查看: 3031|回复: 6
[已解决] cosmosworks运行的问题1
发表于 2006-7-15 12:26:29 | 显示全部楼层 |阅读模式 来自: 中国河北廊坊
请问大家一个问题:我在用cosmosworks 分析装配体时,把两个小一点的装配体装在一起进行分析,最后成功了,但是我把三个小的装配体组合在一起时,系统运行到70%时,提示出现一个问题,系统提示internal error #10,这是怎么回事?
# N, X9 f* R" ?% D: M3 H" g+ i请大家帮帮忙,我很着急。谢谢了!
发表于 2006-8-1 15:55:01 | 显示全部楼层 来自: 中国广东广州
细化网格可能会有帮助
发表于 2006-8-12 16:19:42 | 显示全部楼层 来自: 中国北京
先可以看看cosmosworks给的提示,或能许有帮助。
发表于 2006-8-23 17:14:59 | 显示全部楼层 来自: 中国北京
The FFE solver issues this message when it is not converging after 5000 iterations. This means that the problem  is hard to converge. Many causes can lead to this situation, including but not limited to: Large difference between Young's modulus of the materials, portions of the model with very low stiffness compared to other portions, etc...
/ y8 j! f9 N& ^& f4 R0 r, w6 L7 G+ C. p3 `' m$ ^$ P
You may want to use a different solver like the FFEPlus solver, or the Sparse solver. The sparse solver being a direct solver, convergence problems are irrelevant. But the required memory and time are much higher.
发表于 2006-8-24 16:26:59 | 显示全部楼层 来自: 中国浙江杭州
选择不同解算器看看
发表于 2006-8-25 22:02:32 | 显示全部楼层 来自: 中国江苏南京
注意看模型,有没有不能划分网格的地方
发表于 2006-9-26 19:15:05 | 显示全部楼层 来自: 中国四川绵阳
如果没错的话,应该是网格划分不正确。
