3天前
查看: 2800|回复: 1
[已解决] 大家帮我看看这个后处理怎么改成公制的,谢谢~~
发表于 2006-6-4 12:38:15 | 显示全部楼层 |阅读模式 来自: 中国广东深圳
这个是CIMATRON FOR 米克朗的后处理,希望高手帮我看看怎么把处理出来的程序改成公制的,具体文件请看附件。谢谢大家3 Q( y* g6 b* F/ q$ ?3 `5 j5 C
) {. u! h% P! Q( ~! d
3 `; [* x; u5 N*) _- C  |& m. b1 ?+ G6 L
3 f- l  R! l7 ?9 K*            CamNet (c) PostNet                   *
# c# R0 @- r$ l/ r* {6 [9 z9 Z+ j*-------------------------------------------------*
1 R* z6 F) J. J! f; a/ R3 r*            Name : Hnc_3x                        *' L' U1 d/ Y, P2 M& m9 D
*         Machine : Heidenhain                    */ a( M0 m2 |2 E, z+ @
*         Control :                               *
! x1 I, y1 j  O: @2 S' u) u; T*              CO : Micro Moules Inc.             *0 [1 \2 J( y2 U# U
*    Cimatron Ver : 8.0/9.0                       *# }6 {& V  _1 x0 ?% M3 z
*              By : Ogen Goldstein                *# E0 N4 ]: p& }, L2 Z, V
*            Date : April, 02, 1998               *
! P& Q" @$ h2 D$ o% U*            Type : 3-AXIS MILL                   *
) B" S$ \! e& P*            Unit : Inch/Metric                   *
; ?* m4 r  }" ~4 D8 r; ~8 Y*        Platform : Any (Source writen on NT4.0)  *: R; w+ ]# A$ A- x0 r
/ K# T6 K( s6 C" w/ }& W8 h*             Tel :                               *
4 E4 ^; C+ p+ E" K, e*             Log # 4678                          *1 A2 N6 ?  I0 ^, `+ H3 I4 E! f, q
*     Modified by :                               *
* l  z, R# v4 x% L5 ~  O*            Date :                               *4 `: |5 O7 G. R) ~' D& K. F5 I
*        PLATFORM :                               *: {6 T$ R) B7 j, a1 m1 e
6 x- g6 o: B% A' n; m* m*
. w* v' r: h1 n& l/ ]3 R*============ New Variable ================================================
+ t. \( Y  W  l; b; r& G9 G* L4 `FORMAT (COORDINATES) Clr Depth Total Zinit Xlast Ylast Zlast CycPeck CycXshft ;$ @! u7 Z: c( A
FORMAT (SEQUENCING)  Seq FlagCool FlagBeginLine MoveNum FlagCircle ;
8 p# I8 O# J1 N# n/ {+ m7 QFORMAT (CHARACTER)   SPC UserUnits FileGpp Gunits FlagZdm ArcFlag Comm1;  d& ]4 Z  ^0 u4 {
FORMAT (TOOL)        FirsTool FlagTool next_tool NexTool;
/ c; L* n) Y, `- O& cFORMAT (TOOL)        NumTool OffsetLen OffsetDia  OffsetFix FlagSpin;
1 F, n7 H! r7 H. o/ q6 jFORMAT (COORDINATES) Xi Yj Xendpt Yendpt Zendpt CycReduc;# @" J: o; Y" g, @- g1 j: c: \% G
FORMAT (real)        UF UF1;$ W0 _! O6 |* m* J8 M
FORMAT (TOOL)        OffLen OffDia OffFix;8 N9 i7 U8 }- Q1 n: R! @" y( E& `
FORMAT (CHARACTER)   FlagOffDia FlagOffFix FlagOffLen Zdm ElsFlag sEls SpcFlag;0 p- o2 }% [, H! a; e; T" n
FORMAT (FEED)        AdjustedFeed ;
. r: C) P; j7 p7 g$ m  s: s; A1 b8 ^*==========================================================================: P0 O% @) H1 y" l7 H) T/ f- g
