查看: 11474|回复: 40
[分享] auto cad尺寸驱动程序
发表于 2006-5-31 15:47:03 | 显示全部楼层 |阅读模式 来自: 中国上海
auto cad尺寸驱动程序
2 `; _6 `# g$ C1 J- A( ~" N& J: k/ C. A: w$ J0 h: b
(defun c:tt(/ BLB EP ESPL N-EP N-SP NEW-T SD SD-DXF SEA SEB SP SS1 SS2 SS3)
1 `% R0 u( y" r) u) g) g- b8 _(setq SD (entsel "\n选择驱动尺寸:"))
7 [8 _7 T2 L/ c& }3 Q5 e(if SD
3 l& @! Z  S  ~. t3 a9 [9 D8 X  (PROGN
8 K' v+ {( J$ T    (SETQ SD-DXF (ENTGET (CAR SD)))4 K8 A/ q  g" l9 V* B+ p
    (WHILE (NOT (wcmatch (CDR (ASSOC 0 SD-DXF)) "*DIM*"))
1 J, v/ O/ [" N$ E$ \" T/ Y* [(setq SD (entsel "\n选择驱动尺寸:"))
- V, N6 X" C# u; V5 M(SETQ SD-DXF (ENTGET (CAR SD)))); U3 A/ Z' z4 r5 W; q
    (SETQ SP (CDR (ASSOC 13 SD-DXF))
: I  m0 \  R& o  w% z* Q  EP (CDR (ASSOC 14 SD-DXF))1 g8 ~1 a0 \  v$ N- k% n, k# B
  ESPL (DISTANCE SP EP); v" Z9 Q5 m' A
  SEA (ANGLE SP EP)
, @6 [! }$ \; \1 N  K$ v: k7 k2 a. L5 K  SEB (ANGLE EP SP)
. q& G( t: D$ x- p- A7 d, f  NEW-T (getdist "\n新的长度:"))6 K1 N+ ^7 `* Z# H' O
    (while (eq nil NEW-T)$ g, z8 t. K9 T
(setq NEW-T (getdist "\n新的长度:")))
3 d' z0 G5 i# K. L  W' f    (if NEW-T/ I: |- N1 q# D
(progn
3 I/ G; |3 B! T) p    (setq BLB (* 0.5 (abs (- NEW-T ESPL))))
9 T/ u" |3 G& w: _# H9 f* g    (if (> ESPL NEW-T )
) V2 P- M7 t' Y(setq N-SP (POLAR SP SEA BLB)
, |# Y% y% C6 c    N-EP (POLAR EP (+ PI SEA) BLB))
5 b( A  M2 s! p6 d- Q& V(setq N-SP (POLAR SP SEB BLB)% i( l. }; H- X6 t: S
    N-EP (POLAR EP (+ PI SEB) BLB))
+ ?. n9 C8 x  ~9 C)
' y% x4 R5 @5 n    (setvar "osmode" (logior (getvar "osmode") 16384))5 H( t/ k& |* [: T7 V+ B0 N  p
    (setvar "cmdecho" 0)
/ `8 O8 A' g8 ^3 N    (vl-cmdf "_.undo" "_group")& H3 \3 ^1 K. A* q5 r8 y2 [: n
    (SETQ SS1 (SSGET "C" (POLAR SP (+ PI (* 0.25 PI)) 0.4)(POLAR SP (* 0.25 PI) 0.4)), n) i, _& T4 c7 d. P: [2 q
  SS2 (SSGET "C" (POLAR EP (+ PI (* 0.25 PI)) 0.4)(POLAR EP (* 0.25 PI) 0.4))
, J. t8 r- h: n, Y. t  )7 }1 g3 n7 W3 P, I
    (IF SS18 H; [1 `5 @' U8 M3 m) i  Q
(COMMAND "STRETCH" (SSGET "C" (POLAR SP (+ PI (* 0.25 PI)) 0.4)(POLAR SP (* 0.25 PI) 0.4)) 5 D  {" z; I" a' a* s
  ""SP N-SP))
1 N, k% b* w4 Q7 H1 i5 \3 P3 y    (IF SS3' ?: O$ B" o4 q1 x
(COMMAND "STRETCH" (SSGET "C" (POLAR EP (+ PI (* 0.25 PI)) 0.4)(POLAR EP (* 0.25 PI) 0.4)) 1 y- O% O; n7 ^% A, }$ F! A
  ""EP N-EP))
# `# q- K" k: s2 o  _    (vl-cmdf "_.undo" "_end")
; t0 Z  g8 r5 d- f    (setvar "osmode" (logand (getvar "osmode") 49151))
$ @" `8 T5 g  X: \4 t    (PRINC"\n编写:BDYCAD\n尺寸驱动程序运行完毕, 欢迎使用.谢谢!")))
