发表于 2006-9-28 14:53:22
来自: LAN
螺纹球阀 Thread Ball Valves
5 j+ L0 w% d z8 F s$ _ _L形三通式 L-pattern three way
1 ]9 |+ H6 L5 O6 LT形三通式 T-pattern three way 1 N- S. u5 ?; L5 O! @: Y% `
安全阀 Safety valve
5 |% U5 D: B! k暗杆闸阀 Inside screw nonrising stem type gate valve
$ q8 A8 b/ Y4 \# X百叶窗; 闸板 shutter
4 k" d9 a F9 ?, C. V/ j百叶窗式挡板 louver damper / O ^4 g. e/ {" a" R
摆阀式活塞泵 swing gate piston pump |+ |: R4 \4 x' B" D" q5 I
保温式 Steam jacket type . @4 ^2 b, Y4 a
报警阀 alarm valve 3 R1 t* s( ^9 l3 {9 h( ~+ U
报警阀; 信号阀; 脉冲阀 sentinel valve
; c" _) f( S$ b7 D4 @( q背压调节阀 back pressure regulating valve % W+ K6 X- _6 k3 y& X3 `; Y
背压率 Rate of back pressure & C; p% H1 J0 B9 K9 U$ [& Z L; A
本体阀杆密封 body stem seal
1 J) W S9 ?! t, |) M; f波纹管阀 Bellows valves + u5 B- I! q& s' O+ T' B! h. Z
波纹管密封阀 bellow sealed valve / [8 g0 E+ y) n6 E% z
波纹管密封式 Bellows seal type 5 n8 v: N; r- O# N: e: t) ]1 L% v9 x
波纹管平衡式安全阀 Bellows seal balance safety valve
7 P% @3 {+ f3 W5 v波纹管式减压阀 Bellows reducing valve 4 Z4 X8 R# n/ A* @, ^2 D- v
波纹管式减压阀 Bellows weal reducing valve ; A$ J3 X8 `' x8 f- I/ Y& h
薄膜 thin film
8 Y# X- I+ k. F. c" ^7 ]. L薄膜; 隔膜 diaphragm
" I! T& R6 ?/ G0 p! N5 H, }$ |薄膜式减压阀 Diaphragm reducing valve
+ R7 k2 t% m" X2 d薄型闸阀 Thin Gate Valves
7 W( a" O0 k/ @, M不封闭式 Unseal type
# o# C% F0 W& c/ M5 V& z槽车球阀 Tank Lorry Ball Valves + v8 B( u+ |& }! S8 Q: ^
颤振 Flutter
! f( Y9 C, |( i" s0 O6 S [5 v常闭式 Normally closed type
+ Y, E* [# [. f常开式 Normally open type ( I& Y2 t1 D y6 Z
超低温阀门 Cryogenic valve
' O. e- t& t7 t" ]' u超高压阀门 Super high pressure valve
' R* F0 t, s' H! c( t* O' B超过压力 Overpressure of a safety valve
; @ J+ B; r1 o# C1 k衬胶隔膜阀 rubber lined diaphragm 4 n/ g6 h/ Y) ]5 b- A
衬胶截止阀 rubber lined globe valve 5 F. q0 \+ o9 Q& ]- R6 K9 `4 C E
垂直板式蝶阀 Vertical disc type butterfly valve
) ~7 r a' D/ G磁耦合截止阀 Magnetic Co-operate Globe Valves ( t0 q, D! _4 n; ?
