe + u1 a& X$ A' N& ~. f) |
and select "run as administrator" to complete the installation. , s5 ?4 U- M6 @1 \/ D$ j R( X
# ~' q# s0 j5 ]7 A+ C8 ^7 O, X
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing 4 ?; ?/ `) U7 s
Solid Edge somewhere other than the default “Program Files” folder. Install in a location & \# w8 _ ^: E; Q8 E5 d! V. C
like c:\SolidEdge\ that the user has full permission to write to.
: P: ?( ]/ f+ Y2 O3 h7 L3 _# j1 ~1 }7 x7 F
' a Q1 r( F% VEnd of Installation
' `. }- S" A+ m- i. H-------------------
9 X4 `3 s% i. x& ?3 w8 ]8 A2 [9 Z, N' T
" @2 t3 g# D6 w( T5 i' lThis Maintenance Pack addresses the following PRs:3 g5 R( q3 u' k" Z$ q
6 k3 c; U$ b/ b4 u; |$ E. ?, Z# K& H/ ~# w6 @' W5 M
===API===. P, u$ G. `+ ^. B/ j# g) d
9 A" {5 S; g7 ]4 t
PR 2186499: Added ArrangeWindows API to application automation object
5 X4 J2 P ?5 G3 j# _) [7 a' CPR 1880652: Regression in ModelNode.IncludeInPartsList API
3 x) Z% r" b6 a0 F3 UPR 1870918: Error if use API function Feature->Item()
) W0 y: O* x8 @1 R- Y' p1 CPR 1866671: Skip the Query of non-need Parameter in API SaveAsFlatDXFEx$ W$ _. L9 c B G7 Z. \, E7 M8 I
PR 2185290: ReBend api fails3 ~! E. ~# n" `8 D' F* Q
0 I4 d# w, v) e# z7 v+ e0 B
===Assembly===
9 {7 `. z3 s6 Q7 O0 U/ d( p) g- k' z" f$ P) G+ u! u. @& q0 u G$ q
PR 1878230: Performance problem caused by a loop in the associated graph
; H: }: `- a$ T0 |! oPR 2177784: Memory usage goes up when you put the cursor over a Simplified Assembly! B" a) v8 l/ j m" C# f4 f6 c
PR 2184189: Wrong fittings presented after modifying a pipe route
( G- T# P# o8 |; L$ wPR 6637551: pathfinder locate is not working in ERA manual explode command/ r* Z( S0 @3 I3 w2 v: r& v0 ^% Q
PR 1871721: Pipe route being offset after changing an indirect parent
! H/ O/ x: k4 F9 n5 |8 P6 N$ \" KPR 6644521: SW Translator fails to translate Muti-Body files
) V) F! {, v1 D9 z5 cPR 1873964: Web Publisher not working on a 32-bit installation. J# h' L- ~$ o. b8 v! v% U
PR 1875446: Inconsistent item numbers in Draft due to replace
: J7 a5 J; g* j, vPR 1884297: cannot reorder copied sketches in part pathfinder& }- e5 Y3 _( A- q& M
PR 2180814: Editing this part file causes Solid Edge to crash e `3 l( U I8 y$ N+ k8 R0 n) U
PR 2183520: Resolved random aborts in draft
6 \7 T; a0 E8 }3 EPR 6587167: When transferring renamed components, they take on new names7 V( V) |/ I- |3 I) p
PR 6621873: Weld bead leaks under part4 Q" ?) Z% w6 L4 H
PR 1884912: Display clipping does not work correctly when assembly features are present
* O2 f+ J" o( l) HPR 1682348: Assembly features not working on frames and normal features in subassemblies! }# `, H' A# d/ `( ^5 D- q
PR 1874030: assembly features missing in subassemblies of FOA members0 d& N$ N3 g5 L+ f
PR 6421755: Failed Constraints after Replacing Sub-Assembly in Assembly
( ^" [. Z- V% z8 U( J. JPR 6612747: Abort after using Animation Editor
6 P) d2 v5 ?8 @ U% A9 y4 X/ K! h. ]4 x/ K7 k! ^5 W. f
===Draft=== / U# q, d* t) T, G* A
" n' W, [2 L% b( F' h$ i3 L# L
PR 1878737: Layer is lost when Parts List is opened in ST2 or later
* Y7 j. v- @ l/ \' R z) MPR 1879397: Empty callout symbol is visible on created pdf and print
) J% W1 K2 v2 @PR 1882031: Scale moves position when legacy file is opened& B) J4 Z1 I1 f J# p7 }
PR 6607642: resolved random crashes
) h) g5 N$ I: D6 Y! aPR 6629915: Length of Weld Not Displaying Correctly, and Draft Crashing
