查看: 4623|回复: 3
[分享] MasterCAM 教学 DOC格式
发表于 2006-6-1 19:48:23 | 显示全部楼层 |阅读模式 来自: 中国山东济宁
MasterCAM 教学 DOC格式,适合初级入门人学习!
0 D7 Z. n9 M# E9 |! w% l  V$ b  m/ f
好像是8.0以前
* e. o* P( y6 ^$ `
- d" c( p$ |5 z. P- {) x) f0 ]2 U4 [% ~
" [# p! M( m/ T9 W) U) z8 @
第一章 Mastercam 系统简介............................................................................. 12 R' d, {% _, v) `5 g% n( p
§11 系统特性概述................................................................................................. 1
; A" _5 ]5 g, O§12 系统结构......................................................................................................... 3
# Q% ^9 H5 z8 {% j) a7 ~§13 Mastercam PC机的硬件和软件配置要求............................................. 4) v, U3 T5 ^+ }; _  n* `7 h' f
§14 Mastercam系统的流程图............................................................................ 5
- R) D: I' ?; L) @* }§15 系统界面及功能简要说明............................................................................. 5
9 P; H; h0 @  Z9 k- J§16 功能键介绍..................................................................................................... 7* D8 H% G1 |2 m# y5 U/ k
§17 在线帮助(On-line Help........................................................................... 8
8 B' F, E% L0 Y9 M' Z§18 Masteream生成NC加工程序的实例................................................. 10
. Q5 R; s$ L! B' b$ O2 L3 _; q§19
% n4 A! l9 C, U7 x1 Q
练习.............................................................................................................. 145 [: e* A4 I6 b/ s9 u
第二章 MastercamCAD功能..................................................................... 15
" R1 [& z# U9 ^% P§21 绘图功能(Create................................................................................... 158 {- T8 S4 X" o; `2 G# V
§211 点的绘制............................................................................................. 15
( g% F1 d# E0 m! r§212 线的绘制............................................................................................. 17
) D( p" ?% w0 s§213 圆弧(Arc)的绘制........................................................................... 18. u. h; M# n" S0 P! o( ^( U! b
§214 倒圆角................................................................................................. 19
4 y: F% V. C- _7 [/ y; G§215 Spline曲线........................................................................................... 19) j5 Q: }1 a8 F" @
§216 椭圆的绘制(Ellipse...................................................................... 20/ W$ S0 h8 ?. S1 [% [% L, s
§217 矩形的绘制(Rectangle................................................................. 20
  W/ n* I+ G* o' w7 @/ r- {§218 倒角(Chamfer............................................................................... 20
+ \- b8 y3 q0 e1 `8 g§219 文字(Letters.................................................................................. 20" a- \" H* T) _; Y% H
§22 修整功能(Modify................................................................................... 21& I  j7 ~- K. i, A9 p
§221 Fillet(倒圆角)................................................................................. 21! }3 W% r4 [$ n/ U" B
§222 Trim(修剪延伸).............................................................................. 22) _) K/ u, k% f
§223 Break(打断).................................................................................... 24
8 i8 Z5 a# S0 o; g5 ^4 a§224 Join(连接功能)............................................................................... 24' ^, _! T9 q% ]( ?