带补充载荷的安全阀 Supplementary loaded safety valve 4 k' \; h- m# J4 f1 Q: c: p
带辅助装置的安全阀 Assisted safety valve : C9 g( d {0 ^7 ]2 u, N, T
单阀碟双面平行密封闸阀 parallel single disk gate valve ' b1 x6 W1 _6 G
单口排气阀 Single Opening Exhaust Valves , t3 X; N( K2 J8 m" t
单向阀 Non-return Valve
q# r* @# ]: ?/ I5 x9 v- w单闸板 Single gate disc
8 W) Z+ a% Y' j单闸板平板闸阀 Single Disc Flat Gate Valves
/ X" N/ o+ g3 i4 |4 J弹簧薄膜式减压阀 Spring diaphragm reducing valve
, y; I3 d0 o6 j B2 H弹簧式安全阀 Direct spring loaded safety valve
9 B) V5 ?+ v) l i# B* c3 `弹簧座 Spring plate
: k$ U: {& h; w5 ^- H- t弹性闸板 Flexible gate disc $ j1 D3 z' J$ p% z' B; @( E
当量计算排量 Equivalent calculated capacity
) a! X% u: R* C+ i& A& I6 W挡板 damper
2 Z! y$ A+ S1 R& t* ~导阀 Pilot valve 0 H2 i5 x: e# K! B" ?
导向套 Valve guide disc guide 4 j( _: o8 ~: l' I
低温阀门 Sub-zero valve
$ X1 `1 D- q3 u. k. x7 E1 G低压阀门 Low pressure valve ; C: o# o3 T! V0 }2 M
底阀 bottom valve
4 O' d; ]0 J) [" }! e5 V1 I8 B底阀 Foot valve
( k. D/ H5 a M电磁动装置 Eletro magnetic actuator / {/ c1 V/ Z- |8 P# L
电磁阀 magnetic valve 6 w3 ^3 d6 a, _5 _+ N/ }. u0 Y
电磁阀 solenoid valve
; L, `( `( i+ T电磁-液动装置 Eletro magnetichydraulic actuator , n/ [; n: g0 U
电动阀 mortor operated valve
! a3 k: l+ n$ A; o. M5 Z0 N6 R- b电动阀 motorized valve
1 U0 t7 I( l. {+ Y/ ]电动截止阀 Electric Actuated Stop Valves
9 @" K1 ^0 Z9 I8 _/ P! S. n电动平行式双闸板闸板 Electric Double Disk Parallel Gate Valves ( V: K$ N: b$ z
电动楔式闸阀 Electric Actuated Wedge Gate Valves
& |( y% }9 j% H* U+ N' t9 @电动装置 Electric actuator . W8 S8 }% p: ^$ k8 Y- |
电-液动装置 Eletro hydraulic actuator
3 R; u' S$ _/ z" u9 E+ _) Z$ {电液伺服阀 electro-hydraulic servovalve 5 m3 I0 `, `2 l1 @; d5 k w
调节弹簧 Regulation spring
; t8 i6 ~. r8 a$ I调节阀 adjusting valve * H. m) a- M4 l& y0 K
调节阀 control valve $ Q- O. H+ [+ v$ b- t
调节阀 regulating valve # y, W5 P% w6 j0 g6 E" x
调节螺套 Adjusting bolt Adjusting screw
" y% o$ B/ q. q$ F/ i% h' }调节圈 Adjusting ring 1 z8 f* D# L/ h
蝶板 Disc
/ @ p( _6 q1 B2 F蝶阀;瓣阀 butterfly valve
! N0 }5 G& o+ S8 K2 P1 O: e! }! N3 n蝶阀;瓣阀;拍门;铰链阀 flap valve
6 ^+ K8 L* E; ?蝶式缓冲止回阀 Butterfly Type Non-slam Check
4 U) j, u4 A; Y7 e蝶式止回阀 Butterfly swing check valve
5 T* T2 E( o& A定比减压阀 Proprutioning pressure reducing valve
0 T; j" F- n- q/ |- N1 e* s定差减压阀 Fixed differential reducing valve
* M0 I! J {2 |# U定值减压阀 Fixed pressure reducing valve - M$ k* l5 }5 U( G3 Q
动态特性 Dynamic characteristics $ N& B z0 n% L0 A
对焊连接阀 Buttwelding valves
0 x6 N9 a- u o5 ?对夹蝶板阀 Wafer plate valves 0 z/ `/ G* ?; \( `7 C
对夹式衬胶蝶阀 Wafer Type Butterfly Valves with Rubber Itning + T& m2 s5 E8 d3 K2 z; l
对夹式阀门 Clamp valves
! Z' Y' ?$ b& I$ ?9 T对夹式止回阀 Wafer Check Valves 2 z, y$ N( J* A
额定排量 Certified capacity
) N% a6 }( G9 b# n3 k8 J+ ^5 K& {额定排量系数 Derated coefficient of discharge 3 a, s! I9 N v; [
二通阀 Two-way valves ; [. D0 u* h. N- L
阀 valve : m0 M! h6 E9 J. H- c2 D" |
阀板 valve deck plate
+ H6 r8 V3 }: s2 r% e. Z( V阀板 valve plate
, G2 e: A- `; b+ E5 u阀板式活塞泵 valve deck plate type piston pump
8 ~% o- W( z4 k6 ]$ t/ N1 u阀板式活塞泵 valve plate type piston pump
0 Y* ^; r* N7 B- v阀瓣 Disc 0 @: d* e6 R, w
阀操纵杆 valve operating rod $ N& k: C& A: M
阀痤槽 valve seat recess
- d9 G3 C5 G* k( t6 E& n& v阀挡 valve grid
: r0 f- h6 U% _- U" Y/ d阀挡 valve positioner & \5 n' Y8 c. Y" ~8 J/ T! l
阀挡 valve stop
4 Q4 Q: l& f' @3 w0 u阀导杆 valve tail rod
) o. Y; z9 A8 F. S' J6 _& K# X阀导向器 valve guide . h7 D7 Y" t8 I ^$ x H
阀盖 bonnet
6 R" [! ?$ V- I& i# [阀盖衬套 bonnet bush 7 _, m0 N. a/ u' i" N3 u6 B
阀盖垫片 bonnet gasket 4 I% h( l4 ]4 v8 ~% W. j. D9 H l
阀杆 stem ; K; y$ i% R' n2 c7 T* W8 r+ `
阀杆 valve rod % ]2 G1 m3 a) Q: l/ \, a5 v
阀杆 valve spindle 3 e3 P* E* R2 s1 h& g
阀杆端部尺寸 Dimmension of valve stem end , `1 n4 c( d: K5 u* H2 k
阀杆环 stem ring
& T: m9 v W2 i8 I* N+ o* \( z R% J阀杆螺母 Yoke bushing Yoke nut 3 @% S \% {$ I" m
阀杆填料 stem packing
& \9 f0 A$ m( Q; F) t0 P) y* a阀杆头部尺寸 Dimension of valve stem head ' h% @$ Z2 a1 n, `) o& a
阀簧 valve spring
, v# ~8 d: y6 ^6 ]! K- r阀簧压板 valve spring plate
. I7 C. d& C& H2 C, {; _阀控水锤泵 valve-controlled hydraulic ram
+ l& K! y5 z5 ?% N# [阀框架 valve yoke , l* |: `2 D3 J- K4 x5 G
阀门 Valve 6 G3 F# m- ], p2 U7 M9 Y- o8 U" ^# Y# w
阀门传动装置 valve bandle set
& t4 G! n' g7 O5 J, [阀门和管件 Valves and Fittings
4 u( P# z% z* } C b2 b! t阀门盘根 valve packing " r6 r" G8 r* N. {/ _6 a Y6 H& D6 P
阀门手柄 valve handle ' T' e8 w" G- x! t" V8 O9 m$ g3 R$ ~
阀盘 disc - P6 ]$ {9 m8 ], k( u ?
