查看: 2179|回复: 1
[求助] 如何引用?
发表于 2006-8-4 17:06:32 | 显示全部楼层 |阅读模式 来自: 中国上海
比如我有a图和b 图,是两个可以配合的图,如何将a上的一个曲面引用到b图上。请大家帮忙!
: r/ \4 G4 {5 w4 E2 w谢谢!
+ e- U- F2 P, w8 g# f# T尽量详细点,我很笨的。
发表于 2006-8-5 16:17:38 | 显示全部楼层 来自: 马来西亚
If you are refering two part in solid modeling: 2 w7 p# e/ z5 B2 v$ {9 c# A
Then select the part A as skeching plane first, then use command > filter, right click > filter\ line , select part B to focus on part A plane. ; _/ H7 B5 x+ W/ `$ w
1 `; v& Q- d" t' ?If you are refering two drawing in 2D drafting, even simple.
% M+ _( l" ~" f8 M3 C# [& b1 {Just open part B drawing, select line to be copy/reference using CTR + C button. Then open out part A drawing, and used CTR +V to paste on the view that you want.
