查看: 2435|回复: 1
[求助] 关于solidworks系列配置批量另存DWG的宏
发表于 2012-12-13 13:45:57 | 显示全部楼层 |阅读模式 来自: 中国广东河源
Dim swApp As Object6 M& E* c+ d7 L" k  ]
Dim Part As Object( k8 j) K, N+ b. _1 ]0 t
Dim boolstatus As Boolean
) G  W) ]  g2 g% U4 nDim longstatus As Long, longwarnings As Long
# `9 I4 `( I6 ~/ [$ ?Sub main()( ^5 B1 Z6 w4 ^* W: A
Set swApp = Application.SldWorks
2 b1 X' `9 s% @& _/ n4 E1 k: s2 @  N( [Set Part = swApp.ActiveDoc* F% U! [( E( m7 F  s) Z* m3 g
boolstatus = Part.Extension.SelectByID2("细节项目1@注解", "NOTE", 0.083073725316815, 5.42267060376433E-02, -7.50000000000245E-04, False, 0, Nothing, 0)
+ z% k( ^; l! Z  Z/ {4 t! ^Part.ClearSelection2 True/ X$ T6 H, Y, F8 g! h' N8 i  c
boolstatus = Part.Extension.SelectByID2("平板型式1", "BODYFEATURE", 0, 0, 0, True, 0, Nothing, 0)
/ N# T) V" x$ v+ {longstatus = Part.SaveAs3("C:\Documents and Settings\Administrator\桌面\RRRR.DWG", 0, 0)% K% l! P) R( K# z& l
8 {/ x4 Q7 h7 H0 M' IDim myModelView As Object
# W8 \9 ]: l) L: O4 HSet myModelView = Part.ActiveView  t# s8 z1 k: U& Q; a
myModelView.FrameLeft = 08 w# l$ X! x2 P6 l% I' ]
myModelView.FrameTop = 21
0 O1 X# b% x+ {2 ]  d( N1 ySet myModelView = Part.ActiveView
# C& z2 Y: s* L. F3 dmyModelView.FrameState = swWindowState_e.swWindowMaximized+ d& p8 ?, C; _1 k0 k
Set Part = swApp.NewDocument("C:\Documents and Settings\All Users\Application Data\SolidWorks\SolidWorks 2010\templates\工程图.drwdot", 0, 0, 0)
$ n) v! H0 `, ]2 ~' L3 mswApp.ActivateDoc2 "工程图1 - 图纸1", False, longstatus
8 }3 @- t5 K8 q. D- {Set Part = swApp.ActiveDoc- l$ @  R5 W( t+ x2 S2 }0 j1 l" U2 |4 ]
& t2 B' D: M$ _& ]Set myModelView = Part.ActiveView) Y( `) t5 Y2 c* @
) E! l8 G& F4 l; Z- xmyModelView.FrameTop = 0- h+ M6 z. e$ Y6 u
+ o6 _8 [! o2 x1 I+ [1 pmyModelView.FrameState = swWindowState_e.swWindowMaximized
' O3 U( v0 |" m. y0 IswApp.ActivateDoc2 "零件1", False, longstatus! m1 s" L/ n  x0 D* q
Set Part = swApp.ActiveDoc3 C% X7 D. J0 C
Dim myView As Object4 W5 u  k1 ~/ _; z
Set myView = Part.CreateDrawViewFromModelView3("C:\Documents and Settings\Administrator\桌面\零件1.SLDPRT", "*正视于", 0, 0, 0), e9 o% X/ [. L  x# |* E$ Z
. g7 n% w, G5 X0 }' T$ ?# S* w# SEnd Sub
' \: q9 `; ~+ k% m$ [
- R4 H  o2 A. [
 楼主| 发表于 2012-12-13 13:47:06 | 显示全部楼层 来自: 中国广东河源
运行时到洋红色这里就运行不下去。