阀盘 valve disc * S2 ?% T; {' G7 s; U
阀片 Disc
: S. t3 N( T# j& T6 L+ h- R5 ~' l' h阀球 valve ball
3 T8 ^; H7 I5 l- ~阀驱动臂 valve driving arm
: }; j M/ N4 t3 s& H A3 h阀驱动臂 valve motion arm
r3 _& ^1 c0 G& @6 t阀式活塞 valve type piston
8 s( f$ i( ]5 z/ G. q2 j M阀式活塞 valve type bucket
]. `0 n; z2 D) v% t5 c阀室式活塞泵 valve box type piston pump
4 p9 l5 w9 X( W. i阀室式活塞泵(美) valve pot type piston pump
! E# P* d" T5 W* P; X' c7 A阀抬起装置 valve lifting device . L, J: H2 A7 n
阀体 body ; K5 z: p, K- k# A8 A3 B
阀体 valve body , G% O, N1 C/ B% @# Q; l' ^
阀箱 valve box / Z! z) U* @6 ], L; @# C
阀箱 valve cage # }4 y+ P. l1 W1 n
阀箱 valve chest
" c# }# R: Y) V阀箱;阀限位器 valve guard
3 U* a8 o* F0 M( c阀箱盖 cover for valve box
# _( {0 g! D! O+ \$ \; u; ]阀箱盖 valve box cover
+ P1 m" z6 k4 z p- Q$ Q阀箱式活塞泵(美) turret type piston pump
5 E! v2 q0 A& ^6 b2 V+ m0 g8 Y阀形活塞泵 valve type piston pump
9 u$ [( L5 X y阀座 Seat ring 3 b) |0 |6 Z% W" U; p- z2 R5 Z
阀座 valve carrier ) Q% G0 c# |0 N5 d7 K& @8 E2 D8 a6 A0 Y
阀座 valve seat(body seat)
/ q$ c$ M ?+ [( v* Z阀座;阀盘 valve seat
1 b* [8 q$ n; a" F! o1 K6 h% I阀座环 seat ring ]4 m" [1 v# I: f3 y
阀座密封嵌条 sealing strip for valve seat
1 h3 S0 A2 l0 _) H9 W法兰 flange 4 x6 R. P& W8 l# F8 p. y- l; ~/ B5 \
法兰堵头 blind flange
* w/ O i/ m- X2 H" X% e法兰端 flange end 0 A! S, Q0 w8 U* m) Q9 x# Y7 t3 l
法兰接头 flange joint 0 a0 i6 O3 s' X% C1 G- N
法兰连接紧固件(双头螺栓和螺帽) flange bolting
5 D5 ]8 v1 ?' ^' h/ ?法兰密封面,法兰面 flange facing % R* W* y g. `( f, U+ v9 a# a% t
法兰面加工 flange facing finish
+ |* f0 F6 l$ L9 }2 ?# s$ h0 r& A法兰球阀 Flange Ball Valves
6 h8 Q% Q, r0 v; d8 v1 [; @) b翻板阀 Flap
1 m0 { ^/ f- m" }反冲盘 Disc holder
2 B; t( r8 P2 u4 V/ d! _. e3 K; B反向作用式减压阀 Reverse acting reducing valve
' L9 t3 Q! l+ w3 U& C反向作用式减压阀 Reverse acting reducing valve 2 h X2 r5 U x2 g2 X" _8 ^& \, h+ o
放空阀 emptying valve
& ?2 d# z4 C8 v2 q" Y放气阀 air vent valve;vent valve
7 a& m* E3 I1 r+ N1 w% N* g9 G- V放气阀;排气阀 air evacuation valve 3 h8 l6 I. v Q) b' ~( n7 [5 d# U
放泄阀 escape valve + `& S/ t. r8 ~$ I* Y
分置阀室式活塞泵 separate valve box type piston pump
' z; A) f* M8 o" \分置阀室式活塞泵(美) side pot type piston pump
# E0 C4 y2 k3 m6 U! R2 Z; V, i封闭式 Seal type o B# n' L. h/ b3 W2 w
浮动式球阀 Float ball valve . Y" T! }+ u# p, q
浮球 Ball float 6 z: s/ T, m3 q9 c
浮球阀 Float Valve
7 u& c) g4 d& D5 ~ j9 A浮球式疏水阀 Ball float steam trap ' |4 C1 Q3 k& g( A
浮球式疏水阀 Free Float Type Steam Trap " _# n5 N8 J$ a" B) Y1 V. ~+ x6 N5 u
