查看: 3207|回复: 4
[分享] 自己做的一个acad中打开其他文件的宏vba
发表于 2006-6-22 10:40:27 | 显示全部楼层 |阅读模式 来自: 中国山东青岛
添加个窗体,在窗体上添加几个控件可
* U5 X7 F) |% f* \, h, APrivate Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, _
9 z* ~: [' d* b: q3 U0 K; q& Z7 Y    ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, _
3 v/ R9 P  h0 ~: m    ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long: ]; m* T2 g5 z6 A8 F; V
: O' e5 \5 H. m" RFunction FindFiles(path As String, SearchStr As String, _
6 B7 Q4 Q3 ~) \3 a8 ~0 w5 S# t( j       FileCount As Integer, DirCount As Integer)
/ ?! X8 M5 S% Z1 J8 Q6 A' a2 w: u      Dim FileName As String   ' Walking filename variable.
* P6 H- i( x/ g: M* p* p0 i      Dim DirName As String    ' SubDirectory Name.
4 r+ @/ a* [# U( Q7 W9 F2 @& C  t      Dim dirNames() As String ' Buffer for directory name entries.# A( E4 b6 n: G! w/ h6 D/ e: N* g
      Dim nDir As Integer      ' Number of directories in this path., j6 W' z( O; |8 K% [4 B
      Dim i As Integer         ' For-loop counter.
  T1 V6 H% [* V5 }+ m0 i/ d5 i8 f, D8 x# {6 b+ j
      On Error GoTo sysFileERR
( P9 m8 P* w5 C' ~& ^2 |" y! ^      If Right(path, 1) <> "\" Then path = path & "\"
# p: ^& K* _5 s" M( [      ' Search for subdirectories.
* L6 D: e1 H0 s) U* B; k1 k. ^- A      nDir = 0
  I( Z/ e' A- J) B- A0 ~% R      ReDim dirNames(nDir)
! S! L' [9 |' C5 u# z      DirName = Dir(path, vbDirectory Or vbHidden Or vbArchive Or vbReadOnly _
: v" q$ {5 a+ g1 j$ r; xOr vbSystem)  ' Even if hidden, and so on.
- C- u* @6 \$ {. F; z      Do While Len(DirName) > 0: W5 U1 [2 E7 B5 |5 v
         ' Ignore the current and encompassing directories.
0 p2 r7 t1 A9 }4 G! ]" D         If (DirName <> ".") And (DirName <> "..") Then  y& _5 Y* @- }6 W4 x
            ' Check for directory with bitwise comparison." |# M7 N, ^4 i' A
            If GetAttr(path & DirName) And vbDirectory Then6 i) Y3 X, ^5 Q( s: C
               dirNames(nDir) = DirName1 f. z( |0 t+ z8 U0 L. `3 Q9 \( b
               DirCount = DirCount + 1
2 x8 d6 p# H# E2 N               nDir = nDir + 1" }4 b( A) a2 \$ R
               ReDim Preserve dirNames(nDir)
# X, K7 G7 U4 A( P               'listbox2.AddItem path & DirName ' Uncomment to listbox
. L' E- \$ u  u  k1 U            End If                           ' directories.* ~* W* ~8 o7 u( W: N
sysFileERRCont:# O$ e, D+ B  Q' G1 b
         End If) k" O) B1 N9 `2 p5 w
         DirName = Dir()  ' Get next subdirectory.
; h$ B! d; Q3 q3 `      Loop; ^, `. Z6 z' D9 g
5 H; K2 U4 d9 P% M1 d      ' Search through this directory and sum file sizes.; F$ S/ a# O2 v" r+ E' Q
      FileName = Dir(path & SearchStr, vbNormal Or vbHidden Or vbSystem _3 w& B0 _8 i2 n0 U
      Or vbReadOnly Or vbArchive)
) q6 U8 U& f" T: |% p. y! \2 b, G      While Len(FileName) <> 04 e4 E) s4 E4 I
         FindFiles = FindFiles + FileLen(path & FileName)6 m; o8 {& z! q0 l
         FileCount = FileCount + 1
( u) l; s! l- q5 \3 j         ' Load listbox box
! z( z5 v7 M- z" P         ListBox2.AddItem path & FileName '& vbTab & _  p+ ~) I# a! P# H9 ?3 o" t
            'FileDateTime(path & FileName)   ' Include Modified Date
$ W3 r7 n& ~) J% Y         FileName = Dir()  ' Get next file.: A* @, v  o8 }/ t6 E5 Y$ V& J% Z% k
      Wend
0 |3 W" R7 ?& x9 Q* C: {8 q5 ]% \
1 r6 s) i0 B/ f3 L      ' If there are sub-directories..
