查看: 5884|回复: 12
[分享] Solid Edge ST4 MP6 Update & crack (by SSQ)
发表于 2012-6-10 04:44:45 | 显示全部楼层 |阅读模式 来自: 俄罗斯
3 K: v1 x$ a# A3 S, V  F$ c
% P; N4 H1 @  t7 X115.com
2 U/ I. B7 d2 l' X( ~7 J+ G: ohttp://115.com/file/an2gmquc#SE-ST4-MP6-32bit-Update-SSQ.rar# \$ G7 }! ?. F$ G% y9 c) q  l
http://115.com/file/dp4z7p0f#SE-ST4-MP6-64bit-Update-SSQ.rar7 e  H. ^1 s4 G& Y3 A5 n, w9 \8 u
9 L3 `  g  ]4 Z7 b' TRapidShare7 }& d: r* G. s: Q2 ~
h-ttps://www.rapidshare.com/files/2166336005/SE_ST4_MP6_32bit_Update_SSQ.rar- g9 a6 \1 {1 `" t4 I+ l8 y* [
h-ttps://www.rapidshare.com/files/50266967/SE_ST4_MP6_64bit_Update_SSQ.rar
4 J+ o/ L5 B5 |$ @6 W: a. \, M& }; ]; V3 G: q. Y
% U- ~7 D$ _% M3 Z' {8 ^+ e) A
List of fixed bugs
/ j0 S- y6 ~9 _! R; C  j5 b) j- N. k! F+ N  ]: e) u
--------------------------------------------------6 _1 O. _5 L. F2 {* G5 N" Q
This Maintenance Pack addresses the following PRs:( y: V* ~2 d0 K  X. i- J
' R1 t0 g0 B- ?% T, @6 c, k===Assembly=== # r; ]! r. z' K' G1 x
PR 1874517: Solid Edge hangs on “update all”
' q2 |1 N7 r. _+ P% nPR 1891465: One of three base planes is missed in ASM file
$ E& J& Z, N  _( a. sPR 6676148: 'Cannot be saved' message when saving a second time
/ Z2 G" K: y0 CPR 6698274: Incorrect orientation of user defined coordinate system8 |) t+ A0 U( ?- a5 M) v
PR 6702320: Normal Directions not shown in Simulation with Edit Region Direction" u0 E. f  J/ K2 w
PR 1882889:  Message "Network error has been detected..." appears after calling GetReadOnly
" V  D1 `1 \1 t; P/ JPR 1857457: Incorrect configuration listed after returning from IPA
" }5 X) D+ P' {+ m5 E. MPR 2186316: Auto restore is not working when using backups
! w6 {! g6 M' Z, _; D  \' |+ l# VPR 6711261: Corruption of assembly file when saving in ST4 due to missing master parts
: T4 i  R* J0 k# o' MPR 1828742: Solid Edge Frame Design / Routing API
* m1 n2 z) T9 Z/ [) [! DPR 1890321: Piping relationships conflict when the fitting is flipped0 d( p5 M+ W& @5 e
PR 2188371: Freezing during save after RMB in graphic window2 g" _5 e( a1 b0 A  l( i( L
PR 6704784: Connectors break when a study is copied7 M$ E+ o' K& l# L; S0 L
PR 6707111: Crashing when updating all links
6 L3 h) J! K; e7 }: s. ]3 S
===Draft===
% B9 D) T2 Z' P7 a. q8 [1 D* K( V% GPaul - PR 1877712: Dimension values are changed after deleting break lines on dft views- }" K: m( j5 V; c# @( h/ N
PR 1878646: Special character is lost by parts list properties dialog
+ b- ?9 j7 C" c3 N1 h0 mPR 1890261: Section View disappears after update
: {) |9 L' t( q0 b4 Y3 BPR 1894625: Unable to read a "Write protected AutoCAD configuration file"
+ [7 w% Z" ?0 ~" I, V6 j8 i# gPR 2190276: The position text strings move down subtly when opening a V15 draft file is opened with ST4
2 W0 J/ L0 h- R2 lPR 6694954: Able to delete in use Style and System Styles via automation) `0 e) J% C; R& e8 _
PR 1862979: draft views of top level and sub-assembly with assembly features
! J. d$ J, k3 hPR 2190287: The position of a cutting plane caption will move upward when the file is opened  G* k; z: a  w# [+ ~! B
PR 6689785: SE crashes when opening AutoCAD file1 T/ o$ \# U$ ?; @; S, }
PR 1892292: performance impact when dragging and dropping a block within a block
- V' e; E& }$ G7 ?, Z* yPR 1894479: Captions of drawing view donґt exported to AutoCAD paper space
4 f4 C" ], y6 O1 f4 GPR 1897666: Cyrillic text is not displaying correctly in the Table/Titles Tab6 s. s8 w- P6 S( _
PR 1898642: Parts list is not out-of-date after adding a item number balloon! R% O2 z9 J0 i6 F) G! V
PR 6689394: Property text relocates itself when its value is changed! V- d  n0 C/ K$ q* P
PR 6690768: Property Text "Width" is not retained
3 a% @+ j* O' G; v% Z! v: L) A! w& t- `PR 1872546: Font changes although font is set in text style
