发表于 2012-9-27 13:17:08
来自: 中国北京
--------------( S2 ?) b. k; E
Legal Notices
! r5 a6 [& l& ?0 r/ b--------------
+ `4 ?6 T4 n& z) s0 Q, b?012 Siemens Product Lifecycle Management Software Inc., {6 G# e; ~" [7 P% t- Q4 T& j8 ~. u
& S2 q/ o+ q8 D- UAll Rights Reserved. m- _: I& c' R$ `# S8 t1 Y
Software, file formats, and audiovisual displays may be used pursuant to the 7 E" g8 y# B `/ s- \
applicable Software License Agreement and contain confidential and proprietary * M+ ?9 j, I' t7 V! h1 Q
information of Siemens Product Lifecycle Management Software Inc.; which is 9 t, V% T4 d1 o S4 K) J
protected by copyright and trade secret law. Such materials may not be reproduced
- X5 i& s" U7 a& K) `3 _or transferred to other documents or used or disclosed to others for manufacturing 1 U6 H% W( |+ s7 D7 j
or for any other purpose except as specifically authorized within the terms of the
: x: O( t" Y; ~- }Software License Agreement, or as specifically authorized in writing by Siemens 6 X" S. j# }) o# F- J6 e' T
Product Lifecycle Management Software Inc.) V. ^9 ^0 I0 q& |. u
r( T. c; ^/ k9 E% N1 h
7 V; z) j: p, B9 P9 E8 d5800 Granite Parkway
6 q' s( E) a4 Z, F( o# lSuite 600' A" N! N o* M0 Z$ d+ X% H2 [
Plano, TX. 75024
* f+ H( i q1 j# [6 n$ H+ [/ t
" [, s+ j( W# i; b! ^, P- h) {/ w- b! @
; C# U+ a1 O' c* ^End of Legal Notices1 w) k6 \# w r- ]7 r
--------------------* I9 g/ ]" n1 d! b5 m x
) m- i- K6 r& [& R; g( j* I/ [2 {--------------
# m- N2 A1 Y; ^1 L% v$ w+ M/ y! gRelease Notes:
6 M7 n- J$ R/ N; y. `--------------
+ @% w- \; [5 Y& \6 W
6 D: H% D. k- P E1 cProduct: Solid Edge
3 ^, g9 L5 ~+ Z0 iVersion: 104.00.08.08
* q" p3 f$ W- IDate: 21-Sep-2012
0 l% I# s j$ M; t& ]7 M8 D/ I5 @( \, w( j9 V9 Q7 ?
Maintenance Packs are all inclusive and can be installed on top of the base ! o$ \3 y+ w6 c4 x, z% f
release or any released Maintenance Pack.
+ D8 M. k" K" w" b# A
* m* r1 }1 `3 Y' A) w1 @This Maintenance Pack can be installed on top of Versions: 3 V/ ?1 F2 p3 X% w: @6 k) O& K6 p
104.00.00.82, 104.00.01.08, 104.00.02.05, 104.00.03.05, 104.00.04.05,! W+ g/ u' g1 u4 s, y4 ]) }+ n- X
104.00.05.05, 104.00.06.05, or 104.00.07.04.
l. `3 J3 ^! ]& Z' X2 X0 r7 `' f8 v7 C8 X; ~+ p1 s
6 q% w7 I! l9 x% e3 ]5 H
--------------------4 E8 u3 I! b( l* U+ I6 `4 o
End of Release Notes
; b" x3 y9 Z, @6 G0 o--------------------: X2 a7 c8 a6 p
' a( u8 M: o1 v% I2 ~1 i% V3 V6 Y( l
-------------------& s3 Q( d: d" k; N N8 j0 D
Installation Notes:
2 M% X M4 I/ f4 u1 f4 [1 R-------------------
+ e; f/ E @, ^
; t9 q( m& ^: q7 o$ F) m$ }After downloading the Maintenance Pack to your machine, unbundle the zip file and 3 L; m9 F3 G, _+ v0 @
then dbl click on exe to install the Maintenance Pack.( `) }- B& E* B# X: ]
3 d; v5 c4 }7 `- q. @8 ~* fWindows 7 Installation tips: In addition to turning off UAC, right click on the exe : G" H: T3 |9 c
and select "run as administrator" to complete the installation. 8 r' Q$ m' a( u9 |$ X
, u, N$ ]6 h. \# o# N
Windows 7 Tip: Most of the UAC security conflicts on Win7 can be avoided by installing
, g4 z4 d: R$ z+ }Solid Edge somewhere other than the default 揚rogram Files?folder. Install in a location