浮桶 Bucket float
" C' t" D' @. P, R) S浮桶式疏水阀 Open bucket steam trap * V! b& O- t3 M
辅助(副)阀 Auxiliary valves 5 }0 O/ z Y. {/ w& I
负荷率 Rate of load condensate
9 m0 Z P A: U! l附加背压力 Superimposed back pressure 5 u7 U' j: o* o% U
复位弹簧 Returnning spring
C! `- }% {& F1 X$ }7 m. Q杠杆式 Lever type * k3 i! ?9 r5 p3 h; p
杠杆式安全阀 Lever and weight loaded safety valve
' G3 b8 ^" f9 P杠杆式减压阀 Lever reducing valve j* w% B& _2 J; x+ f
高温阀门 High temperature valve
! g. Y' H3 Q0 {$ u高压阀门 High pressure valve & s7 _1 b/ c6 k, r) _& _ i) `( g7 }
格兰密封 gland
: Y9 a0 J" o5 D# E+ \隔离阀 isolating valve 6 [8 H5 B/ e6 R0 |6 T! c# E
隔膜 Diaphragm : ~" ^2 V8 r0 ]; y) H6 D( |+ Q
隔膜阀 diaphragm valve ; B: b7 _$ _! w0 p
隔膜式控制阀 diaphragm operated comtrol valve / R' T. V8 F# P7 i$ L3 ^; M
工作背压 Operating back pressure
8 f% f- _' K3 E; ?/ m; H8 [工作温度 Operating temperature ' t. ^% e% L2 K
工作温度 Working temperature 0 l9 l) }" X& l/ s& _. b) ]
工作压差 Operting differential pressure
# `3 V$ y( g6 g7 N2 {工作压力 Operating pressure 9 ~+ v: ?) i( ^8 R
工作压力 Working pressure
) g, y. [8 g- X8 C5 {- f- ?3 h公称通径 Nominal diameter
/ j# r4 W0 @! Y8 I( t ^公称压力 Nominal pressure
1 s' p, u' V5 e, E& u1 d固定式球阀 Fixed ball valve $ P `! S- O: P3 K! n
关闭压力 Lockup pressure
+ M' H1 b# j) k* r5 {8 ^$ J% h0 |关阀过冷度 Subcooled temperature of close valve [: Q* Q2 r# z1 m. b. V7 K, _
关阀温度 Closing valve temperature $ j# x. D% A& f7 w0 E
管道安全阀 Piping Safety Valves ! ~% I) H0 ?1 ~
过冷度 Subcoold temperature 6 S% D" M9 R) \8 v5 j0 `
过流阀(或节流阀) Restrictor Valves # f% \( H( Q$ a; s4 j. W
喉径 Throat diameter
0 ?6 ~$ @2 Q# ~! I% g7 [) W滑阀 slide valve ' o5 E; O X( }- }0 \8 \
滑阀式回转活塞泵 rotary piston pump with slide gate ; ` t+ d" u1 w. [: `8 S1 v- C) H
滑阀型转子泵 eccentric rotary pump with sliding sleeve # {$ Q5 H! i" T' i" F' O
环形阀 annular valve 4 N2 O1 l( L X1 A1 c% U9 K
环形阀 double beat valve 1 ]3 g) c* j: D8 v) a! b
换向阀 selector valve : t# R( X2 q. Q; z F
换向阀 shuttle valve 8 z8 U9 r' `6 Q6 r% _& R
回转滑阀活塞泵 piston pump with rotary gate + U; o& r0 `3 S8 D9 w; s' f6 n! |) G
回座压力 Re-seating pressure of a safety valve 5 [! y$ X8 i, J$ U4 n+ v; G
活塞昵减压阀 Piston reducing valve " I9 o4 P" O4 j% f* N
活塞式阀 piston valve ! `9 m. w% m3 y$ N- a1 j: [- y U
活塞式阀;柱塞式阀 plunger valve
* U# d* q' {; p9 x活塞式减压阀 Piston reducing valve
$ X5 y; n/ m% L% `" l减速阀 Deceleration valves
/ \$ z" U. y; C) _3 q k* S/ w减压比 Pressure reducing ratio 0 A, f0 o5 W$ ?