9 p' l6 b3 n3 I, C' tPR 1894504: Problems mapping Tahoma font to AutoCAD
0 B. R! ^( B+ [1 xPR 1894668: Translation from SE to AutoCAD Excel objects is incorrect
& C% `2 X* n8 P5 @1 B1 ]0 k& @PR 1897371: Connectors are incorrect when opening V20 drawing files% M* P% i. m% i- L9 s$ [1 H; u% P) K
PR 1898495: Invisible dimensions are exported visible6 N! h  M# c% u) ~5 t
PR 1823728: Line type scale not applied on Translation to AutoCAD - V4 N: A0 g/ K1 w- r
PR 2196671: View disappears from display when editing its boundaries
5 S/ a5 Q" e- o  l# j- x/ hPR 6720152: Independent detail view profile is shown after this workflow
% K# B) g( `7 v4 P5 G
===Part/Profile/Sheet Metal=== 8 g& s2 _! L+ A5 X6 R
PR 2192364: fixes made to prevent frequent random aborts: H+ x  |: b* H8 V! X( K
PR 1890510: Unable to create Swept Surface with section created within the command
; P8 j) M* S2 hPR 6673535: Physical properties of in Lifecycle Viewer do not match CAD
$ m% c3 z; l' W4 A+ YPR 6681198: Rotate face with 2 points vector fails with no error and cannot save after undo4 ^* ^7 ]( S1 N- ]% y, S0 g) C6 G
PR 6697991: Not all plots are available in Simulation Results/ R1 `" [9 w. x$ F
PR 6553644: activate all crashing after highlighting a groove weld: }2 c* L" c( ~* P' M5 K8 D6 @
PR 1866362:  Feature creation and dimension placement is slow
. p9 T  [% d9 N8 R5 T' o, IPR 1869002: Unable to select edges of other surfaces when creating Contour curves in ST46 K) x' x) l* e1 E& e, ~( C9 c
PR 6702794: .NET Framework error when running seINVENTOR.exe  u3 N: t. F; p( X, }, X  f. u8 P0 ]
PR 1895060: mirrored ribs are not moving together in ST4 like they did in ST3
" K0 |# y" a: {. v1 L: Z            Note: To see the fix, the mirrored ribs will have to be recreated" v) W: B/ c$ R0 W: E
PR 1899239: Color bar values wrong when plotting 'beam end a/end b min comb stress' data
" S$ h. m& i. E1 A, |; r+ i+ H% h9 mPR 6446005: Include fails after editing parent edges
- |+ z7 h5 @* v$ c+ T
===Insight===! c  B) a9 z- b% A6 D9 w( W# [
PR 1849487: INS Poor Search performance caused by sub-optimal SQL query statements
( \3 `5 }, j2 X1 U. H- \& QPR 6571023: Search aborts IE or can hang SE if stopped
" Y0 Y! W7 B5 {" x' XPR 1896255: Insight:  Optimized sql query code shows one regression in search
$ b  p9 K% K; m1 C- |  BPR 2190773: INS opening managed files causes Solid Edge to crash' E5 P& W# ~3 k/ N
PR 1880440: Wrong revision suffix in "Where used file list" for
6 V4 W7 u0 C4 n  \4 U( K===Solid Edge Embedded Client===. M: n. a, s9 u# O; n
PR 1893703: EMF is not created when SEEC_Image_Generate_3D is FALSE
( E3 j- U2 j( m0 }+ pPR 6680750: SEEC Administrator Changes to Support Teamcenter 9.1) u/ f5 c7 d3 Z$ G8 T+ J! _
PR 6705659: integrate 9.1 client to Support Teamcenter 9.1
2 {) x( }. M/ h% x1 ]PR 1894412: Incorrect dataset name for generation of Standard Parts
" F4 q# c  v4 k: _1 GPR 1894960: Part name property setting not honored when placing a Structural Shape
/ A# g. F* k7 J1 }PR 2167437: Standard Parts exits after placing part) ^& B% d+ \$ e" C0 T
PR 1862616: Extended Standard Parts have an inconstant ItemID - Item name in TC. f6 X! w0 q8 S% z3 x: z+ g  q
PR 1896357: Cascading/interdependent LOV not working with SE based Property Category6 s; d8 y/ _/ m# P# z) T
PR 6702262: Adding "Upload" to the QAT causing memory growth: }- a, A3 N7 d! T+ z+ T" y
PR 6717430: Abort due to missing My Documents folder# a1 i4 X& c6 i  N6 s9 _. g/ D
PR 6657723: ItemID Not Generated Like RAC: USER_EXIT Customization
! ]0 v- H- j/ f0 aPR 6718366: SEEC: Tc Exception with Generate JT and AE_dataset_id_usage enabled
发表于 2012-6-10 09:59:43 | 显示全部楼层 来自: 中国北京
Thanks  solid_user
发表于 2012-6-10 20:34:28 | 显示全部楼层 来自: 中国四川成都
发表于 2012-6-10 21:41:27 | 显示全部楼层 来自: 中国上海
更新真快,都更新了什么啊?
