2天前
查看: 5748|回复: 8
[讨论] 官方Mastercam X6 Handbook Volume 3五轴学习资料购买
发表于 2012-11-20 14:08:29 | 显示全部楼层 |阅读模式 来自: 中国江苏常州
2 `- z3 |  K7 P& F4 a7 j( o
4 r, _9 C' v2 Z0 s& E: RX版五轴采用Mouldwork 模块,Mouldwork五轴比较流行,很多CAM五轴部分都采用其模块,如Cimtron 、CAXA等,苦于没有资料,故发起此贴,其因在于寻觅有共同学习方向的朋友,欢迎加入学习队伍。
+ z( [! a# C& {6 C$ {% Y9 g) Z# |
: D3 [3 F; s0 E0 r3 U3 Y以下是Mastercam X6 Handbook Volume3 五轴部分的说明书的介绍& x7 i0 C0 ~% }4 E( E, H. a  ^$ n
2012-11-20 13-42-07.jpg 0 ~( i6 e* ~% ^" B; _, A
The Mastercam X6 Handbook Volume 3 is an excellent resource that teaches the theory of multiaxis machining with Mastercam. The material intertwines conceptual subject matter with practical applications suitable for intermediates and those that have completed Volume 1 and 2. This book covers the classic family of multiaxis toolpaths including Drill 5-axis, Curve 5-axis, Swarf 5-axis, Multiaxis Flowline and Multiaxis Multi-surfaces as well as the Drill & Circle Mill family. More advanced toolpaths are then outlined starting with the custom application toolpaths and selections from the wireframe, surface and solids families. The book touches on the usefulness of Machine Simulation; used to check for collisions between the part, the tool and any of the machine’s components. The X6 Home Learning Edition Software and the files referenced within the book can be downloaded from eMastercam.com3 S. l" _: ^% ?' H6 r1 `
目录
! D3 a6 H5 W% e$ b; r1 b( e7 LChapter 1:        Introduction To Multiaxis Machining  ......................................................................... 3
$ ?6 i; u6 `" _$ |Chapter 2:        Multiaxis Curve Machining ........................................................................................430 E, w4 l+ l: T1 h
Chapter 3:        Multiaxis Swarf Machining ........................................................................................81
% V$ c  c! d5 {9 F0 W; B+ qChapter 4:        Multiaxis Flow Machining..................................................................................... .....97
3 E' K/ {$ C# u+ g( VChapter 5:        Multiaxis Msurf Machining......................................................................................111
1 `, }9 k% C8 m- i0 YChapter 6:        Multiaxis Port Machining ..................................................................................... ...123# b% {( d: y9 U" t( B; W
Chapter 7:        Rotary 4-axis Machining ...................................................................................... ....133$ Z! D, [% m! B9 Z
Chapter 8:        Multiaxis Drilli ng & Circle Mill  ............................................................................ ....145
1 N' q2 g# Q0 dChapter 9:        Advanced Multiaxis Common Parameters ..............................................................163
' t( R$ s- D' a' kChapter 10:      Multiaxis Wireframe Family Toolpaths ...................................................................227$ H! d. a9 u# z+ L5 f5 U# ^2 r* O
Chapter 11:      Multiaxis Surface/solid Family Toolpaths ...............................................................237
7 |1 z3 q; |) o. Y; B" SChapter 12:      Custom Application Family Toolpaths.....................................................................249- e% p) P) Y  J; d+ `! @3 ^0 c
8 U6 C( c. k6 u0 p为什么要学五轴?5 t7 W. ?% o  [9 m, g1 D+ a  a4 F
五轴刀路策略丰富,不仅用于五轴,亦可生成三轴、四轴程序;
! W5 _& l/ D" J8 ~, v$ u五轴机床越来越普遍,非常有必要掌握五轴加工知识;0 Z: z4 `4 J8 g: s( L
% V7 z" G' T! Q7 k$ i
怎样购买?
8 }, W& _  s' T) s9 @3 r6 S( J海外代购,官方pdf版价格85$,截止发帖已有3人加入,1人待定,最终价格按人均分,最终名单通过邮箱及本贴公正,任何质疑请提出!需要的朋友联系我ETG_taoshx@163.com. 为了公正,后面的人请务必跟帖!
& W$ F1 S8 W, I, t5 ?% {, f" g: f- ^* Z. D( L1 K. P
发表于 2012-11-20 19:25:12 | 显示全部楼层 来自: 中国福建厦门
帮你顶一下,如果是汉化了的,我自己出85$都可以。
 楼主| 发表于 2012-11-20 20:31:19 | 显示全部楼层 来自: 中国江苏常州
0 I$ S% Y- i8 M$ K1 h8 y
- J) d0 h* _% e9 @+ G9 [300页不到,图表多,文字少,汉化很容易。
 楼主| 发表于 2012-11-21 08:00:24 | 显示全部楼层 来自: 中国江苏常州
本帖最后由 ta488 于 2012-11-21 08:28 编辑 ; o6 s7 B' j) E  K
( j  C% _. `" {% }: t- }
发表于 2012-11-21 16:12:18 | 显示全部楼层 来自: 中国湖北荆门
英文不好,期待大神们的汉化。
发表于 2012-11-21 16:24:17 | 显示全部楼层 来自: 中国上海
中文的会考虑
发表于 2012-11-22 13:16:41 | 显示全部楼层 来自: 加拿大
友情提醒:这种事最好私下PM, Copy Right 问题。
 楼主| 发表于 2012-11-22 13:46:11 | 显示全部楼层 来自: 中国江苏常州
学习和研究用都不够构成侵权,国际法庭有这样的案例吗?
发表于 2012-11-22 14:16:00 | 显示全部楼层 来自: 中国江苏盐城
帮你顶一下
