查看: 7595|回复: 12
[已解决] cimatronE8.5打开时提示怎么回事
发表于 2012-12-12 11:52:45 | 显示全部楼层 |阅读模式 来自: 中国重庆
各位大哥帮小弟看下,实在没办法弄了。到底那里的问题
发表于 2012-12-12 12:03:30 | 显示全部楼层 来自: 中国广东佛山
授权到期了或没破解好,(如是授权到期了的话可以调整授权文件内的日期)
密密麻麻 + 3 应助
 楼主| 发表于 2012-12-12 12:36:53 | 显示全部楼层 来自: 中国重庆
deqjhwxf 发表于 2012-12-12 12:03 static/image/common/back.gif0 i$ _5 I, t5 [# e
4 q% W6 @2 {" E' |8 O( h
#FEATURE CORE_ELECTRODE cima-d 8 31-dec-2018 uncounted
0 R6 T3 ]5 t% Y8 x. }#        HOSTID=705ab6681c40 ISSUER="Team oDDiTy" SIGN=6DBC437817BE
# ^6 y8 N% U" [  B
. @( m$ |3 k3 \1 PFEATURE CORE_STANDARD cima-d 8 31-dec-2018 uncounted \
* ^% b6 d& z7 M$ s9 V9 {        HOSTID=705ab6681c40 ISSUER="Team oDDiTy" SIGN=3FD12FC0DD54
! d3 s7 K: l3 k  S( W9 |  iPACKAGE ODT_SHOOT_PACKAGE cima-d 8 COMPONENTS="$oDDiTy_rOX SLA CORE \3 k. \6 @1 T  y8 {5 \8 v7 g$ [
        CONCURRENT_DESIGN CATALOGTOOL KINEMATICS QSPLIT DIE_FORM \
& h0 u# x# G4 l  A8 g        DIE_BLANK DIE_STRIP DIE_TOOLS DIE_PLOT DIE_SET DIE_LABEL \
6 V/ z3 u" ?' h5 y# s2 D7 C        2X-MILL 3X-MILL 3X_SIMULATOR 5X_SIMULATOR NC-LINK CAD_MODE \( W; U2 |+ b8 y3 Y
        QUICKDRILL MACHINE_SIM MOLDDESIGN QELECTROD QCOMPARE AUTODRAW \
. i, Y* i) m6 A        AUTOMATED_DRILL BEND CATIA CATIAR2D CATIAR3D CATIAW2D CATIAW3D \
/ s. U' _9 F* f5 C        CIMACABLE CIMADEK CIMADEK-NC CIMADEK-RUN CIMARENDER CIMIT-M \
! D/ E' {5 T* Z        CIMIT-N CIMIT-D CIMIT-MD CIMIT-MDN CIMIT-MN CORE-M CORE-X CPDM \' J7 Z" i9 Y2 D) m# h9 {! d8 [
        DIE_FLANGE E_STAMP QUICK_NC GPF DRAFT EDMS-LINK \& k+ x! |4 `1 Y
        EDM_SETUP_WIZARD EDM_WIZ_AGIE EDM_WIZ_DPC EDM_WIZ_INGERSOL \
. w" P- z( V8 Y, [5 j        EDM_WIZ_MITSUBISHI EDM_WIZ_CHARMILLE EDM_WIZ_MAKINO \1 h$ J  J2 c) k
        API_DE_Global API_DE_SPLINE API_DE_NADELSTICH API_DE_MESSEN \
- }! \4 g7 }" g7 o0 f; B; P$ ?        API_DE_ReadInventor ELECTRODE FAST_BLANK FIKUS_IGUS \
2 J+ T% U! _# L+ I+ K        FUSION_FULL GPP2_3X GPP2_5X GPP2_DEV_FP2 GPP_DEV_EX2 GUN_DRILL \
8 Q/ y1 t% s1 ]; k        LATHE LATHE_2X LATHE_3X LATHE_PP_COMPILER MACHINE_SIM_CONFIG \$ d( O# E5 {3 a0 a9 V5 b9 O
        MACRO MICROSCRIBE_IF MICRO_3X MICRO_5X MOLD-EXPERT MOLDBASE3D \
2 s& Q& Q8 z' Q, e1 D2 N        MULTI-USER-1 MULTI-USER-2 MX-MOTION-EDITOR NC_UNDERCUT NESTING \
+ X+ c7 Z9 D$ b; Z        NETWORK_ENABLED PAR-SHAPE PARASOLID_READ PARASOLID_SAT \4 n2 N& v, g+ s! L2 q( q