0 [1 Z+ i" r4 b, }2 N. q5 s*-------------------------------------------------------------------------5 c  R2 C" W+ {
INTERACTION (SEQUENCING)  "Prog_Num"               Pgn         = 100      ;
* }# j3 I3 t, m4 xINTERACTION (CHARACTER)   "Seq(Y/N)"               SeqNum      = "Y"      ;, \' n- Q' O$ g( i/ [# T
INTERACTION (SEQUENCING)  "Start_Seq"              SeqStart    = 10       ;
7 k) l3 H8 d) T( V6 E% QINTERACTION (SEQUENCING)  "Increment_Seq"          SeqIncr     = 10       ;5 p& h0 V7 S1 t% W5 y. A2 B6 Z
INTERACTION (COORDINATES) "BLK FORM 0.1 X"         BlkForm1X   = -76.2    ;; M+ ~- L) i# k% d- g. [* Q
INTERACTION (COORDINATES) "BLK FORM 0.1 Y"         BlkForm1Y   = -76.2    ;3 {6 i% D! V( w- [, K+ h
INTERACTION (COORDINATES) "BLK FORM 0.1 Z"         BlkForm1Z   = -25.4    ;
6 M" c2 m+ K. JINTERACTION (COORDINATES) "BLK FORM 0.2 X"         BlkForm2X   = 76.2     ;- V; U" P% T2 K
INTERACTION (COORDINATES) "BLK FORM 0.2 Y"         BlkForm2Y   = 76.2     ;2 ~" m3 L8 B/ z7 {2 Z/ F6 @
INTERACTION (COORDINATES) "BLK FORM 0.2 Z"         BlkForm2Z   = 0.0      ;
. }; W3 Y+ i. X4 n& I' O! xINTERACTION (CHARACTER)   "Divide_G-Code(N/Y)"     DivideFlag  = "N"      ;
+ X$ v5 B9 \; ~- GINTERACTION (CHARACTER)   "Path_Save(No:-1)"       sDrive      = "e:\"    ;
' J* B  q# u( J# ?% N  R, YINTERACTION (CHARACTER)   "DeBug_Post(N/Y)"        DeBugFlag   = "N"      ;' Z6 j/ D" x( U
$ U3 a7 u* Q2 d) Y# R*5 n9 t; @. V) o5 g! J& W" v
identical        x_curpos x_endpt;
1 ~) ]" E" L+ R0 w/ s; l! Uidentical        y_curpos y_endpt;% \( u; \8 T1 J) v, O
*2 Q1 g/ i, w5 ]+ [2 y
*---- Interaction var* e6 _) c$ ~; W( p3 v6 |" X9 a
non_modal        Pgn SeqNum SeqStart SeqIncr Comm1 SpcFlag FlagZdm Zdm + @( ]4 t! _% _: k- f
                FlagOffLen OffLen  FlagOffDia OffDia FlagOffFix DivideFlag' K) ~4 ~+ p4 n6 ~
                OffFix DeBugFlag ArcFlag ElsFlag sEls BlkForm1X BlkForm2X. r3 @9 ?+ W4 n, ?4 j8 h* p
                BlkForm1Y BlkForm2Y BlkForm1Z BlkForm2Z sDrive;
% }, c+ A& C# x4 `3 o0 N; h  F: j*---- System Var4 W( J; w) H- q0 g0 {( s. [
non_modal        i_origin j_origin k_origin i_coord j_coord k_coord post_name
" D0 u; w. l: `# Z5 S( `' D                part_name tp_name diameter_ proc_name leng_comp pfm_units
1 ~2 T; x7 t0 y# ]0 e( j                x_origin x_mach y_origin y_mach z_origin z_mach next_tool- H+ a* W9 X, ?0 N8 q, x1 W: \
                x_home y_home z_home cyc_clear cyc_depth cyc_dzinit cyc_retr cyc_dwell;
6 \/ g6 \; S8 t: M& H, T8 e& E2 F, H, U. A; A9 d2 C
*---- Local Var
8 f  U. T8 f8 \( [. K% w8 n- Dnon_modal   Xi Yj SPC OffsetLen OffsetDia OffsetFix Xendpt Yendpt MoveNum 4 g* L& p0 V+ `, h, S
            FirsTool FlagTool FlagCool Xlast Ylast Zlast FlagBeginLine Clr- G4 f: t7 ?2 l7 u: ?! `+ Z0 U