! q  [3 x/ u4 m2 M- S) [' c. c3 F6 g      If nDir > 0 Then; A* c; f" b/ z: q( Z7 t: S
         ' Recursively walk into them
5 l# U* @0 `$ V         For i = 0 To nDir - 1
( y/ u7 H! p4 \0 [           FindFiles = FindFiles + FindFiles(path & dirNames(i) & "\", _) r; B& {  L3 P, Q  F  l
            SearchStr, FileCount, DirCount)+ I; i/ ~' w1 h; t* a  q" c" _
         Next i" r7 N8 b9 q2 i& N- B
      End If; Y2 K) X* v# w$ I9 U0 T
9 u- ~4 ^7 x  }! K( v2 D
AbortFunction:) v3 h% R9 l& b
      Exit Function
; }/ i" }7 ^+ s3 v* j+ I% jsysFileERR:3 k$ T, c' W3 z$ |9 |
      If Right(DirName, 4) = ".sys" Then
9 c# z, W' b9 @3 [' a        Resume sysFileERRCont ' Known issue with pagefile.sys* }8 _* W3 `% x! ^  c
      Else8 g/ d1 G. W) H& N/ v) U  ^4 _
        MsgBox "Error: " & Err.Number & " - " & Err.Description, , _
& m1 R( X. @4 I         "Unexpected Error"/ {; ]  w% c/ t4 X2 Y$ G3 c2 E0 X
        Resume AbortFunction
+ z6 @6 ^) i! k: \; m( H      End If1 \5 F& D! J3 K1 \
      End Function3 d! w: a7 i2 B. M0 Y; P
5 u- o7 e* d( l0 hPrivate Sub CommandButton1_Click()
% s. G# r7 \5 A" B' ?/ X) gSearchForm.Hide, E9 ?/ H7 q( t1 N- |
End Sub1 j: Z6 @: q  F- h) h% Z. ]
$ I( m# v5 H8 k/ r. ^8 w8 p3 c
      Private Sub Commandbutton2_Click()9 b! o5 C8 S% t
      Dim SearchPath As String, FindStr As String* d7 `) K: ?+ M1 N( b5 I- j7 x
      Dim FileSize As Long
- t, Q4 a/ I. f, r! j      Dim NumFiles As Integer, NumDirs As Integer
+ c) ^  {. z9 V( ^( ]: T9 b& G5 y% s' n) J7 {: _) f
      'Screen.MousePointer = vbHourglass% S& E8 t# D, j* g. K( P
      ListBox2.Clear
! j: V. w( O: D/ F# \" s' j      SearchPath = TextBox1.Text# o  ^$ x3 H: f' A) \4 H
      FindStr = "*" & TextBox2.Text & "*" & TextBox3.Text
3 E6 C8 q+ h- g5 x) k      FileSize = FindFiles(SearchPath, FindStr, NumFiles, NumDirs)3 Q8 M7 u  i6 y" _2 |
      TextBox5.Text = NumFiles & " Files found in " & NumDirs + 1 & _2 x, ~- Z3 r) j0 O# q
       " Directories"
# R- R" w; g0 F" V      'textbox6.Text = "Size of files found under " & SearchPath & " = " & _
( [! c- l. O4 v$ ^, a% F9 t& y& z      'Format(FileSize, "#,###,###,##0") & " Bytes", z# ~( K4 @3 @* k+ j' \- j7 F
      'Screen.MousePointer = vbDefault- H  N0 I0 Q( Z3 B9 }: w
      If ListBox2.ListCount = 1 Then ListBox2_Click
2 W5 P) U# H$ M0 l0 e; k* k4 U      End Sub
* {- x% f: y1 v) p* a. |# c( [0 m! `' q& e2 ~$ d4 E8 y% j  N
; T( }9 t- ^" ^1 u; ]; wPrivate Sub ListBox2_Click()
. l6 `: n8 g7 C; l9 @Dim strfilename As String; ?1 Y& E$ V" V5 C+ u- r# T5 b