        POST_CONFIG POST_DEVELOPMENT POST_PRO POST_RUN PUNCH Q5X_CONT \( A  P) G7 _, U1 T( M: e
        QCON_C QCON_Q QCON_S QUICKCONCEPT RD-PTC RE-ENGE R_CATIA5 \, i! }* ^& ?0 Q
        R_CATIA_2D R_CATIA_SAT R_IGES R_IGES_SAT R_INVENTOR \5 P6 C9 m! Q$ L5 u- x0 _' h5 _1 T
        R_PARASOLID R_PROE R_SOLIDWORKS R_STEP R_STEP_SAT R_UG R_VDA \
6 z6 E+ }1 f8 r1 ^        R_VDA_SAT R_VRML SHOP-NC SIMULATOR SOLFAST_FULL SOLID \
6 y: V, B: J) k% L& W* \+ @        SOLID-ASSEMBLY STEP_READ STEP_WRITE SURFM TACFAST_FULL \) U1 |) s& Z" M* u4 A, Q
        VERIFIER V_CONTROLLER WF2SRF WIRE_2X WIRE_4X WIRE_STANDALONE \
. M& q# n+ B8 c        W_CATIA5 W_CATIA_SAT W_IGES W_IGES_SAT W_PARASOLID W_STEP \
6 U) h  u; H8 J% Q% x        W_STEP_SAT W_UG W_VDA W_VDA_SAT W_VRML X-CIMADEK X-CIMADEK-RUN \
0 [- c. S4 n9 S        DIE_PLOT_THICK DIE_PLOT_SAFETY 5X_AEROSPACE 5X_TRIM 4X-CONT \
4 x3 J+ l+ X6 H7 k. R        5X-CONT 2X-WIRE 4X-WIRE ABIANT IGES GPP FEM VDA DXF 2D-TO-3D \
0 h. }- K, [) ~$ I        SAT DWG DMS TEMP_KEY_CODE UGR3D MX_MOTION_BUILDER STL \9 c' D6 u4 \* o9 _9 ]9 J, m
        ADVANCED_ASSEMBLY 2X_MILL_LITE 3X_MILL_LITE" SIGN=9ED7B7BEBF080 c# u0 g% T7 ^$ o, Y. |
FEATURE ODT_SHOOT_PACKAGE cima-d 8 31-dec-2018 uncounted \) i% s5 \! ?' ^7 o
        HOSTID=705ab6681c40 ISSUER="Team oDDiTy" SIGN=79BE617AFE743 U" F8 W% A) [1 l+ l# z! M
PACKAGE ODT_CATALOGS cima-d 8 COMPONENTS="CATALOG_DANLY_INCH \' L) C& }% ~) h: K" M
        CATALOG_DANLY_MM CATALOG_DAYTON_INCH CATALOG_DAYTON_MM \: m! S% l6 A( t9 ~9 w! x
        CATALOG_DME_INCH CATALOG_DME_MM CATALOG_DMS CATALOG_FIBRO \
/ {: _& r. G* y" X1 u/ _$ Z# G/ [        CATALOG_FUTABA CATALOG_HASCO_INCH CATALOG_HASCO_MM \
' L6 H% d& R2 S" y+ B        CATALOG_HOPPT CATALOG_HYSON_INCH CATALOG_HYSON_MM \( b! _/ T1 e( y  s8 x' o
        CATALOG_KISHIN CATALOG_LKM CATALOG_MEUSBURGER CATALOG_MISUMI \
4 p7 ^) h+ X/ w9 J0 J        CATALOG_NATIONAL CATALOG_OKSET CATALOG_OTHER1 CATALOG_OTHER2 \
8 I0 ?0 ~! g$ Z/ g        CATALOG_OTHER3 CATALOG_OTHER4 CATALOG_PCS CATALOG_PEDEROTTI \
2 ~  M/ d( O& c        CATALOG_POLIMOLD CATALOG_PROGRESSIVE CATALOG_RABOURDIN \2 @, V$ p: G) o
        CATALOG_SIDECO CATALOG_SISCAT CATALOG_SKF CATALOG_STAMPI \
8 Y' A, x5 B& t& s/ I4 |1 x) x6 |" d6 p        CATALOG_STRACK CATALOG_SYSTEM3R CATALOG_TEKIS CATALOG_TVMP \
% h& h$ ^3 F; {2 d! j        CATALOG_UNI CATALOG_VAP CATALOG_CN_FUTABA CATALOG_IT_PEDROTTI \1 I$ B, l$ L- t- c
