1天前
查看: 2407|回复: 4
[求助] mastercam9.1 ham机台会抖 大侠们出招i啊
发表于 2012-11-14 15:07:32 | 显示全部楼层 |阅读模式 来自: 中国福建泉州
本帖最后由 KKRC 于 2012-11-14 15:12 编辑 2 z3 O2 H* \. g! _) r- q4 X
) ?/ v2 X0 V# m* h% B
mastercam 9.1 ham铣圆弧机台会抖 过滤也设了下面是程式。大侠们,焦急啊,三菱老式机了' Y0 Z+ q8 c6 }, j7 Q! Q5 n. a9 h" `
5 z2 i. l/ c# q7 O4 x/ V O22224 Q. L2 e7 H6 u% o( F
N100G54; p" ?; w8 o; H9 H. A% E! @
N102G90G80G0G17G40
- [, g* W$ x: z9 V  y (TOOL - 5 DIA. OFF. - 5 LEN. - 5 DIA. - 16.)' N2 ~5 i  ^3 A3 f. K0 T, M$ D
(HSM)
6 t# D( Z$ l% I" A# t1 S5 z9 } N104S1500M3
' x4 n  F, m# s- m N106G0Z57.% [/ y: M6 S1 J, h
N108G0X-2.077Y113.674
" Y( y) c& D* M, n, X N110Z3.M8
7 n" H9 R5 W& q+ Q! r% R N112G1X-2.039Y113.672Z2.61F1200., y" Z9 K# S! p6 `. x! N) g- I
N114X-1.925Y113.666Z2.235
$ T6 b$ O- l7 ]4 Z" T N116X-1.74Y113.655Z1.889
' v" a9 z  H6 t5 ]; y. _3 t; ] N118X-1.492Y113.641Z1.5869 S9 q7 U1 O# u$ l
N120X-1.189Y113.624Z1.337. ^4 S! x, r& S- |, F% D  |
N122X-.844Y113.605Z1.152$ ^# |: X" h9 a- z% q' C) r
N124X-.47Y113.584Z1.038' k* j9 R8 t+ S5 i2 p  S$ }
N126X-.08Y113.562Z1.: j/ k2 S: c2 g1 O
N128X.636Y113.559Z.9788 ^; j/ O; T# M* }* z
N130X1.348Y113.631Z.955+ n, u. v9 W4 P& D* D
N132X2.049Y113.778Z.933
% y: F& u8 ~' q N134X2.731Y113.996Z.91
; u% S5 T6 \# O3 F0 y" a' n. ~3 a N136X3.386Y114.285Z.888
, Z0 a' W2 ?# A/ f N138X4.007Y114.641Z.865+ q1 {* q5 a3 q4 g
N140X4.588Y115.059Z.8430 _( Z+ N' n  ^5 K/ x" a) z
N142X5.122Y115.536Z.82" V- N5 U! t# m) x/ D+ B( S
N144X5.603Y116.067Z.798
* Y: c  N( g# ~! f0 ]. o; b1 |; w* ` N146X6.026Y116.644Z.775  d5 l) F' P+ m
N148X6.386Y117.263Z.753
. n7 j/ q5 Z8 | N150X6.68Y117.916Z.736 X( P1 y' s4 ?0 @! r  p4 j- ]$ u5 [
N152X6.904Y118.596Z.7083 p' V' q) ^" {( q; k
N154X7.055Y119.296Z.685' b! }+ Z1 b5 R' U
N156X7.133Y120.007Z.6630 n' M1 }1 D& G; n/ n( _
N158X7.136Y120.723Z.64* f4 L* J' O/ r
N160X7.064Y121.436Z.618: G+ v) Y- q% V; y& ~! t  C7 s: w% s
N162X6.917Y122.137Z.595
, F' M$ z- L: Y7 Q! o N164X6.699Y122.818Z.573
