查看: 2866|回复: 2
[求助] ST6 SOLID edge license wizard 停止工作
发表于 2013-8-10 21:10:58 | 显示全部楼层 |阅读模式 来自: 中国浙江宁波
ST6 安装后第一次启动 授权 就出现这个SOLID edge license wizard停止工作,无法打开软件!5 G: s1 H+ f! A* S
发表于 2013-8-11 00:33:58 | 显示全部楼层 来自: 俄罗斯
本帖最后由 solid_user 于 2013-8-11 00:35 编辑 + R! {; A6 B  g2 n  C
1 Y% P+ ^, F$ ~SCD87 & f/ K$ k" i& \( m
# x# O6 G+ [- i! L+ E1 R4 V
You mean ST6 v106.00.00.100  (cracked by SSQ)?
' j1 y( N3 E+ B. z
6 p# }3 ^6 c) n& U9 c1. You need to setup ST6 (do not select a license file at this step)6 I* E! K5 l8 k% _, V
2. You need to overwrite original files with cracked ones (from SSQ's crack) and copy SSQ's license file to Program folder of ST60 V  s9 g* s  q: y1 h
3. At ST6 first start you will be asked for license file. Select > "I have a license file" > Browse > browse to SSQ's license file > OK% C. M; p0 o4 `. K5 M& I- p5 z
4. Run Solid Edge ST6
发表于 2013-10-20 10:43:19 | 显示全部楼层 来自: 中国浙江丽水
没有指定许可吧。