        CATALOG_IT_SIDECO CATALOG_IT_SKF CATALOG_IT_SYSTEM3R \
; l- A2 z7 z* z        CATALOG_IT_TVMP CATALOG_IT_UNI CATALOG_IT_STAMPI \. V# K# b# n" X4 ~( g3 D. x0 T
        CATALOG_NL_STRACK_MM CATALOG_DE_MEUSBURGER CATALOG_PEDROTTI" \% V* U1 z" k6 G' w' `! i
        SIGN=025600C824142 p# L0 `. a6 G' Y- k4 u+ _
FEATURE ODT_CATALOGS cima-d 8 31-dec-2018 uncounted \8 d7 d5 [7 `% |  `" N1 B5 @
        HOSTID=705ab6681c40 ISSUER="Team oDDiTy" SIGN=9F7665E06B0E
! G; H, {5 m  B0 i# NFEATURE CHINESE_TRANSLATION cima-d 8 31-dec-2018 uncounted \
# U8 H; h' n" J        HOSTID=705ab6681c40 ISSUER="Team oDDiTy" SIGN=BF091992691E
1 ^6 |# r4 e  _% f& e2 J每个版本装起都是这样
发表于 2012-12-13 00:42:11 | 显示全部楼层 来自: 中国浙江嘉兴
楼主 你的问题是没有破解好哦  E8.5的破解是要生成一个许可文件的哦  用生成的文件去安装
密密麻麻 + 2 参与应助
发表于 2012-12-13 00:44:34 | 显示全部楼层 来自: 中国浙江嘉兴
核对一下电脑的网卡号码
 楼主| 发表于 2012-12-13 11:26:51 | 显示全部楼层 来自: 中国重庆
华英雄love 发表于 2012-12-13 00:42 static/image/common/back.gif! n9 X/ c& A8 d* w; k
, @2 y9 Q9 q/ Y: ?" m我以前都是这样装的,以前都没问题,只是这次从重装系统后就这样了,装了几个系统都是这样。
 楼主| 发表于 2012-12-13 11:28:19 | 显示全部楼层 来自: 中国重庆
华英雄love 发表于 2012-12-13 00:44 static/image/common/back.gif
, e% D: \% T6 t  R& A核对一下电脑的网卡号码
( a/ e: k5 s. Q0 s" T- b现在装多了,网卡都背得着了,能打开,也能用,就是要这样提示一下
发表于 2012-12-15 08:36:40 | 显示全部楼层 来自: 中国浙江绍兴
把授权路径换个地方试试看
发表于 2012-12-15 08:38:32 | 显示全部楼层 来自: 中国浙江绍兴
发帖主题已经登记到《Cimatron 软件整理汇总》,感谢你们的分享与讨论9 ~/ n0 K9 Y3 U
登记地址:http://www.3dportal.cn/discuz/vi ... &extra=page%3D1; c  O5 s0 K4 a% U9 y! ?
发表于 2012-12-18 15:41:41 | 显示全部楼层 来自: 中国浙江杭州
把系统重新安装一下。或者是看看你的破解文件是不是只copy了一个文件啊,要copy整个cracK文件夹的!里面有五个文件呢!
密密麻麻 + 2 参与应助
发表于 2013-2-17 13:43:50 | 显示全部楼层 来自: 中国山东青岛
好新开工该吃饭发现开放性开关盒
密密麻麻 + 5 灌水
发表于 2013-3-17 16:56:28 | 显示全部楼层 来自: 中国江苏苏州
cimatrone.lic:line 4:Feature has expired1 n1 l' c2 ]: ^. U: Y
FLEXlm error:  -10,227
4 o2 H4 B& L2 y) h4 N+ OFor further information, refer to the FLEXlm End User Manual,1 O3 e* @$ G+ o; r% E
available at "www.macrovision.com".
; @, \# C6 N7 H+ Jcimatrone.lic:line 37:Feature has expired8 D5 W* g5 r7 D9 y8 F; b! G8 R
( I3 S  P% ^) |+ p# f6 f8 p) ?3 ?For further information, refer to the FLEXlm End User Manual,3 g/ J+ t( A% Z, R* j3 K
available at "www.macrovision.com".5 v3 b" B5 b2 i: k
cimatrone.lic:line 55:Feature has expired/ a5 E% ~/ Z# c; T
# b1 _% z) y5 X1 E5 |$ G% zFor further information, refer to the FLEXlm End User Manual,
* D3 m3 C. ^2 v2 {available at "www.macrovision.com".