# W5 F' x& h# K+ t( P- rlike c:\SolidEdge\ that the user has full permission to write to.
8 t: H0 O& E. I, G' |+ C4 D) j+ W* g
-------------------3 N- s$ w- b7 f4 Y& Y
End of Installation* P7 w. M: }2 T5 f- V. Z+ Q) K7 _
-------------------& M5 N( b8 d1 p$ n! |
0 x" @/ O, A9 d. G; [. p--------------------------------------------------0 R% \8 R* _* o U
This Maintenance Pack addresses the following PRs:# \0 l6 {6 q$ _/ v( p" ?" L' @
/ L" f# p& U- a# T0 `; m! Z9 X9 @; }) f3 e, W- ?* r
===API===; Y. R. h: a4 q) F
) l( E. F6 I0 m* PPR 2188413: Geometry from addin unexpectedly being removed from UnDo on Next command" s6 [: N6 Z0 ~. o* _2 U
PR 1903366: Replace via API does not work as via User Interface( i2 n/ {; O. z
PR 1891179: GetGlobalParameter (..glMinimumFlatLength) always delivers 0.0025
8 Y8 Z) R, S: ^& zPR 1875930: API - wrong Text Box Width and Weight when adding multi line text O! ]; `1 b: D% p" t! E. O% I
PR 2201222: problem with the method of reading and changing the dimension style by API9 w" N9 p. N3 i7 I8 U5 ]
PR 2201877: API: Parent Object of the fill pattern cannot be acquired# u1 ~8 F Q; h% ~+ u$ I2 S
1 D& n+ t4 N* a/ `
===Assembly===
; ~9 U# Z: t3 H8 Y w. Y8 F* |0 Z5 k8 h# G4 O$ I+ Q' s5 x
PR 1901251: FOA file aborts on open+ u) y0 F9 T8 a9 u e; z# t
PR 1902643: Pattern fails to update correctly when used with family of assemblies
- Q) F2 t d. I% l: BPR 2198695: Positioning of node in Frame Simulation always offsets from Line End 1) q. s/ u: S- Q
PR 1903074: QAT will be deleted after modification
8 t |* Z! o( s/ c% u7 D$ tPR 6608469: displaying subassembly parts.& G# z, }4 Y9 x5 r. a6 [$ T
PR 1900020: display issues after locating dimensions in Assemble
: P( _. o. m9 n& f0 I; `% r# H# {PR 1907507: Failing relationships when assembly features are recomputed in ST4+ i% R6 V( G; T4 ~( [7 [8 i% \
PR 2197077: Error - No License - WEBPUBLISHER# D2 Z% U9 j2 Q1 |4 K* y
PR 6623403: Conflicting error message on feature compute.6 h) a M8 ?9 W: ^4 _- K) w
PR 1903013: Missing override body information caused assembly features to not be visible6 d, ^& y/ D: L
PR 1906702: Cannot place connect relation in some workflows+ a/ A/ Z, g B, ~' l* x: b! f8 X
PR 1902264: A reproducible crash on redo after deleting assembly features2 `" H5 K' b5 H
PR 6769819: Assembly file not shrinking as expected when components are deleted- f9 C' o2 `4 S; o* i2 s
PR 6769125: Multiple Solutions dialog one hour after updating all links# j: B9 \6 d- U9 Q0 x
PR 2201912: Circle not locating properly when creating 3D segment in XpresRoute in sub-assembly
' x8 B) [" ^# e+ [PR 6772627: Zones do not work properly with Adjustable Assemblies; d' r# j( f- Z1 C. ~
/ _* \ y( D% q L5 q1 N, a===Draft===
( A- L$ n( Y, ]+ v8 \
' S4 z& F1 `: b0 N) zPR 1879173: Subscript text size cannot be changed via stack options, u, c5 [ M- _- p! I! {% Z0 J
PR 1904131: The command 'Retrieve Dimensions' generates a small angular dimension2 w. |' q* @3 ~$ j2 u: v5 Q; L
PR 1904254: Fixed a problem aligning drawing views using keypoints to blocks% a9 R9 E4 F U% X4 I
PR 1904828: Solid Edge Crash when Editing Text& V1 A* O$ ?+ b1 M& D. X
PR 1905667: Merge vertical cells with same value doesn't work correctly: z6 T. F6 p% x9 I) P9 m
PR 1906483: Dimension's projection lines are not shown
/ K# E! @% r6 ^5 `5 ~/ I9 aPR 1906525: Underlined balloons added in ST4 to ST3 ones are orientated to the wrong side
9 p. l7 E) r: e2 N2 ~PR 2198792: Dimension disappears when "Convert to 2D View" is executed
p: O9 j& D; L' O( dPR 2200501: Tolerance symbol removed when dimension is dragged in AutoCAD6 \& F: K9 e! |
PR 2202087: Scale line widths should be enabled by default instead of scale line types