+ V- H% u- c* H8 J- {PR 1878851: Property text doesn't update after change to parts list" R7 C9 h' D* G/ [4 m/ I' c
PR 2186167: updating a broken view with broken out section caused dimensions to detach
" \. d) {1 l( E6 ^0 f7 XPR 2188107: User painted edges are appearing in file open in ST35 n# N8 ^+ U1 \; M& F
PR 1882594: Solid Edge is crashing when you rename an opened block4 @" M8 G3 s$ y3 B' ^$ K
PR 1884347: Format codes to modify property text output cause reference to change
, b6 v! L# X4 SPR 2174995: some lines not displaying when the V15 draft file is opened% I- l. {: X' m
PR 6630591: Resolved a performance problem when locating callouts: c& _0 z P( m+ f/ }2 V
PR 1883798: Unable to save assembly file to a 3D PDF with a D&D License
' h3 J. y3 M7 r$ g) lPR 1886005: measure area result varies in this file$ Y9 S% O1 d* K- {
PR 2174959: Unnecessary hatching is displayed in this draft file' y/ O8 Z3 q* F [% i3 B& S
PR 6646879: Point added to leader can only be moved below the horizontal line
& ?8 p4 a q7 G N/ [9 J1 ^PR 1883256: Multiline textbox from ST3 changes justification when opened in ST4) `& I6 M& f+ d7 c
PR 6640013: Stretching Connectors locks Solid Edge) ^2 M& [' R2 V, a3 W
PR 6669348: DV layer override capability erroneously displays hidden layers, G$ y- ?# l# F( L% M; p) Z# s
* ~3 S! w( |0 ~. M/ t0 h0 [% I
===Part/Profile/Sheet Metal=== # s% k* X, `# r$ R r1 Z* a
0 q4 ` f2 ~2 H# m
PR 1869930: Conflicting relationship message is missing # w$ f' q" z' L' x
PR 6645209: Cannot view unprocessed plots for buckling study1 D1 V# b7 Y0 O" r
PR 6645361: Unexpected result trying to move a part face
7 A; F1 x0 N' ]( j3 ^PR 1880039: hole diameter does not match variable/ part/ draft6 W0 C* \. z% g; d6 y7 h: W7 J
PR 1884859: abort issue from add draft command" g& G L! N6 F: m8 A, g& t
PR 6619201: Components not locating in boreline order from Assembly- B, O! r7 E# o
PR 1880722: Mounting boss problems after modification$ M! y$ U: F9 H5 f$ \
PR 2187904: Abort when placing a coplanar face relate in Assembly. e$ C6 l1 a" w! i. o$ p v& E6 C3 P
PR 6664590: Crash on Copy/Paste of dimension with class fit tolerance1 i! P0 H/ R( l
PR 6645336: Edge crashes on app close after going into FOP and AA table
' G+ \- E( Y9 N; A4 K% b/ nPR 1876381: Adding a cutout to the pattern will delete holes * t3 ^4 |. v1 @. r; T
PR 6659724: Crash editing profile Dimple, Drawn cutout, Bead etc
6 k, E, ?, b+ w G2 M7 s- ^# X" tPR 6664695: c-bore does not update with transition to a sync part
5 {- z5 g: N: u9 NPR 6669152: Cannot select nodes with Probe on one side of bolted connection& j7 q- ~5 J- ?4 w3 v7 k/ f
+ A% ?+ I5 d" B0 A Z9 y- Y: ^===Insight===) q# D1 ~/ e/ J
" ^ \0 y# @# ]/ X% V: P" S
PR 6619831: ST3 is slower than V20 after OK 'Select Documents and Folders' dialog
+ D" X0 {7 d* [5 _! h
$ X. |$ G& f2 c) v5 s; D# y$ \===Solid Edge Embedded Client===" ^- G( E$ \* T; P3 ?" L8 E( g6 M
/ o: r/ C9 W* f: z. UPR 6637263: Teamcenter error shown on saving a part file without assigning values to mapped prop0 W7 [. p! f. H- s3 G* g
PR 6575712: Desc: SEEC Diagnostic tool in ST4 gives strange results
+ J' g2 V5 ~" a7 JPR 6653508: SEEC Save As not working after upgrading to TC 8.3.3( f9 R9 S+ ~0 o, W2 d& H
PR 1883259: Saving a Draft file into a Teamcenter with more than 32 characters crashes
8 }, G1 V B3 Y: d- r8 U- D) t" \ w2 D8 Q$ U3 a
" X) b6 Q# j2 y- _! c---/ R4 U0 _* h: P
End 4 z( q8 d* C" j; S8 B# z x