5 q& b. J$ e- B" a6 t" p; q7 l" w+ \ N166X6.41Y123.473Z.55
$ e3 x! e# O( Y- D, q. K' o N168X6.054Y124.095Z.528! X: \* N3 {# m: p8 S  C
N170X5.636Y124.676Z.505/ u9 h* d: u$ a- @) x% F, p# O
N172X5.159Y125.21Z.483
7 T5 Q8 \1 r2 U6 ?2 U. @ N174X4.628Y125.691Z.46
. g6 G7 a/ k4 Y, F  z: t& [ N176X4.051Y126.114Z.438; m! a$ G8 e+ p1 [( H( v8 Q! Y
N178X3.432Y126.474Z.415
+ \, p8 e. `  j- _! a N180X2.779Y126.768Z.3932 P; f. _- G# ]0 Y" T
N182X2.099Y126.991Z.379 Y* Y1 A3 I& s* P
N184X1.399Y127.143Z.348
" O" T4 T, z( s( z3 |: S# U N186X.688Y127.22Z.325
8 ~# H/ H; y+ L+ j6 c N188X-.028Y127.223Z.303, b$ k- c1 G/ L( M; m
N190X-.741Y127.151Z.28! D5 \. a8 i+ M( m% Y; k" ]
N192X-1.442Y127.005Z.2585 ?: Z/ m: L* |8 p
N194X-2.123Y126.786Z.235
* k# W8 W+ a2 x- D" R4 J N196X-2.778Y126.497Z.213! ]) N: I2 A$ T! {3 `% h
N198X-3.4Y126.142Z.198 }; l& S) B! k' N: k; Y; L4 J0 B. j
N200X-3.981Y125.723Z.1685 M( \' u1 |7 _* N' g: Q% B
N202X-4.515Y125.246Z.145$ f7 D1 G" \; g  b2 i7 a
N204X-4.996Y124.716Z.1238 W! Q7 j8 H4 r2 W- z( o5 w8 C; h+ W, a
N206X-5.419Y124.138Z.1! f' v, @5 h1 z# s1 m1 k
N208X-5.779Y123.52Z.0786 s  e( e# D. ?/ q1 v- O. }+ `
N210X-6.073Y122.867Z.055
. d% A- @2 ?+ U8 d9 S5 D' }* p, [0 x N212X-6.296Y122.187Z.033; h; B4 v$ n" ^) n: Q, s
N214X-6.448Y121.487Z.01
% Z. j. f  T5 G$ Y N216X-6.525Y120.775Z-.013
; P- c$ i/ |2 R5 @* j N218X-6.528Y120.059Z-.035
- j! n# b( @2 H7 H3 F N220X-6.456Y119.347Z-.0580 Q9 K( Q4 D( I" w
N222X-6.31Y118.646Z-.08
) Y% ^  \3 I/ Y0 C, N" f# ^ N224X-6.091Y117.964Z-.103/ @1 h  E3 J9 T& N% N# G6 w
N226X-5.802Y117.309Z-.125
3 x4 f$ m6 o4 w8 q2 f0 Z N228X-5.447Y116.688Z-.148% O1 r+ q  ]1 S# Q
N230X-5.028Y116.107Z-.17
1 _% d" f$ A$ p% r( @ N232X-4.551Y115.573Z-.1930 e% Y* k4 ]! S6 {
N234X-4.021Y115.092Z-.215$ S2 o  d) o2 o) k
N236X-3.443Y114.669Z-.238$ i$ I$ f, ~3 b. F$ T
N238X-2.825Y114.309Z-.263 n. M' A) J& s5 e
N240X-2.172Y114.015Z-.283
; \; `, N; k1 d. L" W( Q N242X-1.492Y113.791Z-.305) q9 ~  q0 B$ I! N" F1 r' h/ }2 |