发表于 2012-6-11 09:29:45 | 显示全部楼层 来自: 中国山东济南
Thanks  solid_user  me too !!
 楼主| 发表于 2012-6-12 17:45:49 | 显示全部楼层 来自: LAN
更新真快,都更新了什么啊?
# E; o  d% a5 k; d: Zluckboyyu 发表于 2012-6-10 21:41 http://www.3dportal.cn/discuz/images/common/back.gif
2 S1 ]& `' g- ]List of fixed bugs
& [% S; N9 _/ Y' k+ U  O/ _6 b1 {4 Q) L' s8 \$ r6 [5 H/ a* B
--------------------------------------------------+ q6 q- `& D/ q+ x1 s
  l& o( F$ t' i* T! E. o--------------------------------------------------
+ V5 c! W3 u' b$ g4 a. J
===Assembly=== 5 R; a3 t0 m1 w+ H5 f
5 i3 i' X5 j. N4 K3 P: O: ZPR 1891465: One of three base planes is missed in ASM file
: `% {, x2 I% X* tPR 6676148: 'Cannot be saved' message when saving a second time! d9 {2 V( }. G- ^" F+ {
4 u7 i& R$ `  o# L0 H3 NPR 6702320: Normal Directions not shown in Simulation with Edit Region Direction
$ j1 S5 T/ R* T( E5 ^PR 1882889:  Message "Network error has been detected..." appears after calling GetReadOnly+ M' q  G% B+ l1 b: N6 E& }
PR 1857457: Incorrect configuration listed after returning from IPA0 w: _$ I/ }7 K9 c% d
4 f4 p7 t$ }! V! i3 mPR 6711261: Corruption of assembly file when saving in ST4 due to missing master parts
% m0 n; }; x, c  G) yPR 1828742: Solid Edge Frame Design / Routing API
0 C, z4 @, N, r# P5 v6 d' W) @PR 1890321: Piping relationships conflict when the fitting is flipped: l+ B3 b: L* t3 M% D
% s3 J6 {7 Z- p! v' hPR 6704784: Connectors break when a study is copied
  J) }7 v. N  M. x9 E. B: EPR 6707111: Crashing when updating all links
; A% E' f+ [, y; t: O: }9 L===Draft===
: {% R% T7 @$ |) m; H# m6 lPaul - PR 1877712: Dimension values are changed after deleting break lines on dft views! ?' @( N! W: a3 Q" ~
2 J2 O- O" r& |' P1 O8 W  [: fPR 1890261: Section View disappears after update
) E9 n" j/ N3 @9 e, I7 m5 YPR 1894625: Unable to read a "Write protected AutoCAD configuration file"
( g& w2 ~7 A; q. q# VPR 2190276: The position text strings move down subtly when opening a V15 draft file is opened with ST4
  b/ p+ Z& \4 A. u% ~PR 6694954: Able to delete in use Style and System Styles via automation0 q' `! \, a5 }8 O* V2 I
- _6 J6 e! t( B9 @8 w% C0 K7 _' I5 P& \PR 2190287: The position of a cutting plane caption will move upward when the file is opened0 S: R, p: Q8 D4 w
PR 6689785: SE crashes when opening AutoCAD file/ N3 q3 e- d; }9 _
PR 1892292: performance impact when dragging and dropping a block within a block3 ^; M1 r: \# m1 x
PR 1894479: Captions of drawing view donґt exported to AutoCAD paper space/ u% ?6 z: \) n. W6 W& d$ {5 b! ]
PR 1897666: Cyrillic text is not displaying correctly in the Table/Titles Tab8 a8 F; f( N. q
: C$ i, X% f) Y4 p; \2 F3 cPR 6689394: Property text relocates itself when its value is changed
: d9 M+ z% }. Q- e- gPR 6690768: Property Text "Width" is not retained
+ ?. q/ E9 i; Z6 r' H/ W5 [: _PR 1872546: Font changes although font is set in text style6 n, r- |! F4 j
$ {, A# b# K5 M  Z6 |PR 1894668: Translation from SE to AutoCAD Excel objects is incorrect
5 B: l+ `3 b  VPR 1897371: Connectors are incorrect when opening V20 drawing files
