发表于 2013-6-12 10:46:52
来自: 中国辽宁抚顺
这个方法不好
9 E' D) Z; T4 E1 w1 p6 W8 d其实用VBA从后台画图也需要用到前台手工画图的技巧的,就是几何知识.回想一下当初学过的数学课程,难道没有电脑或者没有VBA就画不出从已知点到已知圆的切线了吗?
' y m4 v0 I6 L; N1 w7 j如果在纸上画,应该是用从已知点到已知圆圆心的线段做直径画一个辅助圆,辅助圆与已知点的交点(两个)就是所求的两个切点." X5 M% {' b+ x/ |. H! c( f
按照这个思路编程应该是这样- Sub test()! c( P P% E- v+ j3 w* l2 ?- @: _$ n
- Dim a As Variant, o(0 To 2) As Double, b(0 To 2) As Double7 F9 j j8 i& x" S% a0 p3 S3 Z
- Dim V As Variant, C1 As AcadCircle, C2 As AcadCircle, L As AcadLine ''''''''''''''''
* |( {( r9 ^8 s7 `2 [7 |& u2 | - 'Const pi = 3.1415926# l7 U( T/ P* h+ O5 ~7 q
- On Error GoTo 104 o% [1 {) Y4 p/ k7 p+ J7 V* x% @
- a = ThisDrawing.Utility.GetPoint(, "shurudian a")0 O1 @) Y4 h6 N! u! q9 z, Q, t
- Set C1 = ThisDrawing.ModelSpace.AddCircle(o, 50) '''''''''''''''''''''''''0 t( }: i+ E& Z/ z0 o4 |
- Set L = ThisDrawing.ModelSpace.AddLine(a, o) ''''''''''''''''''''''''4 T$ _- {4 ]6 }! g% W3 K
- o(0) = (L.StartPoint(0) + L.EndPoint(0)) / 2: o(1) = (L.StartPoint(1) + L.EndPoint(1)) / 2: o(2) = (L.StartPoint(2) + L.EndPoint(2)) / 2 '求直线的中点
0 Y( }& B. J3 n7 P% [ - Set C2 = ThisDrawing.ModelSpace.AddCircle(o, L.Length / 2) '以直线中点为圆心,直线长度的一半为半径画辅助圆$ t8 M& W! Y; `' E2 c/ P4 _
- V = C1.IntersectWith(C2, acExtendNone) '得到两圆交点,即两个切点5 j7 g) C/ X! G$ [! O
- b(0) = V(0): b(1) = V(1): b(2) = V(2) '第一个切点赋值给点b$ ~) a: q3 `& W9 b
- 'Call ThisDrawing.ModelSpace.AddCircle(o, 50)0 W: L$ X% y8 f8 y" A( N
- 'Call ThisDrawing.ModelSpace.AddLine(a, o); Z; `. f% n! }7 _* ~6 H) x
- 'For x = -90 To 0 Step 0.01
9 Y" c0 G/ @. ~ - 'b(0) = Cos((x * pi) / 180) * 50
0 x, ^, i+ F3 D' i2 |" w# ] - 'b(1) = Sin((x * pi) / 180) * 505 M8 b0 o8 |0 G4 Y
- 'If (a(1) - b(1)) ^ 2 + (a(0) - b(0)) ^ 2 + 2500 = (a(1) - o(1)) ^ 2 + (a(0) - o(0)) ^ 2 Then
a& t( |& F# f { - 'End If
+ ~) L' t( `# Q/ M# V% Z - Call ThisDrawing.ModelSpace.AddLine(a, b)" [2 W$ B$ N d
- 'Next x
5 ^# A; D r- U8 i6 ~0 _ b - 'On Error Resume Next/ A. o8 J, S ~' g0 e7 N2 h8 k/ o
- b(0) = V(3): b(1) = V(4): b(2) = V(5) '第二个切点赋值给点b1 A' n* }9 r2 `8 y
- ThisDrawing.ModelSpace.AddLine a, b '画第二条切线
- u( b( h8 l0 U - C2.Delete '删掉辅助圆! v( p; E2 s5 C0 {, g
- 10: End Sub
复制代码 |