减压阀 pressure reducing valve
2 p) k$ C3 h& }3 S) ~1 y7 T- Y9 C# _浆液阀 Parallel Slide Valves
$ F$ e5 Z5 [- o% @$ B角阀 Angle Valve ; R n3 q* o- u' X/ Y7 P" M' L
角阀 isolation valve angle configuration
2 c* d3 A+ e# _5 C1 T: s4 Q1 W) g角式 Angie type 4 X- J- ^8 t" C+ |) G1 K6 a
角式节流阀 Angle Throttle Valves 9 s; A2 m: M5 w$ J5 g1 x2 N
角式截止阀 Angle Stop valves ' ~3 ?& L) X& ?% @) z( ^5 \
铰链阀;片状阀 flapper valve ; u. n( W8 v5 w+ h4 B- B0 m
节流阀 throttle valve " p I. h, n% L) D' o
节流阀 choke valve " a$ \7 |$ Q, h% f
节流阀;节流 throttle ! R$ Y( N- _+ }0 d
结构长度 Face-to-face dimension ;End-to-end dimension; Face-to-centre dimension
" S8 L$ ]7 X! ? g* `1 H `" ^结构形式 Type of construction 6 Q" a+ v& G- m
截止阀 Globe valve
7 J" V; w5 @3 Y+ x8 E$ t截止阀 Shut-off Valve
; Q. r( b: J* f1 K. Y截止阀;关断阀 shut-off valve
& \6 X* _0 t! S3 |+ Z. X, P# z4 x截止式隔膜阀 Globe diaphragm valve
) S- \+ m9 Y0 D# a6 ]- b3 M紧急切断阀 Emergeny Cut-off Valves " x) e3 F; F! B: W( p, `
进气阀 air intake valve 1 b+ b6 t! s. \
进水阀;进口阀门 inlet valve
+ o) L! r0 U9 `4 ^ X静态特性 Static characteristics
. F) O: E ^: V* @& O+ r静态特性偏差 Static characteristics derivation
% o( a( h6 D) Y8 j& z开阀过冷度 Subcooled temperature of open valve
9 |" Z& `& L( X2 o6 R8 Z- t G! J开阀温度 Opening valve temperature 6 t7 Z5 q9 r& Y f5 m5 }3 }
开启高度 Lift 0 L v( ? M1 \1 g: g0 }4 X/ ~
壳体试验 Shell test
3 n& N$ U5 J9 D4 E9 T8 _壳体试验压力 Seal test pressure
( X# z: E; b2 E9 ]2 o* n) w5 l空气阀门 Air valves
8 U/ m9 \4 X, [4 w6 U! H快速排污阀 Quick Draining Valves
, @/ v' L/ ~" ^2 Y& W( n类型 Type * M1 J9 I Q+ m: n: j. G
冷凝结水排量 Cold condensate capacity
) p4 z. f* l( s冷态试验差压力 Cold differential test pressure . G. g1 [8 ~8 k7 F' n$ ~
理论排量 Theoretical flowing capacity
1 I: O5 _3 ]+ q. U% I/ D连接槽尺寸 Dimension of connecting channel
8 w n- R' t0 Y5 f" R# G& |连接尺寸 Conncetion cimension
& X* n" T2 p7 q: Q7 @连接形式 Type of connection - Q( t8 B+ P( V0 R& C
帘面积 Curtain area . a/ B6 \+ ~9 f7 r
流道面积 Flow area / l& @ d8 ?3 c0 ]" Q) M8 {9 ?
流道直径 Flow diameter 7 s9 Z0 y, c2 V6 M! z+ ?# h
流量孔板 flow orifice plate
/ T U( ?. _/ T, g' `流量控制阀 flow control valve
4 t7 `+ T! m# f' R ~+ W5 s流量特性 Flow characteristics 5 N) E5 V5 R' I- f3 m3 P6 Y! a
流量特性偏差 Flow characteristics derivation 4 ^/ V$ i' u) ^) R* V/ q5 r
漏汽量 Steam loss
! b8 D" G/ Y6 W+ s1 {2 j/ `脉冲式疏水阀 Impulse steam trap 3 l& C! K+ ^2 s% W) e5 e$ W
密封面 Sealing face
, {! Z$ R- P0 Q2 ~3 s3 Q' v9 h2 \2 c密封试验 Seal test 9 W- E3 [+ M( ?1 Z1 D
密封试验压力 Seal test pressure 3 y2 G- s/ B* Y* l$ g9 h l& f
明杆平行式双闸板闸板 Double Disk Parallel Gate Valves
( d) @* P" a9 \) h& j明杆闸阀 Outside screw stem rising through handwheel type gate valve
) _* S4 D1 v! R* X- p& B; l膜片 Diaphragm & q; y, x5 D7 N# |; O
内压自封 Pressure seat + m: o0 H( f' M+ c! u+ V) ^
逆止阀;止回阀 check valve * S/ Q% v; S1 A& B- \
逆止阀;止回阀 non-return valve ; o ]4 [$ T3 B' ~' \* \
逆止阀;止回阀;单向阀 check valve
! [* h0 V( `* c1 ^7 P排放背压力 Brilt-up back pressure