0 ~/ b# E4 j! a& j( l( f' {cimatrone.lic:line 57:Feature has expired; G0 K5 r3 }& n1 p8 G
FLEXlm error:  -10,227; x" L& L& O3 b* B6 G  A
For further information, refer to the FLEXlm End User Manual,- {) C$ n; p1 L+ q! j% s
available at "www.macrovision.com".$ G) t! E6 J) j! |4 s( |1 [- ]) q
#FEATURE CORE_ELECTRODE cima-d 8 31-dec-2012 uncounted
/ b. Z+ R" O, ]' j#        HOSTID=E81132001544 ISSUER="Team oDDiTy" SIGN=6DBC437817BE2 [$ I! F  K2 R
* o# d. _3 j/ y1 {% x- x& {
FEATURE CORE_STANDARD cima-d 8 31-dec-2012 uncounted \
$ B7 J" t4 |& a8 K  M# r        HOSTID=e81132001544 ISSUER="Team oDDiTy" SIGN=9BC5F126E6EC% t1 o: R# i: S& ^3 l5 N% t
PACKAGE ODT_SHOOT_PACKAGE cima-d 8 COMPONENTS="$oDDiTy_rOX SLA CORE \: L: n/ v* q/ \5 B; U' T& R
' D# g1 [, m% ]  e        DIE_BLANK DIE_STRIP DIE_TOOLS DIE_PLOT DIE_SET DIE_LABEL \& G( \( Q$ w) T6 {
& n2 z# ]( y7 @) t" O1 o' [        QUICKDRILL MACHINE_SIM MOLDDESIGN QELECTROD QCOMPARE AUTODRAW \
4 ?9 C, O1 q8 }        AUTOMATED_DRILL BEND CATIA CATIAR2D CATIAR3D CATIAW2D CATIAW3D \
, @3 c" j6 X9 }$ Q" O        CIMACABLE CIMADEK CIMADEK-NC CIMADEK-RUN CIMARENDER CIMIT-M \* D, [% g5 \" x! ^  @5 V/ x2 U
3 _9 t, C2 P( {  m        DIE_FLANGE E_STAMP QUICK_NC GPF DRAFT EDMS-LINK \9 d$ c6 y- i" N( w% ?
        EDM_SETUP_WIZARD EDM_WIZ_AGIE EDM_WIZ_DPC EDM_WIZ_INGERSOL \# o& `3 L6 X: |) d8 r" ]
, ~% g0 y/ j) F) i. p+ u; t) L        API_DE_Global API_DE_SPLINE API_DE_NADELSTICH API_DE_MESSEN \+ t' _( I! b. o. j
        API_DE_ReadInventor ELECTRODE FAST_BLANK FIKUS_IGUS \1 {% r8 V! O& I) o4 Y. [# h# |
% U9 B# }8 Q! D# |        LATHE LATHE_2X LATHE_3X LATHE_PP_COMPILER MACHINE_SIM_CONFIG \, A3 N- z- T2 g
: T# X! [6 w3 h. \9 P# o# e1 U# G% U        MULTI-USER-1 MULTI-USER-2 MX-MOTION-EDITOR NC_UNDERCUT NESTING \
& T  H+ D& m$ J, G  ~! H        NETWORK_ENABLED PAR-SHAPE PARASOLID_READ PARASOLID_SAT \
2 j8 Z8 r5 q' J- }0 K        POST_CONFIG POST_DEVELOPMENT POST_PRO POST_RUN PUNCH Q5X_CONT \
# [2 L7 ?- O2 p  o        QCON_C QCON_Q QCON_S QUICKCONCEPT RD-PTC RE-ENGE R_CATIA5 \: j7 ^! J5 L: D# E: N% `
' l& I( M0 G( e; I0 k" V        R_PARASOLID R_PROE R_SOLIDWORKS R_STEP R_STEP_SAT R_UG R_VDA \1 _3 J3 [+ X, k9 f
! C3 e( a$ d' l! Q$ e# o/ x3 O        SOLID-ASSEMBLY STEP_READ STEP_WRITE SURFM TACFAST_FULL \