; u/ X& l. ?1 k @! y$ s0 o( C: C: APR 1906788: Fixed a problem with LT format code not displaying in Callout text on scalar values1 @" w v, f5 Z9 L) V
PR 1910328: Stretch command does not work on shared embed inserted symbols
1 j- c& z* ~" ~( K$ }5 oPR 6767274: Clicking Back or Cancel in the Drawing View Layout step causes a crash' }; ?- h' B7 S) _
PR 1911446: Save As PDF - No error message when pdf file couldn't be overwritten6 u" F) ?, _1 \
PR 6759715: Center justified callout jumps to the left when modified/ S' w& u8 n- r N$ c0 g" {
PR-6776073: New callouts with property text don't honor the user's return/new lines
" R& t% l' Y7 y% y" g! J6 k# vPR 1909452: Dimensions detach or incorrectly bind on update of view with PMI sections
! v+ E1 W0 S/ q- u. v2 r
/ { L2 |1 c @. ?! R0 h4 w) w===Part/Profile/Sheet Metal===
9 r4 _8 d8 k/ V+ p. m1 Q) ^1 |+ R' B! a' n/ T
PR 1903647: Thread information not being present in Synchronous part copy
6 [4 O T; R2 `/ @' t$ DPR 2198575: Can磘 import CATIA V5 file
8 k) s" \$ w* B5 n- ?+ B ^) PPR 2199611: After adding protrusion 'Edit Definition handles' does not appear for some holes) ?: m# i" Y' ^' N$ g" O/ ?* K; j
PR 2200996: the move faces command terminating if "Ctrl+F" is used/ Q8 r! v5 }; _, Y% Q
PR 6724478: Red Pencils in PathFinder after Edit Profile with no changes s$ C% a8 H7 ~8 S( t* N9 P- j+ L
PR 6735355: Part disappears when adding a pattern of holes
7 B9 ]/ G$ p% y7 k4 gPR 6747704: Not seeing the failure code during preview
. z8 X& H) c% _( Q, _PR 1907418: Solid Edge is closing when using show variability
% e: @3 t1 l; H# J6 L4 a- N* l, XPR 2202748: Abort when using mouse wheel to scroll through MRU
% N- e$ ~! T3 qPR 1902823: Differences in Flat Pattern between ST2 and ST4
# u0 H! u4 z6 I+ m0 c- hPR 1904514: Wrong visualization when suppressing an occurrence in assembly sketch pattern: O; C7 r( p" k9 _8 G
& N6 z* e4 L3 N& |
===Insight===1 K# X1 Z* U4 \& b: @+ g4 y
0 t: r8 y1 h' }4 {/ D
PR 1905478: Revision Manager Set Path Browse for Folder slow performance over network on Windows 7
/ B; l* h; w5 B, BPR 6758938: Bend Radius change is not honored in a SharePoint managed assembly/ _4 Y( x2 M9 U8 V) c
7 i$ N( X! j# L4 Q2 o===Solid Edge Embedded Client===
) F+ e' \9 u) G4 D; W
4 T9 M& x+ U* q! ^2 d8 v* ^- B6 T. kPR 1884750: Diagnostics tool is not working & Q. Q1 p/ R5 o+ p
PR 1902765: Error on save as translated from read-only part opened from assembly.
/ X- [- w4 F/ z4 Z2 ?$ PPR 1905070: Data preparation - Filename with accents / r* E- Q$ k k1 `$ V8 @0 @
PR 6730948: Setting the revision and then the Item ID causes the dataset name to not display1 K2 G( \) N# C- E
PR 6740151: Edge crashes on saving the file to Teamcenter sub folder and then exit
9 S# {+ c: g! e! ~/ HPR 6748390: Query will not return TC item revisions with no SE datasets
/ {3 f( W5 m% kPR 6746704: BOM Dialog display for Empty Item Revision3 T/ R, T7 o" M( S, r' k
PR 1903302: Revise with SEEC_Image_Generate_3D=false creates JT file if already present
9 e6 s0 V |2 F. c! C( e& y( |PR 6721338: SEEC Admin Policy files are getting delivered to the wrong location! M3 X6 F, R) d- a
PR 6760443: Custom Property on draft file converting from date field to text field.
9 Q$ V9 T6 q. s1 _- ?+ iPR 1902441: Save As into existing item revision doesn't work (naming rule)
( O0 u% l3 a0 ~/ WPR 1899293: Non SE datasets are loaded in ST Cache during load process$ J, D2 b' k* B* N* {& X& K) u6 `
PR 1907261: Assigning Rev ID before Item ID in Save As incorrectly names dataset
- C: m4 [# t: w) E" q; oPR 1901182: Property manager needs hour(s) to show properties6 ^1 `7 T( V/ w+ O1 g
& T1 T" B ^ Y
: x$ r( k; p8 w1 @3 F9 T& w---1 ^; |1 y7 t8 I9 Q$ C0 ]
End
% S7 s% R: U" w6 c N--- |