If ListBox2.ListCount >= 1 Then/ Z- i! w0 S3 M, _% t6 o
    '如果没有选中的内容,用上一次的列表项。/ x7 O+ J' e% |' _
    If ListBox2.ListIndex = -1 Then+ F% Q1 i- `6 t2 t
        ListBox2.ListIndex = _
% r& [9 o+ |+ U/ K+ H8 n  N9 p9 q, `                ListBox2.ListCount - 1
; K! j4 {! \. H, e# z- L( o/ B    End If4 N" T; E' s  \9 I# c5 J7 Q  w
    strfilename = ListBox2.List(ListBox2.ListIndex)
- s6 k0 Z% ?( t: s5 J: g    . ]  e1 [2 T1 Y8 I  ]
    ShellExecute Application.hwnd, "open", strfilename, _
. D" Z; U7 V+ N  f2 p    vbNullString, vbNullString, 32 H6 r" F, ^+ U4 z/ T
End If
1 A/ s; E) K. s8 t  F8 c! \( c# Y) ~8 P5 \7 S
3 v: [+ |0 P2 G3 T
End Sub
0 V8 f4 |  Z4 Z1 ^! \
+ d0 t! f! U& l  }$ J1 ]# B' zPublic Sub Start(ByVal strfilename As String, ByVal searchfolder As String)' w+ U# w0 J' j2 `8 C
Dim sel* q) e( j) J  i- _
Dim fs6 Q+ j2 W5 J) i& n4 n
CommandButton2.Caption = "SEARCH"  l/ d% o( m7 E' Z4 |9 x
'MsgBox (strfilename)/ `* W" x1 c: E% v" ?, E
strfilename = Strings.Left(strfilename, 8) '取前八位
8 L# t- ^6 W/ E5 k, P& HTextBox1.Text = searchfolder
- v. ~6 d( D& R4 g. }TextBox2.Text = strfilename, h% g; Y& F5 v$ R2 ~. {
SearchForm.Show vbModeless
) g9 O+ i; |) v8 S$ |( e' k) H3 |; J* z
If Strings.Left(strfilename, 2) <> "17" And Strings.Left(strfilename, 2) <> "H7" And Strings.Left(strfilename, 1) <> "S" Then# I' ^* C6 O* l/ z  {6 K
    MsgBox ("Not drawings No.")
4 F9 O& ]6 B3 W* B- X    8 ]# K* D' P2 d  J5 P
    Exit Sub" J) ~1 A& p) k, E. l( g9 Z) C5 ]. e4 {0 d
End If
* S( d1 A$ E5 t) i& I+ R
! }: F# F3 G. u/ C% I: `: J6 ]. T      'CommandButton1.Caption = "Use API code"/ B3 E. x1 ^" d
/ M9 [# E' x4 W' e/ N' y- Z0 d      ' start with some reasonable defaults
+ a# c" O: ^: T+ F7 R2 F. z, d      Commandbutton2_Click
$ [" m2 i5 a) UEnd Sub
 楼主| 发表于 2006-6-22 10:41:49 | 显示全部楼层 来自: 中国山东青岛
如有要得,可以发个dvb文件
为了方便打开图纸中零部件的图纸而做的
 楼主| 发表于 2006-6-22 11:19:05 | 显示全部楼层 来自: 中国山东青岛
我想把东西贴到帖子里
需要什么条件,水能说一下?还要什么等级么,我看了帮助也没搞明白
发表于 2006-6-22 13:09:47 | 显示全部楼层 来自: 中国四川眉山
 楼主| 发表于 2006-6-23 08:32:55 | 显示全部楼层 来自: 中国山东青岛
哦,忘记说明一下
在看装配图的时候经常需要打开明细栏内的零件图看一下,结果要到windows里查找打开,很繁琐。
9 H7 G$ S' q( I# d; j( O$ E( `后来狠狠心 做了这个宏,操作时运行宏,选择需要打开的零部件图号-文本,可多选。然后宏开始在特定目录中查找,如果只找到一个文件直接打开,如果找到多个就在list表内显示供选择,单击打开。
( x) O( m5 A9 ?; ^+ ~. K7 M8 t5 ]用的时候可以修改查找的目录,图号的规则
4 S" D/ h9 s4 J8 v) I我写的时候目录为“x:”,我公司图号都是17或者H7或s等开头,查找前首先判断选择的文本是否是图号的文本,以防误选而耽误时间。
$ M# F. |2 V8 \另,这个vba也可以在excel表内使用,是个通用的
5 e% E, u; V9 b6 j2 U+ ^, a8 f4 U当在excel内查看部品明细时,也是类似操作。