§225 Normal(法线).................................................................................. 246 P2 A3 W# M% v8 q# {
§226 Cpts NBS(控制点).......................................................................... 24( L3 Y& m: @: M# U; O
§227 X to NBS(转换成NBS................................................................... 25* ^) {) k" V$ W& F& e3 }
§228 Extend(延伸).................................................................................. 25
  `: Q; j: @2 S/ H1 B* C9 `( L! c§229 Drag(动态位移).............................................................................. 25( o% H1 J: `& J8 |8 W7 ~: e$ X# q0 U1 w
§2210 Editent(图形元素属性的编辑).................................................... 25
( ~% u  ~7 I; {; v' w§23 转换功能(Xform.................................................................................... 25
: b! v  o. v- h: W, P§231 图形元素的选择方式与公共参数..................................................... 26' H7 |6 I- L/ a8 |. v4 n9 {" w) A
§232 镜像功能(Mirror.......................................................................... 26
0 {& J1 M* E8 m7 N: }( I§233 旋转功能(Rotate.......................................................................... 274 \! N, G, S6 G+ F( A
§234 等比例功能(Scale........................................................................ 271 K9 h8 }5 D4 F( w9 H8 ~3 B
§235 不等比例功能(Xyz scale.............................................................. 277 \# _( k0 Y+ L& Y8 A" G
§236 平移功能(Translate...................................................................... 28
. z" q! n& B7 ]/ E8 E6 C§237 偏置功能(Offset........................................................................... 28
; N% ], H+ m/ D§238 串连偏置功能(Ctr offset............................................................. 282 l) c& P( R7 ^1 l$ E, I1 C5 l
239 群组设定参数(Group.................................................................... 29
' V/ M2 ]7 y3 y( w§24 删除功能(Delete.................................................................................... 299 s+ ?" C0 ?' _( a
§25
& m! W9 y  L9 L: o6 n* x
练习.............................................................................................................. 29
# ~' r, o! j, a  M% e9 k. [第三章    二维工件NC程序的生成.................................................................... 31& [% D% T6 `0 k2 c2 Z  X4 s' Z9 \
§311 v  N- ]6 e& j. E) w8 R
............................................................................................................ 317 f) q& D+ H, B4 q
§3-1-1 二维刀具路径分类............................................................................. 310 z9 w6 D# B6 S; T
§3-1-2刀具参数................................................................................................... 322 W( s3 s/ E2 d. n1 N. v
§32' M% W, K; l; m' T  W
轮廓铣削(Contour.............................................................................. 34
: k* D# o- z2 p1 D" g§3-2-1轮廓的定义选择....................................................................................... 34
; u3 Q( j+ |4 S! q$ a5 l7 Q+ t§3-2-2、轮廓铣削模块................................................................................... 35
" S- o- G3 }" U2 T2 e3-3
$ F8 o- |9 Y0 }( M
型腔加工(Pocket...................................................................................... 36" J$ }7 b# R7 P6 U0 e( U3 O* R
§3-3-16 D3 W" E" T7 M# I
型腔加工参数........................................................................................ 36
- T" V0 {* n# q
§3-3-2............................................................................................................... 37: @2 q& b+ L7 ^# K1 ~
§3-4
; t* o# K( x) w; C$ Y
孔加工模块(Drill................................................................................... 39" g5 @  [* Z! [  y2 B8 x
§3-4-2
. ~+ I/ E! `1 L% v- t% O! C( B
举例........................................................................................................ 40
, Z) i+ I, P  \7 M; {: R
§3-5
( J  Q0 H) T) T
刻文字模块.................................................................................................... 41/ {" H; d; s/ R7 s$ t/ W7 e4 y  F
§3-6  ^+ p# O! N& C8 N6 V) y  G7 p) i
练习................................................................................................................ 42
