查看: 1322|回复: 0
[分享] AMSim论文系列分享(Flight Control) 4
发表于 2013-3-25 20:56:44 | 显示全部楼层 |阅读模式 来自: 中国吉林长春
019-液体火箭增压输送系统多学科动力学研究% X6 S/ ]% ?/ k* c
020-直接驱动阀的阀芯摩擦力自适应补偿研究
0 _6 V; |9 x/ L直接驱动阀的阀芯摩擦力自适应补偿研究
( `4 ]" Q5 [/ q" s夏立群, 牛世勇, v/ [/ n/ h4 q
(西北工业大学 自动化学院,陕西 西安 710062)
% Q7 n7 {# h* m$ g2 C- p摘要:针对直接驱动阀阀芯摩擦力,论述了基于模型的摩擦力自适应补偿。描述了几种摩擦力  F2 M- `( [3 t; U9 r
的动静态模型,建立了直接驱动阀的动态模型,设计了基于摩擦力动态补偿的自适应补偿器,并3 ]: ]5 H' c( o! q
采用SIMULINK 和AMESIM 联合仿真进行了验证。结果表明:基于LuGre 模型的摩擦力自适应
5 k9 X: C5 R9 C. ^! _& B" p! O动态补偿控制器能够有效改善摩擦的非线性特性对DDV 式作动器性能的影响。
2 A! m, `2 Q( R- @  J( K3 h: c关键词:摩擦力补偿;直接驱动阀;LuGre 模型;自适应控制
) I& ]7 Z1 O" g5 f0 Q7 d: i& R中图分类号:TP273.21 文献标识码:A 文章编号:1004-731X (2008) 12-3327-03
  w4 H4 n; _% j( o3 x$ WResearch of Adaptive Friction Compensation for Direct Drive Valve
  d& r+ k; A6 q  G% XXIA Li-qun, NIU Shi-yong
  U* U/ s. o% n  S7 m7 v(Department of Automatic Control; Northwestern Polytechnical University, Xi′an 710062, China)5 u4 {( q* f6 D, {# L' T1 B
Abstract: An adaptive friction compensation scheme for direct drive valve was proposed based on LuGre model. Several3 A& y! e8 C" P, e
model of friction was described, especially LuGre z model. The dynamic model of direct drive valve (DDV) was built, and an0 s" I6 Q0 [3 E: H
adaptive friction compensation controller was designed. In order to verify the performance of adaptive controller, simulation! m+ ^9 G1 m* k- }$ ^
models based on SIMULINK and AMESIM were built, and co-simulation of SIMULINK and AMESIM was carried out. The% q) q4 d4 z8 {, ~/ o
results show that the adaptive controller improves a lot of DDV dynamic performance, which is influenced by hard
+ b4 u: U6 J+ y& B, v3 {- ?. k0 s  nnonlinearity due to friction.$ h3 z+ V* Y4 K2 x7 l" m  f
Key words: friction compensation; direct drive valve; LuGre model; adaptive control
0 z1 D9 u0 Z4 v) O2 u032-仿真技术在飞机起落架可靠性分析中的应用研究' O4 h& g4 d$ J4 H6 K0 [3 z  t
仿真技术在飞机起落架可靠性分析中的应用研究* H! N' C6 K) p2 u' g/ q
赵世春.. ,2:喻天翔.. , 王慧.. , 宋笔锋..
. C$ @2 m# y5 i5 ^! k* l0 s+ U(1.西北工业大学航空学院, 西安7 100 72 )
8 J8 c# v1 v. ?  [/ Q# ?3 g" Z(2 . 中国航空工业集团公司成都飞机设计研究所, 成都6 1 ....理1 ..2 R/ i* m) d, a5 k7 \
摘要: 起落架所承受的动载荷较大, 造成系统工作环境复杂, 出现故障较多, 因此对起落架系统可靠性的研# j& e" L# j+ t1 E7 q  g$ D
究显得迫切和重要.. 以三维辅助建模软件..A T IA ..有限元分析软件N A S T R A N ..多体动力学分析软件I M S
& ^0 R; ^) |+ H0 H9 x7 t: ~vi rt ua l.La b 和液压控制仿真软件A M E Si m 等为工具, 采用自动仿真求解策略针对某起落架典型失效模式进9 ?( R0 v8 Y; ?& s8 F& b. h
行仿真分析, 得到仿真分析数据的数据库, 并通过各平台下数据之间的共享和融合, 结合高精度..高效率的,叮靠
* A; V6 |1 v7 |0 R+ i0 V性分析方法,实现起落架典型失效模式的可靠性仿真分析.. 结合某飞机起落架落震可靠性分析案例,结果表( x9 W7 X* Q: O2 D% F+ {! _9 B
明:采用仿真技术建立仿真模型, 通过分析机构失效机理和失效模式, 结合可靠性分析方法进行起落架系统复
3 _* }* F. \" Z, w4 _/ F杂机构可靠性分析具有可行性和实用性..
