OUTPUT $ " "TP_NAME" "USER_NAME";
0 K2 w4 Z6 R0 q OUTPUT $ " CURR_NAME " " TOOL_CMNT " ;" \; T2 a! k7 M; i/ u$ ~
OUTPUT $ "DIA.=" DIAMETER_ ", R=" TOOL_RAD ", Cut Length="CUT_LENGTH",Clear Length=" CLEAR_LENG ")" ;
- u; s9 ?$ X5 V: Z' o9 R OUTPUT $ "(Offset=" CONT_OFST ",Tolerance=" CONT_TOL " )" ;
, z# s9 }/ @* ]* k4 o3 t OUTPUT $ "(Offset=" PART_OFST ",Tolerance="PART_TOL " )" ;
- |' n/ V/ W' I s' r OUTPUT $ "(Down Step=" DOWN_STEP ",Side Step=" SIDE_STEP " )" ;) Y. q) b( s$ \4 a( M& w# v
OUTPUT $ "(T" CURR_TOOL "M06)";
! h! a6 s9 P: l, C' B OUTPUT $ " G43 H"CURR_TOOL "Z" Zhome " S" SPIN_SPEED " " SPIN_DIR" ;
6 g! k7 S1 ?& y, w
: o3 [( e- E3 ?) j) E) {5 ^上述是GPP1后处理exf片段,在GPP2里怎么译过来?部分识别不出。/ f* B6 A5 V* G/ [" v
目前个人知道的S" SPIN_SPEED " " SPIN_DIR "不变,"Z" Zhome "改为"Z" Z_home ",
4 y" m y+ g X b' o" \5 ^8 T7 j3 W其他的呢?版主或知道的同志们出来告知一下,最好能提供更完善的命令集或ex2源文件。谢谢! |