" }: [3 Z. R8 p        VERIFIER V_CONTROLLER WF2SRF WIRE_2X WIRE_4X WIRE_STANDALONE \
8 m5 p+ a% d+ k7 b( M        W_CATIA5 W_CATIA_SAT W_IGES W_IGES_SAT W_PARASOLID W_STEP \
# l% q/ n: ]0 ^( |        W_STEP_SAT W_UG W_VDA W_VDA_SAT W_VRML X-CIMADEK X-CIMADEK-RUN \; A' U% }. M+ ]# o. r
) l6 m+ W9 R* D) P7 F; {1 ~2 k        5X-CONT 2X-WIRE 4X-WIRE ABIANT IGES GPP FEM VDA DXF 2D-TO-3D \& x6 M. k# T* P3 ?7 @
        SAT DWG DMS TEMP_KEY_CODE UGR3D MX_MOTION_BUILDER STL \9 v  K- H6 z+ @  K& ^
        ADVANCED_ASSEMBLY 2X_MILL_LITE 3X_MILL_LITE" SIGN=9ED7B7BEBF08# P+ l) [1 z+ f# L8 N2 q
FEATURE ODT_SHOOT_PACKAGE cima-d 8 31-dec-2012 uncounted \8 Z: ]& J# ]5 ^0 v
        HOSTID=e81132001544 ISSUER="Team oDDiTy" SIGN=A27F9C56E88A
6 q4 d- @5 [1 \# H9 y, l' oPACKAGE ODT_CATALOGS cima-d 8 COMPONENTS="CATALOG_DANLY_INCH \, H6 q1 H6 C0 U
        CATALOG_DANLY_MM CATALOG_DAYTON_INCH CATALOG_DAYTON_MM \- F. n4 h2 I8 v" D: F
        CATALOG_DME_INCH CATALOG_DME_MM CATALOG_DMS CATALOG_FIBRO \4 ?' J" m$ Y* O9 j: S/ s4 d
" k: {6 L4 V2 o        CATALOG_HOPPT CATALOG_HYSON_INCH CATALOG_HYSON_MM \& u8 k6 s! K& B$ K1 J
        CATALOG_KISHIN CATALOG_LKM CATALOG_MEUSBURGER CATALOG_MISUMI \6 s& K1 i2 W( Q6 d, @
        CATALOG_NATIONAL CATALOG_OKSET CATALOG_OTHER1 CATALOG_OTHER2 \2 P2 b& k6 e6 B6 r
        CATALOG_OTHER3 CATALOG_OTHER4 CATALOG_PCS CATALOG_PEDEROTTI \5 E2 }$ r# u2 P+ k+ _! N( n
0 r+ ]/ N( N; G& ]& A: l: `        CATALOG_SIDECO CATALOG_SISCAT CATALOG_SKF CATALOG_STAMPI \8 V2 d: M' J; U
! S+ a' b( C& [6 n" J        CATALOG_UNI CATALOG_VAP CATALOG_CN_FUTABA CATALOG_IT_PEDROTTI \
& j  w( |8 V1 ~& b  D) }        CATALOG_IT_SIDECO CATALOG_IT_SKF CATALOG_IT_SYSTEM3R \0 w# P/ ]6 w3 Q0 Y
        CATALOG_IT_TVMP CATALOG_IT_UNI CATALOG_IT_STAMPI \  y4 S/ `- f5 M6 [% Y9 j
        CATALOG_NL_STRACK_MM CATALOG_DE_MEUSBURGER CATALOG_PEDROTTI" \+ @/ V8 h/ L7 y  Z$ y
        SIGN=025600C82414
' z9 m+ `- G$ s  \5 C5 SFEATURE ODT_CATALOGS cima-d 8 31-dec-2012 uncounted \
, j0 k8 b% G2 A/ J* ^# P9 U/ y9 R) s        HOSTID=e81132001544 ISSUER="Team oDDiTy" SIGN=011A7048E898
7 N) o" q$ V# ]FEATURE CHINESE_TRANSLATION cima-d 8 31-dec-2012 uncounted \' L; r; @( N9 N9 d9 p, w/ Q
        HOSTID=e81132001544 ISSUER="Team oDDiTy" SIGN=59044C4A3CD6
: k! {2 ]. d- A9 X& {; w我的许可文件是不是授权到期了
发表于 2013-5-14 14:37:37 | 显示全部楼层 来自: 中国天津
许可到期了