4 Q2 b7 |  f4 _* \0 ]; s$ j第四章  二维刀具路径的编辑及切削路径的规划.............................................. 43/ C: R# S* `* ^: _' I; c, P
§4-11 U: M, B; Q6 F& Z7 A$ W
刀具路径的文件结构.................................................................................... 43
0 S5 F7 d$ e6 P% x! Y§4-2
; p1 `6 Y, o" @1 d& K: W
删除刀具路径................................................................................................ 44
% G$ L( {. Q% f$ D1 s6 A§4-3  Q% d! {, c5 e9 R  ?! \" D
改变刀具加工路径的顺序............................................................................ 45+ C4 t/ p6 \* p; q. {# j, J3 g& g* a
§4-4$ \" y0 E; t+ X
合并刀具路径文件........................................................................................ 45; K/ k* m) U( {. t6 v
§4-5" F. _: r" \" o  @2 R7 b
编辑功能(Edit NCI................................................................................. 46
. k$ `+ X# X2 T5 y§4-5-1! a# k1 B, H3 P" G. @/ [
镜像功能(Mirror.............................................................................. 47
7 [% Q( B1 e3 u$ V* U/ z6 [§4-5-2
5 N# C$ M9 b( [4 x$ @3 [
旋转功能(Rotate.............................................................................. 47
0 q4 U) ?4 O0 o4 T! N% V2 t+ ]§4-5-3' S+ p1 I& G% X
比例缩放功能(Scale........................................................................ 48
. I4 U, F$ h) ], Y' [3 H§4-5-4
0 L" p2 X3 W8 z" z2 w
平移功能(Tronslate......................................................................... 49
( \* M1 K' ~3 A' }8 S, p§4-6, I  D5 E1 Y, `+ A" ~
线性阵列参数................................................................................................ 51
8 c, Z4 e! e8 P* U§4-7+ k' s3 w5 t" |" R& Z0 k! J
加工程序和切削路径的规划........................................................................ 51+ z( h" n6 t$ X
第五章  文件转换及文件管理................................................................................ 54
; c/ V" V/ x2 y9 k§5-1 Mastercam的文件转换功能......................................................................... 54
2 @/ F0 r+ j$ I; N$ c) p6 K§5-2# v6 D. t2 H* H* ?# a
Mastercam
AutoCAD之间文件的转换............................................... 55
# n% Q7 o1 x/ e/ c§5-3 文件功能表的其他功能.................................................................................. 56/ |( \2 C7 j" s1 O7 n
§5-4
) ^8 M2 `+ Y+ H! I& ~
练习................................................................................................................ 57% B- W8 ]5 X& a0 R+ i
第六章  曲面功能简介............................................................................................. 59" r2 k" }. j' t2 r8 E: J: o
§6-1
. p2 M! D1 H0 U- x
概述................................................................................................................ 59! {2 z+ n  M+ k$ r; A
§6-1-1
. h' O4 S+ N: N' u6 j
曲面模型的种类.................................................................................... 59
& ]' q: o7 \4 T7 W& n8 W0 J8 @" Z. n( ^§6-1-27 M9 ?1 s  z+ |; X0 E$ E
Mastercam
系统提供的基本曲面功能................................................. 59
2 X/ _, b0 {  C) e' \5 d§6-1-3四种编辑曲面........................................................................................... 60
$ V$ _; s; W$ k: F* Y6 P§6-2曲面造型举例.................................................................................................. 60
) A! S& \2 ]5 `1 B§63三维曲面刀具路径的产生............................................................................ 63* g: d7 J. d' N% G8 r
§6-3-1刀具路径的通用参数............................................................................... 63
2 y7 w- \6 I7 ?, s" f§6-3-2) E# w7 d( @8 E# e0 J8 k4 U
刀具路径的产生.................................................................................... 64
  d( _# w8 i, J, t! @# j§64练习................................................................................................................ 66
* J) j2 L8 T5 t2 E) I
! n3 |, w, Y1 G! W4 B0 K[ 本帖最后由 hoopoe 于 2007-9-16 12:41 编辑 ]
MasterCAM 教学 DOC格式.rar
716.08 KB, 下载次数: 816
发表于 2006-8-12 19:36:24 | 显示全部楼层 来自: 中国黑龙江牡丹江
也看老了啊
好想是5.0的文件啊.太老了啊.
发表于 2007-3-1 17:50:20 | 显示全部楼层 来自: 中国北京
以前看过有朋友上传车床的编程说明不知道这个是不是铣床的,如果是铣床的就好了,不过还是很想用谢谢感恩的心情对这位不辞辛苦的哥们道声,辛苦了。
发表于 2007-6-22 18:35:42 | 显示全部楼层 来自: 中国湖南永州
可惜是8.0的!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
% r* o6 m) A0 ]1 l! C# z6 P
5 c4 M* V" E0 r0 _有没有9.0或更高版本的X