N244X-.792Y113.64Z-.3287 s8 K6 O+ N) Y; e# u
N246X-.08Y113.562Z-.350 Q) Q. ?( ^! d; g
N248G3X1.434Y115.143I.081J1.438F3500.4 l- {& Y8 }" r" t& t9 K: X- @
N250X-.08Y116.438I-1.433J-.143
  t2 G) \$ d# y! e4 a8 I, m: I N252X-1.439Y115.I.081J-1.438
+ Q4 u9 o5 ^9 t: F' p* B. H/ y1 H N254X-.08Y113.562I1.44
7 {' L' a7 O3 M. I, | N256G2X1.614Y111.896I-.101J-1.797
9 e* S- @. z. y; z: I4 I N258G1X2.136Y104.774+ M% C1 d2 M! W% q: O1 G0 D
N260G3X4.584Y103.228I1.795J.1324 {5 x* T( o- h! e! t) v0 o
N262X12.572Y116.253I-4.584J11.772
- @1 ~) s, J  S6 m" k& y; A( E. p, A' z N264X-.708Y127.613I-12.571J-1.253
& ^7 k1 }; m' A, a" f7 M" q N266X-12.632Y115.I.709J-12.613
& ]! v, m0 Q/ X8 g3 \* y4 ^ N268X-.708Y102.387I12.633" \7 t8 ?7 x/ _8 o9 c. t% f
7 i4 [/ W& R, I, b; ?% r# Z, F& @/ j! T' P' G$ u! g6 u
! t; D+ @- q' P( ]0 p
发表于 2012-11-14 15:23:10 | 显示全部楼层 来自: 中国台湾
8 k, k& O; M  _. g- R
7 }4 {$ l+ p2 K; ?3 J造成可能的原因如下..
& G# z# f6 w8 R; H( [; Y- @
( r, N& Y- b5 e1:看機台本身是硬軌還是線軌 (硬軌進給率快 跑起來會抖 最好程式再加上g5.1Q1會好點)
; _& |, Y! a7 _( s$ i! p6 r% y$ G  c) n$ G
2:控制器差別 (控制器預讀程式列不夠 機台來不及反應 程式會因此遺失一小部分)
5 R7 k3 W% p* I, |( E
5 o; A- t$ I7 C2 W* [( [3:程式方面有錯誤  (可以用軟體模擬看看...)
$ O. B/ w9 [$ N$ O9 p; d! d( \' q$ @. [$ K' W% U$ y# }' v
我遇過大部分原因是 機台本身為硬軌+ `6 d7 A1 \% ~0 t0 G3 A
 楼主| 发表于 2012-11-14 16:04:16 | 显示全部楼层 来自: 中国福建泉州
cnc0304 发表于 2012-11-14 15:23 static/image/common/back.gif3 E* Q) p5 v; M, ]* B" T3 N/ K* y
造成可能的原因如下..5 E$ [; b% g% R7 w1 D
- N8 j, B0 D/ s
1:看機台本身是硬軌還是線軌 (硬軌進給率快 跑起來會抖 最好程式再加上g5.1Q1會好 ...
9 Z4 V3 Y7 e% g: ~8 ?( f9 {! c
是硬軌机台,这是挖槽铣圆程序只有最后一圈圆弧才会,前面不会啊
发表于 2012-11-14 16:21:05 | 显示全部楼层 来自: 中国台湾
進給率改慢,程式頭加上G5.1Q1 程式尾G5.1Q0, 試看看唄# z+ o8 ?- L  o5 q7 C
(再不行 po最後一段程式 看看)
发表于 2012-11-25 18:30:56 | 显示全部楼层 来自: 中国福建泉州
cnc0304 发表于 2012-11-14 16:21 static/image/common/back.gif
$ Z& S* [& _' }# ?# G5 |6 Z進給率改慢,程式頭加上G5.1Q1 程式尾G5.1Q0, 試看看唄  ?8 J, u7 Y5 D) P0 d, d
(再不行 po最後一段程式 看看)
# e2 F* r% e; G( [% j
我也遇到这样的问题,换后处理