            Depth Zinit NumTool NexTool FlagSpin UF UF1
0 s3 x% D* }; m: c! p9 J4 z' d- S            FlagCircle Total AdjustedFeed;
- M& n  D8 j3 G% }/ v3 g+ A7 A+ {5 H1 S( h2 Q8 `, }
$ H, X* \, v1 P$ s7 ?/ P1 uNEW_LINE_IS $ ;0 x9 G/ H! \+ U1 g
        if_set(SeqNum _eq_ "Y")  @$ A0 o2 N6 ~5 _
                if_set (SpcFlag _eq_ "Y")
+ ?) R0 a" p  \0 w9 E2 k$ ~                      output \J "N" Seq SPC ;/ [* m) @8 l. V1 X
                else) j( H6 {+ Z0 e/ G2 g$ E; y5 c
                      output \J "N" Seq;" @, @) U. G& Y% l
                end_if;2 s0 \) q  v% I8 a
        else
& T6 e7 Y9 B- T9 _5 R8 B              output \J ;. ~, X1 }3 V, m
        end_if;; P  @% j1 K, o/ O$ L' O! ^
    Seq = Seq + SeqIncr ;
! Z6 I  u* Y+ L' X3 m: c
: Q+ v* ^2 T$ o( X& l% A( u1 Q  `. M" B0 R
2 {6 Z# I9 `! ]9 a% d( k. }BEGINNING OF TAPE:
9 v, _# Q; b- V! \        SpcFlag     = "Y"    ;
4 R! `: x3 Z6 l9 [/ E5 o- p6 i6 c$ x. V& ~        ElsFlag     = "N"    ;1 o/ s/ E5 V. e$ w
        sEls        = "*"    ;
7 ^' C+ X) p. z2 V' E. n# L  j        Zdm         = "N"    ;+ a2 p. t! ^2 U. q
        cyc_dwell   = 0.0    ;
3 r; c. M0 s5 z! b        OffLen      = 0      ;  u$ b# J; t5 ]. r2 T9 `0 l" }
        OffDia      = 0      ;
( F  t" Q5 _4 _2 w' _6 `0 z        OffFix      = 1      ;0 y* b) |/ v9 _/ h) v; H
        FlagOffDia  = "N"    ;
& ]2 A: m) s+ E5 U8 G) e' T8 c        FlagOffFix  = "N"    ;
' |. B3 m1 z5 E: I1 l        FlagOffLen  = "C"    ;" H9 V5 A% m- |$ Y
        FlagZdm     = "N"    ;
3 X# B5 X; x: F2 R        Comm1       = "None" ;
0 b2 l+ J- P/ x# }        ArcFlag     = "N"    ;
& z7 s" Z4 f; B        if_set(Zdm _ne_ "N") if_set(Zdm _ne_ "n")5 N' C) N" p3 F
                FlagZdm = "Y";8 p' |* O. `+ V+ m- I
        end_if;end_if;0 F+ Y$ `$ f9 O8 z
*********************************** For Convert Units9 m6 l$ ?& [; o% y' T, }
        if_set(factor_ _eq_ 1.0)
- x6 u$ `7 y( N4 {( \                Gunits    = "G71"   ;( `6 h, f' B9 ^+ s1 ^' u
                UserUnits = "Metric";
6 ~3 v7 }- v/ G  b( a        else9 e" b* H! h6 o, R" O
                Gunits    = "G70"   ;' g& y. {$ f, n! w3 r
                UserUnits = "Inch"  ;/ c/ r/ ^. y) p' Y! M( V
        end_if;) F3 G3 k* ?) O7 H
        if_set(pfm_units _eq_ "INCH")$ m' F: V1 _% e( `/ j; l
                if_set(UserUnits _eq_ "Inch")" }: p# R. K) o2 g- f- g+ |
                        UF1  = 0.039370078 ;6 l, I) f* c* P9 R
                        UF   = 1.0;
& v# n) J  B6 m! q8 Q                end_if;* Y# O& H( D  f$ j; r1 U
                if_set(UserUnits _eq_ "Metric")# i# n& k+ T9 A5 o" g+ H" k' l
                        UF1  = 1.0;  n" r; B4 o" r6 z  U( M% }: \
                        UF   = 25.4 ;
1 B( l' @# o) A8 s% X' L                end_if;& s/ E9 z/ ]% Q1 h  M
