9天前
查看: 9779|回复: 11
[分享] Solid Edge ST5 MP03 Update & crack (by SSQ)
发表于 2013-1-30 20:47:20 | 显示全部楼层 |阅读模式 来自: 俄罗斯
letitbit.net
+ l' ?- c3 `4 w+ i
. L, B; |) \2 ?, u5 c* M3 T8 b! i) S32bit
& O6 E! {5 E  {0 Q5 Vh-ttp://letitbit.net/download/85211.867cf41cd12c0f4150552f85e040/SE_ST5_MP3_32bit_Update_SSQ.rar.html, ~8 d; i0 z$ k0 j
6 {3 _3 Q+ l2 H. e7 E. j64bit
! X+ B; F3 }! P4 `1 J1 |" ?8 ^h-ttp://letitbit.net/download/15512.1385461b849bfa2dd7d4a53d3aa8/SE_ST5_MP3_64bit_Update_SSQ.rar.html/ j7 N- o$ v% T
" ?% |8 e. m9 f6 R  k
7 @" @/ k' |1 z- Z& P: e  b. E3 u* U& K6 M
pan.baidu.com9 p8 k5 G7 b( A1 j/ z
8 {  d4 L5 M+ N3 z3 Q' P: _
32bit
- O! Q( }) u% k+ D: K3 o# |8 f1 sh-ttp://pan.baidu.com/share/link?shareid=322941&uk=539739554" y7 ]3 s. X6 K
) S" v' w- g8 S/ W8 z
64bit
& s# `# y' r& B' j2 C, ]/ Y2 ]h-ttp://pan.baidu.com/share/link?shareid=322947&uk=5397395543 _- C$ E/ P" l* j0 _8 q
 楼主| 发表于 2013-1-30 20:55:17 | 显示全部楼层 来自: 俄罗斯
Fixed PR's0 W" s7 r8 h( M; y4 p; r
" g' J2 @0 c* D6 b. c; HThis Maintenance Pack addresses the following PRs:1 j' a# x7 [+ d5 i- v6 u
--------------------------------------------------* i( n$ F- |- Z1 n; k; Q( A* `8 Y6 j
% b8 `9 @. S! z2 r6 w# ~9 s: n
===API===" ~2 t6 |, R; c3 Z& G
5 _% ]+ M$ D. v  E% XPR 6809735: Solid Edge ST5 is missing dmcurve.h.
; A1 A3 \$ s! E2 v( N8 MPR 1914096: GetReferenceToGraphicMember2 returns a runtime error
' [# z9 w$ T! ]2 v3 P2 Z* xPR 1911992: How to add an extend surface to a selected edge( |1 S5 X- B( i
: D2 m6 s1 r+ g, G+ A3 Z===Assembly===
* ?; G8 z' _4 P0 l- {4 U2 |: N) k  P3 i3 R' G
PR 1818449: STEP translator does not honor Cyrillic symbols
) Z4 [/ S7 o( J  I1 \PR 1895023: STEP file imports differently when assembly template is used / ^3 [: M; M9 U# m: B
PR 1898966: Assembly Features are missing in drawing views
( R6 q3 t; M" c$ @; iPR 1913935: Solid Edge crash when selecting a SharePoint resource within the Parts Library
- A$ G2 }  ^8 ~4 d- ^4 n* cPR 1916698: Offset value is not maintained when editing assembly relationship& @& S" D0 Q* f: Q
PR 1916969: Capture fit part placement will not automatically switch from Mate to Planar Align like ST4' ~7 P  U) n& y9 ?
PR 1918123: Solid Edge crashes after creating section view with hidden simplified parts) S. v/ {8 v" R8 }/ o; Y
PR 1919026: parts are becoming fully defined when they shouldn't be
; I" D3 y/ b4 w# e2 d, u( Q! n  [PR 2204078: Solid Edge crashes using Measure Angle4 n  M3 _1 z- L0 G
PR 6765034: Deleting parts in an assembly crashes Solid Edge: ~' J  J; B4 [2 n( M( p. w& c0 w) L
PR 6774771: When a relationship is selected it does not highlight graphically  J( Q# j) D5 n* x
PR 6783601: Assembly with simplified part crashes while defining pressure or bearing load( w4 @% H" Q; {" r8 y
PR 6794074: Increased sharpness setting causing strange highlight
2 w! S9 H$ I/ w2 TPR 6795685: File crashes when selecting face for assembly relationship# i! S& l; E5 ]. \+ g
PR 6796478: Inserted image causes shaded model to be black. 9 p6 W5 B' v" ~  L
PR 6798220: Refresh issues when dragging the timeline bar
. |5 D; o: V0 I, K$ X. lPR 6798649: Not able to delete relationship during place part
6 w7 ^% ]/ E3 \# z7 T) y. L" \9 GPR 6806166: parts display like a mesh when modifying geometry
8 l) R7 J$ S* I+ Z, C, }PR 6806302: Undo does not work for Assembly feature edits
2 c% l1 ]5 s: P7 h0 vPR 1919281: No possibility to open NX 8.5 prt-file in SE ST5MP1- V7 _9 I- ]" b) b1 K
PR 1921808: Imported Catia V5 using the assembly template produced incorrect results* S0 I( I8 b" W$ d2 H* ]