7 d ~' L: X1 I3 w+ _- W+ h排放压力 Relieving pressure
( j; _( T: }6 B n- T, x5 C- Q' A% E排灰阀 Ash valves 0 e9 S5 S- |( B. w9 f H
排量系数 Coefficient of discharge
. o% E0 W- e9 x' b+ w' U! O5 y& H9 a排气阀 air release valve 4 y& t8 d4 \- @0 Z
排气阀 Exhaust valves
5 V4 g: D1 M [, V/ z: H; ]) I排气阀 Vent Valve
5 g7 F& n% t1 q B9 q. w排水阀 Drainage valves . v+ z. Q. Y, I
排水温度 Temperature at discharging condensate
, K! ^3 a0 S6 b4 L+ x, P5 j# S% f排污阀 blowdown valve 1 c& b; n6 W' w# Q5 e5 k
排污箱(阀) Waste Valves 5 e& W# b$ K' X
排渣闸阀 Scum Gate Valves
/ p) K. ^1 w- [4 \6 F8 v( _盘阀 moushroom valve 0 F6 Q- D. H7 p
盘状阀 plate valve 8 ]7 Z6 r/ |- o6 r: R" ]+ G0 p# q
旁路阀 by pass valve
( V* p" x. w R5 I6 v* C配汽活塞阀缸套 piston valve line 1 a8 U+ L( U6 |
喷射阀 injection valve & n$ a, \ s% [' q! [5 B
喷射阀 sprayer valve
( T* P- [5 t7 `- b, B" w喷水阀 spray water valve % g1 D% A, }) a3 V
频跳 Chatter 7 w( E. p9 I/ t) d# ]
平衡阀 Balance valves
( p. k' }# i9 k) X平衡式 Balance type
; g. o4 Z4 W7 E. q$ a/ M平行式闸阀 Parallel gate valve Parallel slide valve 1 e4 x5 a' G" P5 O% P
启闭件 Disc
, B9 [+ Q5 o- A$ W8 s; E4 r启闭压差 Blowdown of a safety valve " k! }. O% S% d; E
起始升程 Commencement of lift
; m v) j# B6 C, x& [& i- p8 ?2 n气动装置 Pneumatic actuator + e- a0 Y' J1 P% C5 `
气阀摇臂 valve arm * P1 N& b/ F! _
气-液动装置 Pneumatic-hydraulic actuator ' @. k- l$ F' J
潜水电泵(排污泵) Submerged Motor Pumps
# O8 h& ]. c" y" \* v/ n& }切断阀;截止阀 block valve;shut-off valve;stop valve / }) ?. _- {) T% C" f$ L8 b; q
切断式止回阀 stop check valve
- D) N. Q' f B" E/ {切换阀;多向阀 changeover valve
0 \3 m% S( E" \( w球、球芯 Ball , ^ Y2 w: Q5 o% H
球阀 Ball valve $ p* {# {1 U4 @; s! D( ?
球阀 globe valve " t% |$ q# A7 V2 Z1 w6 a9 b
球体 Ball # E0 ~# I4 t# ?1 Z
全启式安全阀 Fall lift safety valve
; R* `! j; R" |热凝结水排量 Hot condensate capacity $ S a( `% `6 ]- R4 T9 }
入口隔离门 suction isolating valve
8 r7 _. Q0 n& P& V: @1 S. c塞子 Plug & D; R: g+ N }/ ~
三通阀 three-way isolating valve . \# b& u1 G6 I# P
三通阀 three-way valve
! e$ ], I7 q$ {1 q. k. Q& T# f三通式 Three way type 3 S8 K/ T; [* ?: N
上密封 Back seat ! \2 f$ H1 W7 c- l0 a6 m
上密封试验 Back seal test
2 _+ g# S5 Q. {0 q. {- g! `8 A渗漏量 Leckage
2 Y" d9 H- E. l' B* a* R升降立式止回阀 Vertical lift check valve
+ p! E2 k: p5 s" k/ j升降式止回阀 Lift check valve
. I0 W* l8 i( n' m% c4 r适用介质 Suitable medium 2 {4 ]. A/ B9 N; \) `; d) ]
适用温度 Suitable temperature
4 {; b, K1 M$ G" F$ t1 @6 N手摇油泵(阀) Manual Oil Pumps Valves
' `) L9 J$ l5 A9 B' H8 V疏水阀 drain valve
$ l" F& u5 m% u, K+ p双金属片式疏水阀 Bimetal elements steam trap
' e! i; F: f/ P: r双口排气球 Double Opening Exhaust Valves ! i8 B" W* Q L8 c
双联弹簧式安全阀 Duplex safety valve : \& w! Y2 \6 I7 N5 p
双闸板 Double gate disc " m$ S: d7 |6 {+ N$ {
双闸板平板闸阀 Double Disc Flat Gate Valves 6 w5 ?& \) C% a
水封闸阀 Water Seal Gate Valves ' i W+ P4 e9 K7 O
水力喷射器(真空泵) Vacuum Pumps 6 _6 j3 k: J* @. k. D* u
伺服阀 servovalve * N" L7 E0 k2 M K$ \' q( y. C9 u
填料 Packing $ I G7 F+ E3 S! {* I1 P) L