        else' \, o- L0 v5 Z& {% G7 m( X
$ M" E% d7 [: V/ f4 _8 }4 I                        UF1  = 0.039370078 ;
4 E( d8 K8 `& @( U                        UF   = 0.039370078 ;
: X" O/ X4 Q" m3 v( o                end_if;
8 g% i; {) B5 S8 a5 {                if_set(UserUnits _eq_ "Metric")) }8 `$ r9 a  g
                        UF1  = 1.0;
  R5 H- r0 Y7 K2 l                        UF   = 25.4 ;* c* O+ H: V  k  n4 t
                end_if;
+ u. d- f8 y3 J        end_if;1 o. Y, H( V% k
: K# v! r. s% w. A2 x" y3 j        SPC        = " ";
: }/ r  a. W+ F2 d        Seq        = SeqStart;
9 s* r. b6 P, D8 E; o        FlagCool   = 0;
$ {% R( }( B3 T  X1 H% l        FirsTool   = 1;
1 K1 a2 [. I* Q& f8 _        NumTool    = 1;- Z* B: M) F! W0 H
        next_tool  = 0;
6 Y3 n+ N4 |/ [5 L; \: K        NexTool    = 0;
0 F! y1 s0 G7 ?6 L        cyc_clear  = 0.0;
# s2 \( l" K: v! e4 X        cyc_depth  = 0.0;# M; q+ R! c& E  d
        cyc_dzinit = 0.0;7 T- g9 R$ a; F9 v
) ~1 l9 B% y% v; c$ T2 Z( M*******<<< OutPut CMD File >>>*********** b0 ^8 R6 r6 X5 D3 a2 e" R; Z7 |
****************************************, [0 i) G4 X& B) {; O7 E# T
***<<< Begin >>>****
: n7 {7 K1 ]$ f*=======================================* O4 [! r. T2 @; j/ i& h& h
*        OutPut To Cmd Win Version6 R  z  B( j8 i9 E+ @
) O: `1 P) U- j" s) {        if_set(sDrive _ne_ "-1")$ s2 D5 V: N- N( Z( _
                print0 \j "copy " part_name "." tp_name "." post_name " " sDrive "\" tp_name ".hnc" ;
* g& Y, C7 g8 l$ h4 S        else
2 M6 _1 C8 C! I) t                print0 \j "copy " part_name "." tp_name "." post_name " " tp_name ".hnc" ;
  D& Y( W5 z" [        end_if;
& l+ b- r5 K( K: i  C7 ]+ P) p; o        if_set(sDrive _ne_ "-1")( T& J* P) P1 L0 w$ ^
                print0 \j "copy " part_name "." tp_name ".tools "  sDrive "\" tp_name ".too" ;: q! q( O) s$ t
        else* E4 J3 T: h' h: C/ j; A
                print0 \j "copy " part_name "." tp_name ".tools "  tp_name ".too" ;+ u( H- g+ g5 Y8 G! C/ k
        end_if;3 {0 J  u+ A- @
        print0 \j "del *." post_name;
9 m1 S$ H9 T9 T5 q7 ]; C& b7 B        print0 \j "del *.txt" ;
, \6 {$ c; R; K4 O2 S0 Y         print0 \j "del print0.bat" ;
( C$ l' B5 u% Q***<<< End >>>****
: B* X( l  t5 ?: K0 g5 ?4 O# U; k% x* g2 W  a) D5 _7 q% T) C7 G
& M! C" V- c# Z# ]******************************************
3 F+ T  l& N8 k& ]. K*******<<< OutPut Begin Tape >>>**********  N% U+ w! K' r- d: G
******************************************& W0 o# z( V3 y' e3 u( T* c6 N( @
***<<< Begin >>>****2 D' ~( T8 i4 ?' @, F
        BlkForm1X = BlkForm1X * UF1;
! k" _2 |7 u$ ~, R1 n9 ^- ^        BlkForm1Y = BlkForm1Y * UF1;3 A9 a, I& G# U/ N+ c& C  c+ |
        BlkForm1Z = BlkForm1Z * UF1;
