hi guy, now I tell you 2 ways to get your sprocket model.9 S U$ n$ t2 V9 O6 V3 G$ h
1\use ptc wedsite http://www.3dmodelspace.com/ptc to search what you needs.) W, b: s f# K4 a- a) ~$ t' Y3 x
2\I share a sprocket model with you, and you can change the parameters to meet your needs. but no chain.
hi guy, now I tell you 2 ways to get your sprocket model.* f: v2 z1 b/ G( V; K. S5 g. F
1\use ptc wedsite http://www.3dmodelspace.com/ptc to search what you needs.' w% Q8 I2 X/ R% h; l! C
2\I share a sprocket model with you, and you can change the para ...1 E* B4 h% l8 x. j! L
nanfeng36 发表于 2012-5-14 23:29 http://www.3dportal.cn/discuz/images/common/back.gif
8 o! f' q. n4 q2 ^' U* X% dsorry for forgot the attachments