填料垫 Packing seat
0 J$ P; j: \% N/ H, \* z6 b填料函 Stuffing
3 {4 L! X# w5 g4 g, t& u$ b填料式旋塞阀 Gland packing plug valve
0 m, J8 `3 \' v填料箱 Stuffing box 7 q) N* H2 c+ h& S+ W6 l. s$ Q/ L9 g
填料压盖 Gland 1 O$ Z/ R0 i: O6 t6 ]6 y2 I
通气阀 breather valve ; Q2 j; p# d0 x' q
通气阀;呼吸器 breather
% j4 j# C& [% g* k; _7 ^通用阀门 General valve ; T' s+ l) N2 b3 s' ] o
吐出阀;排出阀 discharge valve ' @2 b" K$ ^3 o! T6 R- J- B8 ?$ s
吐出阀限位器 delivery valve guard + k! N' T: }& O* \
微启式安全阀 Low lift safety valve
/ h( T7 d- U9 ~2 M. n6 o微阻缓闭止回阀 Tiny Drag Slow Shut Check Valves 1 B; e/ Z4 k- O' u- M4 U
吻合度 Percent of contact area ) W- G$ E0 E9 ~! Z
蜗轮传动蝶阀 Butterfly Valves with Gear Actuator . }$ d+ g8 z9 q/ s& k. r7 g" S
蜗轮传动装置 Wormgear actuator
@ L! C$ c% X3 M( N9 m屋脊式隔膜阀 Weir diaphragm valve . O" E [& G" q5 c
无阀泵 valveless pump & u0 `/ [& c! s; ~
无阀隔膜泵 valveless diaphragm pump . r" o0 O5 }8 f" J6 U) h4 F: c7 d
无阀振动泵 valveless vibration pump ) u- }8 q* @! E" G( n: {% f x
无负荷漏汽量 No-load steam loss
4 j- z: R7 t, v0 G无负荷漏汽率 Rate of no-load steam loss & j! C. `# \$ E8 Y0 d0 |
吸(抽)气阀 Aspirating valves
" f; f T1 l5 n6 R! i吸入阀 suction valve 6 {- c' @+ U2 w7 | J7 a
吸入阀限位器 suction valve guard
R8 f+ m( c! }5 K0 @6 C, F0 b3 D先导式安全阀 Pilot operated safety valve
& H) W- j6 n1 T! h' j先导式液压阀 Pilot-operated reducing valve
4 y5 }3 X1 d; d8 E' m# O相对静偏差 Relative static characteristics derivation + t0 V7 s: y F; D/ }( {
相对流量特性偏差 Relative flow characteristics derivation
; N" a; R* U) Q! V相对压力特性偏差 Relative pressure characteristics derivation
- p# w- L# v9 l6 l销轴 Hinge pin
: T9 ]7 Y- J' g6 |+ b楔式闸阀 Wedge gate valve 5 i) Y0 ^" P$ [- t
斜板式蝶阀 Indined disc butterfly valve . Q3 e {# C* `7 K; ?0 I! [
泄料(放空,排污)阀 Blowdown valves
1 Z# c! s, W, s& Z) x泄压阀 Decompression valves
* V" ^8 M6 o$ r1 d泄压阀 pressure release valve - b) t. f6 J+ m3 f/ v' ]
泄压阀;安全阀 relief valve ; ]" C T5 W7 U U, \) n* @ H! x- w
卸荷式减压阀 Balanced reducing valve : T6 \6 e3 @: S7 K
型号 Type Model
. `" u9 Y; i0 q( T% ~ d7 ?旋启多瓣式止回阀 Multi-disc swing foot valve ! H' _9 T0 H8 y3 o7 P; L
旋启式止回阀 Swing check valve
& l* R: p( H& _' [2 V1 k旋启双瓣式底阀 Double disc swing foot valve 6 q1 V: }) q% R/ B2 _
旋塞阀 Cock
* P5 i' K/ o" }, R旋塞阀 plug valve
8 h& Z0 {9 d7 E' x @压力(増压)阀 Pressure valve
, |3 M/ t3 Y" v1 \+ ?! n压力调节阀;压力控制阀 pressure controlled valve
! {* x3 |6 U$ ~' K# [ _+ D, {压力特性 Pressure characteristics
) J- l2 T+ ?+ N; R压力特性偏差 Pressure characteristics derivation 5 d) l, I4 Q* n7 w8 G
压力增长系数 Pressure increasing ratio
9 O) Y% P( X) p9 p* n+ ^3 |摇杆 Arm
3 @9 o1 r2 Y0 D液动装置 Hydraulic actuator & _) y" \$ D$ Y d6 D7 b
液化气管件 LPG Pipe Fitting : d ]; R7 f2 I) N' l# ~) t' G( g
液下泵 Under Water Pumps * V5 e6 y8 c8 A, t
液压执行器 hydraulic actuator
7 S0 R# k8 y% A" q o仪表针形截止阀 Meter Needle Type Globe Valves
- R4 B1 L8 X3 I$ N' A溢流阀 overflow valve 2 O0 \% |# y- }3 W, @8 q
翼形阀;锥形阀 wing valve