1 j7 \4 D* q( l) u! t! h' {! J. L1 M        BlkForm2X = BlkForm2X * UF1;
6 u: P- @& c& n/ q        BlkForm2Y = BlkForm2Y * UF1;
! ]. u* R# {' l  Q2 q) B/ Q: l  C        BlkForm2Z = BlkForm2Z * UF1;
- ]7 ^- A3 Q0 P2 o& x8 b- \( B        output $ "BEGIN PGM " Pgn " INCH";; U" m+ a8 L" |( _( B: L
        output $ "BLK FORM 0.1 Z X" BlkForm1X " Y" BlkForm1Y " Z" BlkForm1Z;& O8 r3 ?& `  ~* }+ s' Q
        output $ "BLK FORM 0.2 X"   BlkForm2X " Y" BlkForm2Y " Z" BlkForm2Z;
$ b3 E) q2 s2 I( b1 o        Xlast = x_home; Ylast = y_home; Zlast = z_home;0 d; d  M- M  Z4 b
***<<< End >>>****
6 R/ b4 F; t6 Z7 q+ ~. A7 x& s, \# d0 F1 [; u
; t+ s( q3 s7 u- W
7 u3 E& W9 r* J& y- H/ C' W7 c8 d6 xEND OF TAPE :
; B8 P3 j" f9 T4 E/ x& q# K1 U; z******************************************
& |4 e% U$ E. l3 L( t" ?********<<< OutPut END Tape >>>***********
7 h: _0 X3 P" U5 {- z" S( P******************************************0 k* O, T3 V8 o+ V! Y
; I& `3 z5 H- @9 |! I1 j        output $  "L R F M05";9 \; a0 W( {6 q) p
        if_set( FlagCool _eq_ 1)5 C3 S( G6 f/ M2 U! R2 L6 E1 a
                output "M09" ;
+ c7 S) t2 r" R+ @' z+ z                FlagCool = 0;
- Z/ r( W$ a; Z$ b        end_if;" s& S( m3 M0 C  i/ K
        output $ "L R F M02" ;
. Q1 e9 I6 Y0 A( K        output $ "END PGM " Pgn " INCH "; 0 |2 R: Z6 n, a
2 z8 N7 o2 J( T/ ?        if_set(DivideFlag _eq_ "Y")
. D3 g; q) ^8 ]                print1 \j "( Divid Prog )";
: d3 c) R8 O$ ?7 G& E* n+ E1 P                if_set (ElsFlag _eq_ "Y") output sEls ; end_if;
$ {8 D5 I$ v$ B! g        end_if;
  p  b' r$ G/ Y: F( K***<<< End >>>****: w2 W& j8 D8 R4 K- Y6 M
! m: P( ]& C5 ]
; x0 Q5 N& z' @/ P0 o*>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
& V' c8 X" t3 c" m( M/ e0 iBEGINNING OF TLPATH:3 ?4 ^6 [/ v" h
        if_set(DivideFlag _eq_ "Y"), U; M$ Y$ C/ r& c7 {, W6 p( i
                set_on cut_file;
$ d8 A1 E8 B4 |4 k- Q        end_if;
, Q, v7 h* w  m  ?7 Z% o, B  P# M        if_set(DeBugFlag _eq_ "Y")
& g2 [8 k) P2 O- I                output \j ";( <<< BEGINNING OF PROC = " tp_name " >>> )" ;( A6 W/ S0 q# T) p. g/ }4 m
  u2 H( v8 `6 ^  i  v! b        end_if;/ W0 Y' [( Y! w3 L+ m/ t
7 d8 p% [3 `! n8 N*>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>9 M: S  E& p+ c% N3 o/ ]
BEGINNING OF PROC:
9 p5 b1 o* Q( C2 p3 l" ?        FlagSpin = 0;% G1 X9 J, n8 ~. z& g8 _
        MoveNum  = 0;* l7 Q( e( Y5 A5 K/ }+ a5 M# g$ L( T
        if_set(DeBugFlag _eq_ "Y"): k& x/ ~) W& w, e* \/ y+ K
                output \j ";( <<< BEGINNING OF PROC = " proc_name " >>> )" ;
6 |3 K! V5 l* E% u  D! J                if_set (ElsFlag _eq_ "Y") output sEls ; end_if;
7 X  Y4 `& n! A. z1 N. V        end_if;
MIK.rar
13.34 KB, 下载次数: 13
英制的
发表于 2007-8-7 14:30:29 | 显示全部楼层 来自: 中国福建福州
怎么没有看到解答呀 :L :L