# T( E! @# A3 z& C( U; YPR 1898495: Invisible dimensions are exported visible+ N  u7 G* z& i6 V4 z
/ u, E: o! v- s6 LPR 2196671: View disappears from display when editing its boundaries8 l2 b" `7 v. R4 Q& w
" _8 `- C" ?0 V; d, L% M# s
===Part/Profile/Sheet Metal===   x3 {$ ?9 n7 V# I* H) s# G
PR 2192364: fixes made to prevent frequent random aborts, T- V! P& t: z0 ^0 N2 _
" F( _, o* b7 w5 I& wPR 6673535: Physical properties of in Lifecycle Viewer do not match CAD
" X/ d4 a* {) j$ h2 a; CPR 6681198: Rotate face with 2 points vector fails with no error and cannot save after undo7 Z) Z/ S, X. ?: @$ `  D1 A
PR 6697991: Not all plots are available in Simulation Results4 ?% l) A: E. [- V9 g3 s+ H! H) z: s
/ }$ c  ^3 y$ t, ?+ ?PR 1866362:  Feature creation and dimension placement is slow
( ]4 ^. r8 v/ F# r" e/ VPR 1869002: Unable to select edges of other surfaces when creating Contour curves in ST4' o. s* ~% m' x4 Q, i4 c, [: c
PR 6702794: .NET Framework error when running seINVENTOR.exe' h+ J4 k; g0 _0 `5 I' ^
PR 1895060: mirrored ribs are not moving together in ST4 like they did in ST3% J+ O+ p' q, [3 G) U
% [6 r# q5 `/ \$ ?PR 1899239: Color bar values wrong when plotting 'beam end a/end b min comb stress' data
# c, ^/ F& D9 {! B5 g- WPR 6446005: Include fails after editing parent edges
" W4 x7 ~6 _' v& V+ {
===Insight===: m3 s" ^" ?3 G
PR 1849487: INS Poor Search performance caused by sub-optimal SQL query statements, o. n# |+ C3 `7 R$ [; p
3 [, o  h2 `- h4 a: n& m( T! G8 `PR 1896255: Insight:  Optimized sql query code shows one regression in search 1 ?# u; H4 x7 v# i
& b/ ^. w; i- y) X. S% ?" D) NPR 1880440: Wrong revision suffix in "Where used file list" for
3 `# a* Y4 r0 G5 R# X4 S- C
$ B' `6 V" J& d  |: b7 {6 E; RPR 1893703: EMF is not created when SEEC_Image_Generate_3D is FALSE
9 E4 r  \+ z$ ]; d' oPR 6680750: SEEC Administrator Changes to Support Teamcenter 9.19 z; d& E7 y/ |
1 l8 `$ Y; x" r6 T& }: b* yPR 1894412: Incorrect dataset name for generation of Standard Parts
3 f- `# a( j% I. y9 |# K8 {PR 1894960: Part name property setting not honored when placing a Structural Shape
. U2 q5 \# R% H# r  A3 K" w  ^# qPR 2167437: Standard Parts exits after placing part
" z; u) v# q4 v" y0 [PR 1862616: Extended Standard Parts have an inconstant ItemID - Item name in TC
9 z. D% o8 u7 k: H2 M: ?" LPR 1896357: Cascading/interdependent LOV not working with SE based Property Category3 F* n9 l& t) ?, r
PR 6702262: Adding "Upload" to the QAT causing memory growth8 \' I+ L5 n$ y
9 ?. H1 S6 X; Q1 q: _; P5 L% C4 ZPR 6657723: ItemID Not Generated Like RAC: USER_EXIT Customization
3 w& J: f& b  u# q! \PR 6718366: SEEC: Tc Exception with Generate JT and AE_dataset_id_usage enabled
发表于 2012-6-12 23:21:48 | 显示全部楼层 来自: 中国浙江丽水
补丁出的真快。赶紧下载了。
发表于 2012-6-12 23:21:49 | 显示全部楼层 来自: 中国浙江丽水
补丁出的真快。赶紧下载了。
发表于 2012-6-14 05:53:08 | 显示全部楼层 来自: 中国吉林辽源
顶一下  单愿有我想要的
发表于 2012-7-14 22:33:11 | 显示全部楼层 来自: 中国上海
不打前面的MP5...等,可以直接打这个补丁么
发表于 2012-7-19 09:21:37 | 显示全部楼层 来自: 中国山东滨州
发表于 2012-7-21 14:40:53 | 显示全部楼层 来自: 马来西亚
Thanks bro:good