9 ~7 Z; e* H. K6 o& G% k' ~2 l2 W油封式旋塞阀 Lubricated plug valve $ o& s* V; O. }% |$ f
有阀翼板 double acting wing
: E+ g; P" }' y, t1 B/ f4 {有阀翼板 wing with valve / e: H: r$ G( H. b1 p; r
有负荷漏汽量 Load steam loss
# r# }$ d; w$ a8 v有负荷漏汽率 Rate of load steam loss
8 K' D5 `. ^. n4 U9 A4 i% h圆板阀;圆盘阀 disc valve - o: E3 W' }# D' [
圆盘式疏水阀 Shemostatic team trap ' n* N$ u/ R7 U* _( W
圆柱齿轮传动装置 Cylindrical gear actuator ' u1 K1 B/ D+ T; ?# \
圆锥齿轮传动装置 Conical gear actuator
; O: D; Y3 @3 p9 E+ W闸板 Wedge disc
: u+ Z' q7 }9 Z( D闸板式隔膜阀 Wedge diaphragm valve
) P8 z- L) n3 I闸阀 gate valve
$ R2 n/ C5 a8 \9 ~6 r4 s闸阀 sluice valve " P' \" q9 ? T. r7 y
针形阀 Pintle valve ; Needle valve
; g" T1 M8 b. k2 F$ I真空破坏阀 vacuum breaker valve " |3 e, q/ [- O& Y( X u. T5 ]
蒸汽疏水阀 Automatic steam trap Trap 4 b, {- q; Z' p9 ?; V7 U( r5 v
整定压力 Set pressure - Q3 Q _. U" i
正向作用式减压阀 Direct acting reducing valve
4 ]4 c- |0 n3 i* L. A8 G支架 Yoke
+ D- d- [) z! ~! x$ E$ K" z0 b直接载荷式安全阀 Direct loaded safety valve / S: G# j' O" o4 D
直接作用式减压阀 Direct-acting reducing valve * Q+ r, u, p: \
直流式 Y-globe type 7 X" {7 P0 ?1 `. p# X
直流式截止阀 Oblique Stop Valve
# j z9 O" K7 x- u3 N直通单向阀 inline check valve ( D& j5 V0 K5 n6 c' C f
直通单向阀 straightway check valve
- n6 U4 @% F' u& Z4 w8 C1 k: G直通阀 Throughway Valve
" j7 y, w& \4 X止回阀 Check Valve
8 ?8 o1 z5 R* L( c1 |. z( e止回阀;回流阀 reflux valve
- L4 h4 _8 v x; Y制动阀 Brake valves . D0 D1 p2 P0 F% w# g* B, k8 T5 P
中压阀门 Middle pressure valve 0 L) e; h( }0 j, x3 [+ A
钟形浮子式疏水阀 Inverted bucket steam trap
( H5 B' Z* u( ] \; r钟形罩 Inverted bucket 9 U% D3 ?1 r( a2 [
轴套 Axis Guide
. I8 {, c6 C5 Y主阀 Main valve
9 x" z: V, k1 B2 s2 t/ `主要外形尺寸 Prime out-form dimensions # a! l% Z# ~' l) E) P
主要性能参数 Specifeca tion speeification % ]$ a. H- S6 G8 x; T: G/ _
注液漏斗阀 Priming Tundish Valve
- d; ]; W; N* Q. }( P3 g9 X柱塞阀 Plunger valve ' H( K# S; v6 T
柱塞截止阀 Plunger Globe Valve
]2 J1 c% |/ K: h9 W( p1 ?/ }; q柱塞型摆动阀 rocking plunger valve
9 Y# x6 [( r0 m1 s8 F撞击手轮 Impact handwheel
# `2 }% D4 w! J6 @. U. z D7 ?锥形阀;翼形阀 conical valve
7 C+ @. s# K0 y; B) s3 w自动循环阀 Automatic Recirculation Valve
' t5 }$ ]2 w+ D. U3 G% a组合阀 Combination valves
# R$ b' S% y: y9 o7 t+ [* Q最大过冷度 Maximum subcoold temperature
' x% y, _/ s' h) Z v3 @最大流量 Maximum flow rate
3 N' d6 @$ O" J- v" S$ F最大压差 Maximum differential pressure 9 e1 K1 r' m1 U \
最低工作压力 Minimum operating pressure 9 a' X* v" f$ ~5 n
最高背压率 Maximum rate of back pressure % s& C1 I: n/ b+ S0 c
最高工作背压 Maximum operating back pressure
- x" s: w, ^, n, e% i8 X% {最高工作温度 Maximum operating temperature ' t2 {* m) U) D4 |3 @; R" ~; z \
最高工作压力 Maximum operating pressure / ?& H. j% n4 B) b
最高排水温度 Maximum temperature at discharging , K4 B# a3 ~6 ~ Z9 J
最高允许温度 Maximum allwable temperature
2 ]. {7 K. ]2 @最高允许压力 Maximum allowable pressure
) X o& [! D+ O+ }; K& \最小过冷度 Minimum subcooled temperature " @) j: }8 \1 k: Y6 [3 ?& i
最小压差 Minimum differntial pressure |