PR 2210861: FlashFit showing a floating offset when a fixed offset is created
! O7 o: F9 G! IPR 6814458: Not able to Move Segment after certain workflow 5 Y+ q( [5 s5 z7 {( G9 c# q
PR 6814554: Replacing a part/assembly takes a long time or never completes
; [- N; g  k- z4 \, Z# WPR 1914588: Not possible to define MegaPa units for pressure and stress - Russian specific  Z/ U3 t+ z7 E8 r: s6 U4 d
PR 6808825: Solid Edge unstable after upgrade ST2->ST4 when using Propsync custom add-in" B: g: `* r: F' Q
9 W1 r% ^( b- [" }. q
===Draft=== ' ~: q: K) L% L: V
( i( |2 F  n6 y1 N0 R- I& rPR 1913120: Row order within a particular group is not maintained when manually changed0 d. z  r8 q2 {! p" {
PR 1914540: V20 detail envelope caption text moves when opened in ST4 and ST5
/ o3 P" N+ }! B6 LPR 1918828: Problem exporting to paper space
6 A/ h6 g# q4 i) A6 [PR 2205355: Trouble when Zoom and Pan are done in text input
* s" e2 H4 o6 |' k8 m/ w  ZPR 2205600: Changing Drawing View Style by API is strange when the views are made in V20 1 I1 m8 p. r6 m3 @" T
PR 2208005: The Caption of Auxiliary view is initialized
1 D8 b! c, B; }: WPR 6774435: Templates seem to be corrupt3 h* c8 T9 a* k% G" R
PR 6795525: Tolerances not maintained after consecutive uses
3 _: n5 ]2 o; e8 QPR 6801607: Symmetric diameter dimension is incorrect until view of force updated
1 }! Q3 y( c0 V+ p, WPR 6802009: Problem with formatting property text
% v. D2 W3 O+ u3 M6 c) _/ T' CPR 1919964: Problem with Drawing View Styles 7 `8 q+ F7 L1 M" W" l
PR 2206199: Textbox is disappeared by "Fit to Content"-pattern2.- ~) P: N5 }) ?( X4 {
PR 1823728: Line type scale not applied on Translation to AutoCAD
, B9 X9 P* c. d2 A4 _  V0 J7 O. c$ q/ r0 l1 p3 k5 F2 b  X; Q1 P4 b
===Part/Profile/Sheet Metal===
% a, G. B6 T: U7 z- S+ N: B0 B9 {' k7 k& f1 z' m( E3 x
PR 1916069: Etch on bend radius in flat pattern is not possible in ST5
; ~6 e, z2 c; p$ @PR 1918988: Attempting to open multi-body assembly after edit to multi-body part causes crash
# K9 q& @( r0 S& {( s5 XPR 1919262: unlocked dimension in a sketch causes an abort during a move to synchronous
& D! i2 }% R+ f$ ^! kPR 1919317: Part (with fill pattern) crashes when making changes
7 l) j7 v% Z* V- qPR 1921943: locked dimension changes value when geometry dragged
5 {  q. {. M, U$ e* ?; L5 kPR 2202008: Pattern component positions are wrong - behaves incorrectly in Assembly- m5 n5 B- W% I% I6 N4 R
PR 2206506: InterPart copy not operating as in ST4 4 U% k* @% A7 S" L* k
PR 6794786: Ribs do not move correctly with steering wheel after copy
9 C" U% E* @3 E; w% B( DPR 1923823: Successful import of Inventor assembly on MP1 hangs and is incomplete on MP2+ ~- v, I/ z# x& K5 Z) ^
PR 2208479: Solid Edge crashes in Measure Angle or Minimum distance , o* W9 x5 E  x% Y
PR 2210336: When "Multi-body Publish" is executed second time an error occurs
发表于 2013-1-31 10:14:50 | 显示全部楼层 来自: 中国北京
谢谢,觉的补丁该有了
发表于 2013-1-31 10:24:12 | 显示全部楼层 来自: 中国黑龙江哈尔滨
感谢老大发布更新补丁,辛苦了!
发表于 2013-1-31 13:02:30 | 显示全部楼层 来自: 中国江苏苏州
更新速度好快啊!!
发表于 2013-1-31 20:49:07 | 显示全部楼层 来自: 中国四川成都
发表于 2013-3-26 13:51:44 | 显示全部楼层 来自: 中国河北石家庄
h-ttp://letitbit.net/download/15512.1385461b849bfa2dd7d4a53d3aa8/SE_ST5_MP3_64bit_Update_SSQ.rar.html$
发表于 2013-4-4 22:23:20 | 显示全部楼层 来自: 中国黑龙江哈尔滨
solid_user为三维网做得太多了,我们谢谢你!
发表于 2013-4-19 16:25:12 | 显示全部楼层 来自: 中国四川绵阳
更新速度是够快的,不过话又说回来,现在哪个软件不是这样,就没见有什么实质性的改进
发表于 2013-5-4 19:22:22 | 显示全部楼层 来自: 中国辽宁大连
英文的阿,找找中文的去
发表于 2013-10-24 01:26:04 | 显示全部楼层 来自: 中国湖北孝感
发表于 2019-3-27 10:09:39 | 显示全部楼层 来自: 中国辽宁沈阳
英文的阿 3 ^& Z0 a* i" Q/ b( W