5 f* H& q$ W8 v1 q- q关键词: 起落架仿真;可靠性分析;混合仿真;落震仿真
7 f$ {( ?. g. F, |4 B中图分类号: T B ll4 . 3 ; V 21 5 .7 文献标识码: A& q8 ^0 j8 e, d5 x8 h7 Z, H
A P P lic a tio n o f S im u la tio n L T e e h n o lo g y o n R e lia b ility A n a ly sis fu r
* [) F* C. _+ m0 Q3 H/ H$ yA ir e r a ft L a n d in g G e a r S y ste m
  {( |# `6 g9 B9 }. EZ h a o S h ieh u n ..,2 , Y u T ia n x ian g l , W a n g H u il , S o n g B ife n g ..
1 s% G8 C* k/ X7 A: L6 c( 1 . S e h o o l o f A e ro n a u tie s , N o r th w e s te rn o f P o ly t ee h n iea l U n iv e r sity , X i ..a n 7 1 0 0 7 2 , C h in a )
5 }2 S; f# b7 Z, Z3 ^9 X6 _& ]( 2 . C h e n g d u A ir e ra ft l)e s ig n R e s e a re h I n s ritu te , A v za tio n In d u s try- N; A0 R8 \. x* ?+ |$ G6 ~
C o rp o ra tio n ()f C h in a , C h e n g d u 6 1 0 0 4 1 , C h in a )8 D; {' J  u6 |- p5 v
A b s tra et : D y n a m ie lo a d o f la n d in g g e a r 15 h o v ie r , w h ie h lea d s to eo m p liea te d o p e ra t io n e n v iro n n 飞e n t o f ..y s re tn/ F8 V5 U- G: o5 C  [/ R; R8 H8 p* r8 X
a n d m o re fa u lts . 5 0 re s ea re h o n re lla b ilit y o ] a ire r a ft la n d in g g e a r s y ste m b e e o m e s m o r e a n d m (..re e x ig e n r a n d
. D; |0 g' z9 A2 o; Rim p o r ta n t. B a s ed o n t h e s im u la t io n a n a ly s is m o d el , rh e p a p e r p r es e n ts re lia b ility a n a ly sis m e th o d fo r th e ty p ze a l
9 C$ e4 s/ E6 y+ G# r, ifa ilu r e m o d e o f th e la n d in g g e a r. T h e m e th o d a d o p ts a u to m a tie sim u la tlo n s o lu t io n s t r:..re g y b y tl s in g th e 3 1) a id
% b& S$ p# k9 z1 N1 }& a% v* ve d m o d e lin g s o ftw a re C A T IA , th e fin ite e l.:m e n t a n a ly s is s o fr w a r e N A S T R A N , m u ltib o d y d y n a m ie s a n ,一ly sls, l+ b% J; I; T6 U# |1 K
so ftw a re L M S V irt u a l I a b a n d h y d r a u lie p r .Zss u re eo n r ro l s o ftw o re A M E S im . T h e s im u la tio n a n a ly s 一.. d a ta 15. k: h% ]2 I: j* ^& N3 @% a
o b ta in e d b y a p p ly in g d a ta s h a r in g a n d fu s io ll m e e h a n is rn u n d e r th e d iffe re n t s o ftw a re p la tfo r m s . T h e n . e o m -
* A  H1 E! y8 Lb in e d w ith h ig h p r e eis lo n , h ig h e ffieien t rn e tllo d o f re lia b ility a n a ly s ls , re a lize th e re lia b ility a n a ly ..一5 fo r th o ty p lea2 v) `+ w2 D  b! E  p, h
l fa ilu r e m o d e g e a r s im u la tio n . T h e e x a rn p le o f a la n d in g g e a r d ro p re lia b ility a n a ly s is s h o w s th :It th e m e th o d ,( M; P% z) b) g$ s7 f4 }0 V! ^
w h ie h b a se d o n e st a b lis h e d s im u la t io n m o d e ] b y th e eo lla b o ra tiv e s im u la tio n te e h n o lo g y o f m u ltl一s o ftw a r ..一p la t -
* R1 m) q+ Z7 |; W+ Z7 Vfo r m a n d th e a n a ly s is o f t h e fa ilu re m e e h a n is m a n d fa ilu re n lo d e s o f m e e h a n ism s y s te m s , 15 o f tllc fe a s 一b 一1一ty a n d" H2 I! }- e  D0 E+ C5 s
p ra e tie a b ility fo r th e eo m p le x la n d in g g e a r r le e h a n is n : ..y s te m s re lla b llity a n a ly s is.' V( o, \$ E* i# s6 j$ E
K e y w o rd s : la n d in g g e a r s im u la tio n ; re lia b ility a n a ly s is ; h y b rid s一m u la tlo n ; d ro p s in i u la tio n
) E& n- s7 t6 v: P4 B9 \/ ~) Z7 L& K3 ?
+ @- D6 u1 ]% k4 a0 P Flight Control.part02.rar (512 KB, 下载次数: 2)