6 ^: Y1 P1 F8 _$ T0 z0 R' ^. A    )
2 S6 p2 C7 w1 T" U& J3 ?/ s5 D2 }  )9 Z, t7 A- b. T( W! [5 L
(princ)% j4 D# r5 `! T0 E. k
)& X% K& G8 x, e0 ^8 ~7 k1 ~/ R  U% z
————————- X/ y3 d) k5 v+ Q; D' j
不知道如何用
发表于 2006-5-31 17:39:30 | 显示全部楼层 来自: 中国浙江杭州
你这个需要其他库支持的吧!
发表于 2006-6-1 07:17:47 | 显示全部楼层 来自: 中国浙江温州
尺寸驱动太好了。怎么用谁知道吗?
发表于 2006-6-1 08:28:42 | 显示全部楼层 来自: 中国广东江门
不知道什么用,楼主能说清楚一点吗
发表于 2006-6-7 20:07:53 | 显示全部楼层 来自: 中国湖北咸宁
老大!看不懂啊!
发表于 2006-6-8 13:44:04 | 显示全部楼层 来自: 中国贵州贵阳
你这个需要其他库支持的吧!
发表于 2006-6-9 15:54:57 | 显示全部楼层 来自: 中国吉林延边朝鲜族自治州
回复 #1 冬梅 的帖子
尺寸驱动太好了。怎么用谁知道吗?
发表于 2006-6-9 16:43:29 | 显示全部楼层 来自: 中国广西河池
怎么用啊??????
发表于 2006-6-29 17:07:11 | 显示全部楼层 来自: 中国山东青岛
怎么驱动的有误呢
我标准100 驱动是输入50,结果显示为75" S) D. p' Z( O
9 z, N% |' j0 c& _- a
使用时将以上文字拷贝进txt文件内,改名为×××.lsp。然后用cad加载该文件即可。
发表于 2006-7-2 01:12:52 | 显示全部楼层 来自: 中国北京
这个好,拿回去慢慢研究,如有结果再来告诉大家。
发表于 2006-7-2 21:07:20 | 显示全部楼层 来自: 中国江苏苏州
这就能“驱动”了?
发表于 2006-8-4 22:57:01 | 显示全部楼层 来自: 中国山东聊城
看不懂,麻烦高手解释怎样用尺寸驱动
发表于 2006-8-5 09:22:44 | 显示全部楼层 来自: 中国浙江金华
驱是能驱的,只是驱动出来的结果不是我要的。! D. h9 a' w; b! c
还烦请楼主再调整一下,谢谢啊!
发表于 2006-10-7 21:05:56 | 显示全部楼层 来自: 中国重庆
把文件先用TXT格式保存下来后,再更名在LSP格式的文件,再用CAD程序加载它,画一个图标注后,在命令行中用TT命令就可运行了,但是他妈的程序有错能驱动但数据有错,气死人了,我想是算法上有问题,
发表于 2006-10-17 21:31:16 | 显示全部楼层 来自: 中国河北石家庄
我很少用到尺寸驱动,用电子图板时,有尺寸驱动功能,我孔很少用,有时感觉还没有直接修改来得快.
发表于 2006-10-18 12:04:37 | 显示全部楼层 来自: 中国福建南平
可是,到底有什么用呢?
发表于 2006-10-29 15:24:21 | 显示全部楼层 来自: 中国江苏无锡
谢谢楼主啊,真是好东东!但俺不懂!
发表于 2006-10-29 15:38:54 | 显示全部楼层 来自: 中国浙江杭州
好像不能啊,楼主能讲解一下吗?是不是特殊驱动什么东西得?
发表于 2006-11-22 12:47:30 | 显示全部楼层 来自: 中国河北承德
看不懂,楼主能讲解一下吗,麻烦高手解释怎样用尺寸驱动,到底有什么用呢?
发表于 2006-11-22 13:21:28 | 显示全部楼层 来自: 中国浙江温州
终于能驱了,但是不理解!!!!尺寸没法控制!
发表于 2006-11-28 18:50:59 | 显示全部楼层 来自: 中国河南洛阳
楼主请您完善一下,的确是个好东西
发表于 2007-11-17 11:54:47 | 显示全部楼层 来自: 中国江苏苏州
尺寸驱动完全不对
发表于 2007-11-17 12:01:48 | 显示全部楼层 来自: 中国江苏南京
我们一般是先画图,再标注尺寸;如果要稍做改动的话,可把尺寸改动后,利用尺寸驱动,与该尺寸相关的线条就会自动改变。
8 F5 J& C  Q0 X0 K0 _: l我看同事用过,但自己没用过,只能说这么多。
发表于 2009-3-30 12:32:59 | 显示全部楼层 来自: 中国陕西西安
尺寸驱动的好处就是不犯错误,据说CAD2005就驱动了,但我的没有。
发表于 2009-3-30 17:09:55 | 显示全部楼层 来自: 中国江苏无锡
好像的CAD的二次开发lip
